Question about Kiddieland Toys
I tried to reset the polly pocket electronic secret safe to use a new code and it won't work?What do I do?
The default code is "Polly"... Use this after resetting with the reset button or remove batteries...
Posted on Sep 24, 2011
I can't open my bumil safe and the combinations i have are old and i think i keep getting them wrong, im not sure what to do.
Take it to a Locksmith. Most newer safes (15 years or younger) have a secret way to get inside, which the manufacturer is willing to reveal ONLY to a bonded-professional Locksmith. If there is no secret entry, then the safe will have to be drilled open (i.e. "destroyed"); and that too must be done by a locksmith because only they know _where_ to drill. Lastly, If you have electronic code entry, try installing new batteries, and retry your combination codes. Ps... I am a locksmith. I know what I'm talking about.
Oct 14, 2015 | Home Security
Cannot open my secret safe by justice
Reference: Paisley Electronic Push Code Safe
Item # 5661462
Purchased at Justice. May be one of the following design/colors: 1. Pink and black 2. neon green 3. tye-dye (all in zebra pattern, I believe)
To gain access to safe without code proceed with the following simple instructions:
Use a screw driver to access batteries on the bottom of the safe. Remove all three AA batteries.
WAIT AT LEAST TEN SECONDS before reinserting betteries to functional position. Replace screw. Key in default passcode "0000#" Safe will now be unlocked and upon opening you can reset passcode. Hold down the "*" and when voice prompted to "key in passcode" enter new 4 digit code followed by the # sign... HOLD "*" until completed code with "#" You will hear the voice command, "enter passcode" after each digit entered. [Press & hold "*" (1234) press "#" release "*"] Close safe and new passcode should be set and work properly. If not, enter default "0000#" and try to reset once again.
Feb 03, 2014 | Toys
How do i change my code on my safe? it is a S-25E i have keys but want 2 change the code
Try this,
NOTE: The safe needs to be upright and right side up or the locking mechanism
won't work.
ELECTRONIC SAFES
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad -159B. (These numbers are preset. You should change the code as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter "B" on the electronic touch pad.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the live action locking bolts.
Good luck
Thanks
Apr 29, 2011 | Office Equipment & Supplies
Gordon electronic safe and can't open it
Wow , I have the same safe thats been locked for more than a year.
I locked the keys in the safe and forgot the code.
I took the thing out side and droped it on its corner and whala.
go figure it worked ,thank you to who ever was the first 1 to try that
cody in west palm beach,fl
Feb 13, 2010 | Safe International Digital Electronic Safe...
I LOST THE MANUAL, HOW TO RESET THE NEW NUMBER?
I LOST THE MANUAL FOR THE 'HARDLINE' DIGITAL ELECTRONIC SAFE. HOW TO RESET A NEW NUMBER?
Dec 22, 2009 | Safe International Digital Electronic Safe...
I can't reset by keypad on my cannon gun safe electronic key pad
First I would try the original numbers to see if you did change it. If the original numbers work then you need to start over. If they don't work then the new numbers you installed are there and you need to figure out what you punched in not what you meant to punch in.
Hope this Helps,
RSMITH972278
P.S. FOR FURTHER ASSISTANCE PLEASE PROVIDE MAKE AND MODEL
P.P.S. PLEASE RATE ME
Nov 15, 2009 | Locks & Locksmithing
I forgot the safewell electronic code and didnt have the key
won’t work.
ELECTRONIC SAFES
electronic keypad –159B. (These numbers are preset. You should change the code as soon
long, and confirm your new code by pressing the letter “B” on the electronic touch pad.
If you can not get this open more then likely you will have to cut it open.. One last thing to try is to email safewell sales@safewellsafe.com
Good luck
Sep 14, 2009 | Locks & Locksmithing
Need to reset the electronic code to open the safe.
are you the manager user of the safe?if yes,you can reset a new code by yourself.
Apr 06, 2009 | Safe International Digital Electronic Safe...
Toys Logo
773 people viewed this question
Top Kiddieland Toys Experts
ray gallant
Handyman
David Payne
David Payne
Are you a Kiddieland Toy Expert? Answer questions, earn points and help others
