Question about Compaq Armada E500 Notebook
NTldr missing and non system disk or disk error replace or strike
Can't load a: or d:
    Problem Solver:
  • 18 Answers
Hello:)
Try fn+f10, else try fn+f8.
Good Luck
Posted on Jun 17, 2009
Ntldr is missing press ctlr+alt+ and delete to restar and i did and don't workz
First I have to assume that you are running Windows XP. This solution should work for other versions of Windows.
The "NTLDR is missing" error displays very shortly after the computer is first started, immediately after the Power On Self Test (POST) is complete. Windows XP has only initially begun to load when the NTLDR error message appears.
Causes of NTLDR Errors
There are a number of possible causes for NTLDR errors, including the most common "NTLDR is missing" error message.
The most common reason for this error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Other possible causes include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
How to Fix NTLDR Errors
1.Restart the PC. The NTLDR error could be a fluke.
2.Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
3.Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
Try replacing the IDE cable cable if you suspect it might be faulty.
9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
NTLDR Errors Apply To
This issue applies to the Windows XP operating system, including Windows XP Professional and Windows XP Home Edition.
Windows 8, Windows 7, and Windows Vista utilize BOOTMGR, not NTLDR.
Still Having NTLDR Issues?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more. Be sure to let me know what steps, if any, you've already taken to fix the "NTLDR is missing" issue.
Jan 29, 2014 | Microsoft Windows XP Professional
Tip
NTLDR is missing?
A missing NTLDR is a common start up error that can appear on the screen while booting a computer running a Windows operating system. This error may occur due to number of reasons.
NTLDR is short for Windows 'NT LoaDeR'. It's entirely involved in the loading of the operating system.
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk/hard drive that contains no operating system or CD-ROM drive. Firstly what you've got to to is press the Delete key multiple times as your computer boots up until it displays the BIOS screen. Then you will need to find the boot disk priority setting. Make sure this is set to your drive that has Windows on it (as priority 1) and not the CD-ROM drive/stiffy drive or empty hard drive. You can set the CD-ROM/DVD-Rom drive to priority 2 if you like.
Once you have checked that and have set it to your master/primary hard drive (the one that you've installed Windows onto), save and exit the BIOS and on reboot your system should boot into Windows normally.
If you only have one hard drive and the boot disk priority 1 is set to it and you still get this message, then it means that your NTLDR is either corrupted or missing. In the BIOS you will need to change boot disk priority 1 to your CD/DVD drive. Once this is done save and exit the BIOS.
As the PC reboots insert your Windows install disk and let it load.
Hit [R] when prompted if you need to repair system files and then [C] at the 'Welcome to Setup' screen to start the Recovery Console. This will let you copy NTLDR from the CD to C:\
If this fails then you will need to install a fresh copy of Windows on your system. All is not lost though as you can still save your data that is trapped on the NTLDR missing hard drive. If you are not quite seasoned with computers and electronics then this is the job for a PC technition. Simply take your PC down to your local Computer store and explain your situation (Don't forget to take your original Microsoft Windows with you). They will back up your data, re-install Windows and the put all your data back on for you.
on Nov 15, 2010 | Computers & Internet
My windows XP has an error message when started. It says "MISSING NTLDR, PRESS CTRL, ALT, DEL TO RESTART" I tried restart with boot disk but nothing. Please help!?
  1. Restart the PC. The NTLDR error could be a fluke.
  2. Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Jan 22, 2014 | Belkin Basic Wireless Router
Dell inspirion 6000 is showing "loading PBR2.....done. NTLDR IS MISSING.HOW TO FIX
Use the Restoration Disk. When asked choose Repair.
(Non-Destructive Installation)
You are missing basic Windows files. Boot loader files.
Also you may have to prepare to replace the harddrive. May have bad Sectors on it.
Means I would copy off all personal information, after getting that laptop going again, or you may lose it.
Regards,
joecoolvette
http://en.wikipedia.org/wiki/NTLDR
http://computer.howstuffworks.com/hard-disk.htm
http://computer.howstuffworks.com/hard-disk7.htm
Dec 19, 2012 | Dell Inspiron 6000 Notebook
NTLDR is missing is displayed when i turn on the computer
The "NTLDR is missing", error displays very shortly after the computer is first started; after the Power On Self Test (POST) is complete. Windows XP might only initially load when the NTLDR error message appears. Causes of this error message include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Get more help and information for Windows XP hope this helps you.
Mar 01, 2011 | Microsoft Windows XP Professional
NTLDR is missing
this is a very common Issue:NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Causes:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Windows XP users
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
hope that it will be help full
thanks
Oct 27, 2010 | Dell Computers & Internet
Ntldr is missing
These are the common causes for this error Computer is booting from a non-bootable source. Computer hard disk drive is not properly setup in BIOS. Corrupt NTLDR and/or NTDETECT.COM file. Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is usingFAT32. New hard disk drive being added. Corrupt boot sector / master boot record. Seriously corrupted version of Windows 2000 or Windows XP. Loose or Faulty IDE/EIDE hard disk drive cable. Failing to enable USB keyboard support in the BIOS.
Please checkout this link for fixing the same Ntldr is missing
Sep 19, 2010 | Computers & Internet
What is NTLDR error sir?
NTLDR (abbreviation of NT Loader) is the boot loader for all releases of Microsoft's Windows NT operating system up to and including Windows XP and Windows Server 2003. NTLDR is typically run from the primary hard disk drive, but it can also run from portable storage devices such as a CD-ROM, USB flash drive, or floppy disk. NTLDR can also load a non NT-based operating system given the appropriate boot sector in a file.
NTLDR requires, at the minimum, the following two files to be on the system volume:
  • NTLDR, which contains the main Boot loader itself
  • boot.ini, which contains configuration options for a boot menu.
This error means that NTLDR is missing somehow from your computer,hard disk problem,virus.etc
You can go to that page and follow the instructions exacty as he says and your problem will gone:)
http://www.tinyempire.com/notes/ntldrismissing.htm
Jan 12, 2010 | Abit KW7 Motherboard
I have a Epic notebook ACE 1314 model no. MS_1314 and when i turn it on it comes up with NTLDR is missing can anyone help me please? Cheers Dylan
the windows system is trashed - boot from a xp cd and choose repair -
NTLDR is Missing
NTLDR is missing
Causes:
Sep 10, 2009 | Computers & Internet
NTLDR is missing
Reference number: CH000465
NTLDR is Missing. Issue:NTLDR is Missing.
Related errors:
NTLDR is Missing
NTLDR is missing
Cause:
You can go to these sites to view solutions (to much to post here) Very easy to understand:
http://www.computerhope.com/issues/ch000465.htm
May 22, 2009 | E-Machines eMachines Desktop PC
Compaq Armada E500 Notebook Logo
148 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
