Question about Frigidaire 24" Tall Tub Built-In Dishwasher - Black
Fridgidaire dishwasher will not fully drain. - Frigidaire 24" Tall Tub Built-In Dishwasher - Black
  • 6,784 Answers
HI, i recommend checking the following areas to combat this issue.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Posted on Jun 17, 2009
Online live chat
Ours has done this as well and we use a hairdryer to thaw it and works again.
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Feb 28, 2018 | Frigidaire Dishwashers
Dishwasher not draining
Our dishwasher drains into the same pipe our sink does, which I think is the case with almost all of them. If the drain pipe is getting clogged, it will be difficult for the dishwasher to drain. I would suggest to try drain cleaner (BE SURE TO FOLLOW DIRECTIONS) and if that does not help I would remove the hose from the drain under the sink and see if the hose itself is getting clogged. Our sink drain also gets to the point that drain cleaner does not work, so I remove the "trap" and clean it out.
Jan 03, 2018 | Electrolux 134743500 Fridgidaire Washer...
Fridgidaire does not pump out all the water
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Jan 24, 2011 | Dishwashers
Water not draining
You need to access to the drain hose, located under the bottom panel, and check that this is not clogged, if you do not find anything in there, check that the connection to the drain line outside the machine is not clogged.
If still no luck, then check that the drain pump is not faulty, that is possible.
You can find schematics and replacement parts by entering model number here.
Feb 18, 2009 | Frigidaire Dishwashers
Fridgidaire FDB126RBS2 Won't Drain in Rinse Cycle
check the drain pump for foreign object in the pump if nothing is found replace the pump
Apr 25, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Dishwashing machine not fully draining (2 inches of water remain). I have an open problem concerning this problem. I have a new pump. dishwashing machine not fully draining (2 inches of water remain) For...
Following a cycle, a small pool of clean water inside the tub is typical. Excessive water means the pump isn't pumping water out properly, the drain hose isn't carrying it to the drain pipe, or the house's drain lines are backed up. If dirty water spews from the air gap, the drain line is kinked or clogged. Note: If you've recently installed a garbage disposer, be sure the knockout plug for the dishwasher was removed when the connection was made (see your disposer instructions).
Apr 19, 2008 | GE 24 in. GLD5860LSS Stainless Still...
Fridgidaire dishwasher model # FDR252RBS1
just doing it by the numbers ask your husband if he removed the drain loop from the side of the tub to get extra drain hose if he did reply to me before going on next take the drain hose loose from the sink get a mop buckit put the hose in it then turn it to start and close the door holding the hose in the bucket if it drains and the drain loop wasnt removed check the place where it goes into the sink for blockage let me know what happens
Jan 30, 2008 | Dishwashers
Dishwasher not draining fully
Remove and replace the motor / pump assy. Call technician. Big Job
Dec 02, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Frigidaire 24" Tall Tub Built-In Dishwasher - Black Logo
282 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
