Question about Dishwashers
Hi, asko d3250 will fill and drain(when you press cancel) but the motor will not run. there is a light over the glass icon button that blinks when the motor will not run. what do you think the problem is? motor? circuit board?
  • mann520 Jun 17, 2009
    do you think the selector switch would be bad before the motor itself?
    Genius:
  • 1,847 Answers
This can happen because of multipal reason...
The door switch is bad.
Dishwasher's cycle selector switch has become defective.
Just go through this link ...
http://www.partselect.com/repair.aspx?appliance=dishwasher&part=dishwasher-wont-work
http://www.repairclinic.com/0088_9_1.asp#Level1_1
Let me know if you need further assistance
Thanks
K
Posted on Jun 17, 2009
  • Legin Varghese
    Legin Varghese Jun 17, 2009
    Yes if the selector switch in bad the motor will not function.
    K
Asko d3250 pump runs continuously
I have a D3450 that was doing the same. Eventually I ascertained that there was a pressure switch that was not functioning properly. On the D3250 it was only accessible from the rear after taking off the lower panel on the back. It was a black part with a red membrane of sorts. I just disconnected its wire connector instead of replacing the part as it was rather expensive. I've been running mine machine at least 2x day for months since with no problems. Good luck! e53c3564-9255-4057-93f1-a616c7ab21ca.jpg
May 27, 2014 | Asko 24 in. D3250 Built-in Dishwasher
The basket at the bottom of the dishwasher has water in it, is this a plumbing problem?
as the dishwasher ages and broken glass, coins, ect get in the bottom the impeller that drains the water out gets worn and doesn't work as well. The other cause could be that the drain hoes is partially clogged.
Feb 02, 2010 | Asko 24 in. D3250 Built-in Dishwasher
Our Asko D3250 dishwasher is brand new, and it fills up and drains and fills again and then the water inlet fault flashes. It doesn't go past this point.
this sounds like a improper install ! ck to see if the drain hose outlet is lower than bottm of tank. it should drain to the disposal . and have a drain loop under sink .. the dw prosser is sensing that the drain is longer in time so it flasher inlet fault . . elevate the drain and try again ..if it drains to a lower use a stand pipe or a siphon brake . in the install .. mm
Dec 03, 2009 | Asko 24 in. D3250 Built-in Dishwasher
Asko D3250 not working
If the first start button is blinking then there is a door error...the door switch is not closing... to repair
1) turn off the power at the breaker...
2 ) remove screws in the door T20
3) remove contol panel (slide up)
4) place wire tie behind micro switch on door latch...
5) replace door latch and door.
Hope it helps....If NOT let me know more about your problem ... I will Help
Nov 25, 2008 | Asko 24 in. D3250 Built-in Dishwasher
ASKO D3250 Does not run
HI thanks for your question. the problem is with the water pump. its electric, so some of the food got caught in the pump. clean out the pump. thanks, the appliance doc. please rate my answer. thanks.
Oct 09, 2008 | Asko W6661 Front Load Washer
Asko D3250 Bottom arm not moving
Check that the diverter motor above the wash motor is working and that you havent selected upper basket wash only,could still be a blockage in the lwr arm assy
Nov 17, 2007 | Asko 24 in. D3250 Built-in Dishwasher
D3250 drain blocked error
usually these are blocked at the discharge end under the sink, especially if the hose is hooked to a copper pipe then shoved down the plumbing standpipe. It could also be in the hose behind the dishwasher if someone has fitted an extension onto the hose and used a small diameter coupler. Run the dishwasher on any cycle...if there is standing water you should hear the drain pump run first...if there is no standing water run it on a rinse and hold cycle. at the end of the cycle the pump will run. if you hear the pump, but no water is ejected out the drain hose under the sink, then you most likely have a clog in the hose near the end or in the middle if it has an extensio. if you dont hear the pump run, then its a bad pump and you need a new one (parts like that are covered for 5 years if you use an ASKO servicer) Good luck!
Nov 03, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Bosch Dishwasher won't drain, cancel drain lights blink
when you said "I can run a wash", does the machine act normal for that time frame up to the point of drain? if yes, the pump is fine. sounds more like the micro chip on the board is "confused", but not sure why.
Jun 04, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Overfill protection tripping
Is there water in the drip pan? My asko developed a leaky inlet solenoid, which would fill the drip pan eventually causing a failure. If the water evaporated, the washer would run. Normally, there should be no water in the drip pan.
May 01, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Dishwashers Logo
51 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
