Question about Panasonic KX-TG4500 Phone
People on the other end can't hear us on Panasonic KX-TGA450
Ever since we started using this phone the sound quality has been terrible. People are always complaining they can't hear us. I have hit the reset button several times but nothing seems to help. I have called tech support several times (but they couldn't hear me-HA!) Does anybody know if this is a common problem or is it a problem with just my unit? Would it be the base unit since all my handsets have the same problem? I'd probably scrap the phone if I could find a similar phone with 4 line cordless features. Help, please!
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Posted on Jan 16, 2008
SOURCE: Openning a panasonic cordless phone handset
Carefully slide a thin bladed jewellers screw driver along the side of the case as you go the catches will release, do not force it !!
Good luck
Posted on Mar 05, 2009
SOURCE: my panasonic kx-tga520m cordless handset does not
Because your phone was low on battery, you will not see this feature. Once you charge your phone fully, you will start receive phone calls and you will see this feature activating again.
Posted on Jan 20, 2010
  • 5528 Answers
SOURCE: I want the user's manual
The handset manual is here: http://safemanuals.com/user-guide-instructions-owner-manual/PANASONIC/KXTG1100CX-_E (you'll need to rate the product or enter security code to download).
I hope this helps.
Posted on Jul 28, 2010
Testimonial: "It really was useful, as now I can set the settings on my phone and get the ful out of my phone."
SOURCE: I have a Panasonic KX-TCD220E
I had the same problem with KX-TCD220E and BT line. Cured by changing the DSL filter.
Posted on Nov 13, 2010
To set up my panasonic KX-TG633 cordlessphone
Print the Manual and read it cover to cover. Or online and read beginning to end.
ftp://ftp.panasonic.com/telephone/om/kx-tg633_en_om.pdf
KX-TG633SK - Panasonic
shop.panasonic.com > Get Support
Rating: 2.7 - ‎3 reviews
DECT 6.0 PLUS 3-Handset Expandable Digital Cordless Phone with Answering System.
[PDF]Operating Instructions (English) - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/telephone/om/kx-tg633_en_om.pdf Jul 15, 2016 - Operating Instructions. Cordless Telephone with Digital Answering Machine. Model No. KX-TG633SK. Before initial use, see "Getting Started".
panasonic kx tg633 manual Google Search
Aug 15, 2017 | Panasonic Lands Phones
Tip
Do you have a constant buzzing sound in your handset?
The NiMH batteries used in these phones have a useful life of about 2 years. With only 2.4v at normal operation, the amplifier circuit will start to pick up interference as the voltage drops in an old battery. If you hear a constant buzzing, no matter your location or distance from the base unit, then it's most likely your battery causing the problem. Some phones are more susceptible than others causing the buzzing to start earlier than another phone. Battery Buzz is a good indication to change your battery as soon as possible. As the problem gets worse you will have voice and connection problems. Since transmitting uses the most power, you will be unaware when your voice quality drops dramatically for the people on the other end of the call.
on Jul 05, 2007 | Panasonic KX TGA400B Cordless Expansion...
Panasonic phone model kx-tsc83cid automatically show backlight and show strange number like 5555555555555.
In the smallest case there can be an accident happend when there is coming some moisture inside the matrix-keypad interface of the phone
when there are separate hard plastic buttons in the phone you have more luck to find the cause by disassembling the filmsheet of the phone its sheet with matrix conductive paths, clean this between inside the sheets in case its possible , or when the buttons feeling rubber then its more hard to find the problem a new filmsheet or a gray sillicon -keysheet its hard to sell this or clean it when there was some coffee or moisture inside and after drying a film of with a little wd40 on a cleaning Cloth make it good dry . in the other case its better to buy an other phone its saves time and priority because Panasonic has very good products as there are Powertools and some hifi, and televisions and other things fotocameras BUT .... a nice phone with a good sound its hard to find maybe this is maybe the one and only model , because i have never ever liked the (extra noise by ringing) and the whole sound of the different lines of Panasonic phones its not the quality of the phone itself but the speaker inside its always choice terrible voice they better can stop buiding phones , and i have never stricked a comfortable Panasonic phone and always compare the sound with a pretty and good sound without (noises) Siemens even or even a cheap Profoon phones this is not the best quality made in comparison of Panasonic but its sounds realy much better and very pretty to use . yes .. the quality of the brandname of the phone is not allways the priority. in choice. good luck
Jul 19, 2014 | Lands Phones
Handset on panasonic cordless only works with headset
It appears there is something internally wrong with your handset. We recommend you use the below link to setup service.
www.panasonic.com/repair
Apr 28, 2014 | Panasonic KX-TG5422M Cordless Phone
I would like connect kx-t7730 to tda100 .can I connect it ?
Yes. However, it will only work if you have the 8-port hybrid card(TDA0170) installed. Besides costing a lot more money(the card, not the phone) the phone uses 4x the power of a 76xx or DT series phone and you only get 12 lousy working buttons.
Carl
Nov 30, 2010 | Panasonic KX-T7730 Corded Phone
Panasonic kx-tga561az code less phone speaker not working
Constant background fuzzy noise and poor sound quality
May 27, 2010 | Panasonic KX-TG1033S Cordless Phone
Hard to hear on one of the handsets
we have the same phones, the volume can be adjusted using the key pad but only slightly the hearing overall with this phone is not so great you end up straining half the time to hear the conversation
Sep 04, 2009 | Panasonic KX-TGA101S Cordless Handset
KX-TG6500 Battery wears out too quick
I called Panasonic and they anserwed all my questions. Thanks.
Mar 24, 2008 | Panasonic KX-TG6500 Cordless Phone
Panasonic KX-TG4500 Phone Logo
129 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
