Question about LG 37LC7D 37 in. LCD HDTV
Humming sound on new lcd tv
Just purchased a new Samsung LCD tv and on mute and low volume it has a humming sound...
any idea what can cause this?
  • 344 Answers
Probably a cooling fan!
Posted on Jun 17, 2009
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
I having problems with the volume. When I start watching t. v. the sound keeps lowering until it goes completly mute. Im not pressing any buttoms, the t.v. is new. How can I do to solve this problem?
This problems is the intermittent cause by the tv Tuner signal board.If this a new tv,take it back where u bought the tv and make an exchange for a new tv or call the Samsung corporation for a warrenty repair.
Nov 24, 2010 | Samsung LN32A330 32 in. LCD TV
I have no audio
Hello sir, Hi, No Audio on your TV can be user error or Hardware error, for the user error, make sure that the TV is not set to low volume or the setup is on MUTE, for the hardware error, Place your ear close to the speakers, then set the volume up and down several times, you should hear a soft hum that goes up or down, (make sure that the room is quiet.) The soft hum means that the power amplifier is working properly. so the problem may be on the main board where the sound is being produce before amplification, usually the sound IF section. NOW if you did not hear the soft hum, problem with the amplifier and speakers, A physical checking for open wire contact or loose connection is needed.
Aug 20, 2010 | Sharp LC46SB54U 46 in. LCD TV
No Sound on Samsung HDTV? But there is a picture...
Push the MUTE button on the TV remote to restore audio.
Nov 18, 2009 | Samsung LN-T3253H 32 in. LCD Television
I recently purchased a 52 inch LCD. I have
This could be the speakers are vibrating onto the casing and need padding out more to prevent this.If this isnt the case, you may have a sticking coil on one of your speakers..When the sound distorts, remove one speaker in turn to see which one(s) are the offending unit(s) and replace. Is there a buzzing noise coming from the speakers especially in low volume? If so then you may have a faulty capacitor in your power supply producing hum on sound. Hope this helps :)
Oct 17, 2009 | Toshiba Televison & Video
No volume on my Samsung 50" flat screen
Go check up the settings. First disconnect all appliances and then reconnect when power off. Configure connection when power on.
See your manual. You use the analog tuner or digital cable or satelte receiver to watch TV. If external digital decoder check your settings there. They are independend and might be low or muted sound level or incorrect setting.
Apr 14, 2009 | LG 42LC2D 42 in. LCD HDTV
Hum in sound volume
It could be a few things. The first thing you want to look at is make sure that the microphone is muted in the mixer controls of your audio cards. These settings are located in the control panel. If you need the mic, look under the advanced settings under it and disable the 20 db option for it.
If that doesn't work I have a few other ideas.
Mar 17, 2009 | Proscan 32LB30QD 32 in. LCD TV
My lcd tv makes a humming noise
Try removing all cables going to the TV except the power cord. Power on the TV and press mute. If you have any unwanted noise, then you have a defective TV and since it is new, you should get an exchange. If there is no noise with the A/V cables removed, then you might have hooked the source (cable box/DVD Player) into the wrong inputs of the TV.
Mar 14, 2009 | LG 42LG30 42 in. LCD HDTV
Samsung LN32A550 32-Inch 1080p LCD HDTV
Best Buy Samsung LN32A550 32 in. 1080p LCD HDTV Free shipping Order Today! [Click Here!]
Samsung LE32B650T2 32-inch Widescreen Full HD 1080p
Save On "Best Buy Samsung LN32A550 32 in. 1080p LCD HDTV" You can Buy Samsung LN32A550 32 in. 1080p LCD HDTV In Stock. Low Prices Samsung LN32A550 32 in. 1080p LCD HDTV Shops & Purchase Online - Quick & Easy.
Discount "Best Buy Samsung LN32A550 32 in. 1080p LCD HDTV" Free Shipping & Pay No Sales Tax! You can Buy Samsung LN32A550 32 in. 1080p LCD HDTV In Stock Low Prices Samsung LN32A550 32 in. 1080p LCD HDTV Shops & Purchase Online - Quick & Easy.
Dec 10, 2008 | Samsung TXJ2879 28" TV
LG 37LC7D 37 in. LCD HDTV Logo
329 people viewed this question
Computer Repairing
Computer Repairing
