Question about Microsoft Exchange Server 2003 Standard Edition for PC
Error the folder http://url isn't accessible. This folder may be loacted on an unavilable volume or protected password or a file may contain a / or . I am triny to ftp using frontpage get the above error.
4 Suggested Answers
ohms
  • 1879 Answers
SOURCE: Frontpage
For information how to access and update your website, you need to contact your webhost.
Posted on Oct 15, 2008
  • 25 Answers
SOURCE: I am getting an error code Server error: Cannot
Call up your web host and ask them to re-install or re activate frontpage extensions on the server which 'should' fix the problem.
From the knowledge base....
When publishing sites with FrontPage, my customer is getting the error "cannot open we80.cnf no such file or folder"
First, switch FrontPage OFF for this customer.
Then find and delete all frontpage directories and .htaccess files: find ./ -type f -name ".htaccess" -exec rm -f {} \;
find ./ -type d -name "_vti*" -exec rm -rf {} \;
Then switch FrontPage ON.
I just posted the last part in case the server admin needs it. Good luck Willine.
Posted on Aug 10, 2009
SOURCE: Cannot access pictures to insert from other folders
I re-installed Frontpage 2003 again ... it worked.
Posted on Dec 03, 2009
How to repair outlook pst file
To restore a file .pst, follow these steps:
From the Start menu, click Run.
In the Open box, type:
Code: Select all
drive: \ Program Files \ Common Files \ System \ Mapi \ KodYazyka \ scanpst.exe
Click OK.
In the Enter the name of the file, enter the path and file name listed in the error message above.
Note. May not be able to use the Browse button to locate the file, t. To. It is located in a hidden folder.
To change the logging during the scan, click Options. If the switch is set to replace or supplement protocol protocol, the log file will be saved in the same folder as the file .pst.
Click the Start button.
When the scan is finished a file, select Create a backup copy of the file before restoring.
Click the Restore button.
If the file has been successfully restored, a message is displayed that the recovery is complete. If using a recovery program "Inbox" file is not recovered, you will need to use a backup file.
Or try to recover files through the program Outlook Repair Kit. She saved me many times.
[url=http://www.microsoftoutlook.repair/]http://www.microsoftoutlook.repair/[/url]
Still I recommend to visit this forum
[url=http://www.filerepairforum.com/forum/microsoft/microsoft-aa/outlook/604-how-to-recover-pst-file-is-too-large]http://www.filerepairforum.com/forum/microsoft/microsoft-aa/outlook/604-how-to-recover-pst-file-is-too-large[/url]
Dec 03, 2014 | Microsoft Office Outlook 2007: Windows
Tip
How to Make Invisible Password Protected Folder Submitted by Srikanth on...
How to Make Invisible Password Protected Folder2761870.jpg Submitted by Srikanth on Thursday, 10 December 200930 Comments Do you want to password protect your folder? Do you want to make it invisible so that it remains unnoticed by the normal users? Well here is a way to do that. In this post I will show you how to make a password protected folder in Windows without using any additional software. Here is is step by step procedure to create a password protected folder.
How to create a Password Protected Folder
Step-1: Create a new folder (Right-click -> New -> Folder) and give it any name of your choice. For instance I name it as ABC.
Step-2: Now in this folder place all the important files, documents or any folders that you want to password protect.
Step-3: Now Right-click on this folder (ABC) and select the option Send To -> Compressed (zipped) Folder.
Step-4: Now a new compressed zipped folder gets created next this folder (ABC) with the same name.
Step-5: Double-click on this compressed zipped folder and you should see your original folder (ABC) here.
Step-6: Now goto the File menu and select the option Add a password.
ie: File -> Add a password
Now a small window will pop up and here you can set your desired password. Once the password is set, the folder will ask for the password every time it is opened. Thus you have now created the password protected folder.
How to make it Invisible
Step-1: Now Right-click on this password protected folder and select Properties.
Step-2: At the bottom select the option Hidden and press OK. Now your folder gets invisible (hidden).
Step-3: In order to unhide this folder go to My Computer – >Tools -> Folder options. Switch to View tab, scroll down and under Hidden files and folders you’ll see the following two options
  • Do not show hidden files and folders
  • Show hidden files and folders
Now select the second option and press OK. Now the invisible folder becomes visible in it’s location. To access it you need the password. To make it invisible again repeat step -1 through step-3 and select the first option and click OK. Now the folder becomes invisible once again.
I hope you like this post. Pass your comments!! Cheers
on Mar 30, 2010 | Computers & Internet
Tip
Password Protect Folders in XP
There are two ways to password protect a folder built into Windows XP (for other Windows flavors, there are some freeware/shareware programs out there).
Method 1:- If you have a log in password for your account, this can be used to protect folders from other users. Your hard drive must be formatted using NTFS (which it probably is unless you're dual booting with another operating system). Here's what to do...
Right-click the folder that you want to make private and choose "Properties" (or Alt+Double-click). Go to the "Sharing" tab and check the "Make this folder private" box.
Click Apply . If you do not have a password on your account, a box will pop up asking if you want to assign a password. This must be done if you want to make the folder private, so click Yes . You will need to use your password to log on to your computer from then on.
Type in a password then confirm it. Click the "Create Password" button then close the Password window.
Click OK in the Properties dialog box.
Now anyone else logged on to your computer can't access that file without knowing your password.
Method 2:- If the Folder is Zipped you can give it a unique password.
Just double-click the zipped folder. In the top menu select File then click "Add a Password".
Type a password into the Password box. Then again in the "Confirm Password" box.
Now, you are the only person who can access files in this folder. The folder can be opened allowing the files to be seen, but you are the only one who can access them.
on Jan 23, 2010 | Computers & Internet
How can I password protect folders / files on my sandisk cruzer glide 128gb
Use the software that came installed on the drive. Use it to secure the whole disk. To access it you need to enter a password. Be careful though. The drive may not be accessible on Linux or Mac.
Mar 04, 2013 | SanDisk Cruzer Glide 128GB USB 2.0 USB...
CSSM ERRCODE MEMORY ERROR
If your computer is windows 7 systerm,I will tell you some advise for you:
Many people have this dilemma when using Windows 7 system. A strong and unique password is essential to protect our system, but you tend to forget Windows 7 password. What to do if we are locked out of computer? The following will tell you how to reset Windows 7 password efficiently.
Trick 1: Using Windows 7 default Administrator account.
Trick 2: Using Windows Password Key to crack password.
Forgot Windows 7 password isn't a troublesome matter if you pick up a good way. The above two tricks will help you a lot. You also can log on the HP official website to find more information.
Jul 04, 2012 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Tip
Do you share a computer with other users and want some extra security on your folders? There are two ways to password protect a folder built into Windows XP (for other Windows flavors, there are some freeware/shareware programs out there).
#1: If you have a log in password for your account, this can be used to protect folders from other users. Your hard drive must be formatted using NTFS (which it probably is unless you're dual booting with another operating system). Here's what to do...
#2: If the Folder is Zipped you can give it a unique password.
on Dec 14, 2009 | Computers & Internet
I creted a folder and put private things in the folder and i want to try and crete a password to the folder so that im the only 1 that can get in the folder
Hey, I'm going to assume you are running Windows, so let me provide an easier solution rather than creating a password for a folder.
Instead, you can create a ZIP file which contains all the "private things" you want to store, then put a password on the zip file.
- Download WinZIP: http://www.winzip.com/downwz.htm
- Install it by double-clicking on the file you downloaded
- Next, select all the private things you want to protect, right click on them and select "Add to Winzip".
- On the dialogue that will appear, you can add a password to your zip file, and then hit create.
That's it!
The file you created is called a "zip" file, and it contains all the private files you want to store. You can drag any new file you want to add on your zip file, and it will be added inside it (after you type your password). You can also take your zip file with you wherever you want!
It's a much easier solution that creating a password for a folder.
Alternatives:
7zip can also do this, and it's completely free, but a bit harder to use: http://www.7-zip.org/download.html
May 12, 2011 | Computers & Internet
How do I set the password for an individual folder; i.e., F1 I want to password proctect the folder as well as rename the folder.
http://www.addictivetips.com/windows-tips/how-to-lock-and-password-protect-folder-in-vista/
  • 1 Select the individual folder that you would like to password protect. If you will be protecting multiple folders, it is easiest to place all of these folders into one larger folder and simply add a password to that master folder.
    However, it is also possible to add passwords to folders at multiple levels within the folder arrangement. This is an excellent way to allow certain users access to some documents by giving them the password for the higher level files while making the master passwords for the interior folders available only to those who have access.
  • 2 Highlight the designated folder, and left click on it to open the drop-down menu. Select the "Folder Information" option, and open the Folder Information menu. This will give you access to the various preferences that are adjustable for each folder, such as color, icon and name.
  • 3 Click on "Password Protect," which may be on the main menu or on a "Settings" or "Security" tab. Apply a level of password protection that fits your needs. Set a password for the folder that will be easily remembered. Click "Apply" in the bottom right corner to make the changes permanent.
  • Mar 14, 2011 | QuickPAD IR Keyboard
    Exchange 2003 Encryption
    Microsoft Exchange Hosted Encryption provides policy-based encryption from sender to recipient with no end-user training or software installation.
    For Software solutions :
    MessageProtect can be used that secures Exchange, GroupWise and Notes messaging systems with strong email encryption and digital signatures. It is a flexible appliance that incorporates Public Key Infrastructure (PKI) and Tovaris Secure Tier Architecture to deliver secure email that is easy to administer and semi-transparent to users.
    Mar 12, 2009 | Microsoft Exchange Server 2003 Standard...
    Password on shared documents on a workgroup
    To password protect a folder built into Windows XP (for other Windows flavors, there are some freeware/shareware programs out there).
    If you have a log in password for your account, this can be used to protect folders from other users. If not, you need to creat one. Your hard drive must be formatted using NTFS (which it probably is unless you're dual booting with another operating system). Here's what to do...
    Dec 02, 2008 | Microsoft Windows XP Professional
    Microsoft Exchange Server 2003 Standard Edition for PC Logo
    50 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
