Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
MY WASHER MACHINE IS NOT DRAINING OUT AFTER THE CLOTHES WASH IT COMES TO A STOP
  • 6,784 Answers
HI. in most cases, this will be a clog or fouled pump. i recommend inspecting the following areas to combat this issue.
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Posted on Jun 17, 2009
My Tromm washer is leaving residue on my clothes
Make sure you are using the correct soap. (Front load soap powder) Also use a bit less than suggested on the packet. If you are often using cold or low temp wash cycles, dirt and build-up in the machine will be common and come off on your clothes. Use a very hot wash at least once a month to clean it out and stop using fabric softener. It sticks to everything and any dirt in the water gets stuck on and then comes off in later wash cycles.
Sep 25, 2014 | LG WM2688HWM TROMM SteamWasher
Washing machine wont complete drainage at end of wash cycle
Look under the washer tub where the drain hose comes out and attaches to the pump. Your pump impeller is either clogged or worn out. Try removing the pump and checking from there.
Jan 07, 2008 | Fisher Paykel EcoSmart GWL15
Washer or dryer is putting holes in my clothes
Try putting less clothes in on a wash. The main problem is caused due to draining. My brother had this problem. Try stop your washing machine before draining and hand drain them over the sink. Best advice I can give on that one sorry
Jun 01, 2013 | Washing Machines
This was will go through the whole wash cycle until it come to spin the clothes out then it will just stop it will not ring the close out. What can be the problem?? Please help me so that I don't have to...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 30, 2010 | Maytag Legacy MAV208DAWW Top Load Washer
Will not spin clothes
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 20, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Fridgidaire front end washer
ok first of all, you should be using HE detergents, it uses less suds, regular detergent will slow your water from draining properly out of your washer. Another thing it is recommended that after you wash a load you dryer rubber gasket or leave door crack to dry out..
Sep 23, 2009 | Frigidaire GLTF2940ES Front Load Washer
The machine fills and drains on wash cycle but willnot spin
C1. Your motor was stopped due to overloading, inbuilt device, reduce weight of clothes (put less clothes). Press 'stop' & 'cancel' to clear the display.
How abt a good rating? Thanks
Mar 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag neptune washer
Doesn't your unit have a lock light in addition to an on light? On mine when you start the machine a red light comes on, then after a minute or two the lock light above it comes on. Once the lock light lights, the machine shouldn't stop. If only the initial light comes on, the door isn't locking. As a result, as the drum moves the clothes and they push against the unlocked door, it turns the machine off. You might need to check/tighten the door latch. Also check the door wax motor/door lock assembly.
Dec 10, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Washer will not spin out after wash
Is the water draining out of the machine? Is the drip dry option selected? If the water is not draining out, check drain hose and drain pump. Is the lid switch operating?
Oct 31, 2007 | GE WBSR3140DW Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
96 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
