Question about HP Color LaserJet 8550dn Printer
My LaserJet 8550dn won't print
I just purchased a 2nd had LaserJet 8550dn - it will print from commands on its demonstration window but won't respond to my computer.  My computer has installed it - just no printing
  • 31 Answers
Re: My LaserJet 8550dn won't print
Did you download the print drvers for the printer. the printer is not a plug & print . you have to download drivers. if you do not have the disc you can go to to get them. make sure that you download the postscript drivers it will alow you to print any font plus extras. hope this helps.
Posted on Nov 02, 2007
0 characters
3 Points
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
HP 8550dn printing to light
change the toner density settings
Aug 13, 2012 | HP Color LaserJet 8550dn Printer
When i give a print command this error apears on the paper : pcl xl error subsystem:kernel error:illegaltag operator:0xfe
1st: turn off your printer, wait 5 minutes, turn on again. Try to print again and see if the problem is solved. If this doesn't work:
2nd: de-install your printer from your computer, download the latest driver for your operating system, install your printer again. And if this doesn't work, download the latest HP Laserjet generic driver and install it again.
You can find the drivers on the support page from HP, searching for the model printer that you have and select the driver for your operating system (windows xp, vista, 7..)
Aug 07, 2011 | HP LaserJet 1320n Printer
HP Laserjet 1320. Will not stop printing and not showing up in the Que. I have unplugged overnight, I have cancelled all jobs in the Que and will not stop printing. How do I cancel the job
Click on Start button
Click on Run
Type SERVICES.MSC and click ok
look for Print Spooler in the list
highlight Print Spooler,
Click on STOP button then click on START
close the window and check if the print queue is gone.
Alternate method,
Click RUN
Type CMD ( or COMMAND ) and hit enter
In the black window type
NET STOP SPOOLER ( hit enter button )
NET START SPOOLER ( hit enter button )
Repeat the Stop and START Command 4-5 times
End the Command with NET START SPOOLER
Open Printers and faxes folder - Refresh the Window - the printer will show Status ready with 0 document
Jul 07, 2010 | HP LaserJet 1320 Printer
8550dn printer showing out of memory message? Is there a way to clear this without having to do all the resets? Or just how to clear the message?
If the error is '20.00 Insufficient Memory'
No action required. It is simply out of memory because the file you printed was too big.
If you keep getting the message, simpify the print job and/or add more memory to the device.
You could also..
Change the setting in the <Configuration Menu>, <Clearable Warnings>, from 'On', to "Job'.
This will get rid of the message a bit quicker.
Dec 08, 2009 | HP Color LaserJet 8550dn Printer
Labels only jam when printing from file
I cannnnoooooottt believe what I am reading! If you are going to use labels on a laserjet, you need to get thermal labels! The other cheap labels are made for inkjets, matric, or daisywheel printers. The laserjets have heat rollers that will melt plastic. It will melt the gum on the non thermal labels and get them everywhere!!
Master Rod
May 08, 2009 | HP Color LaserJet 8550dn Printer
"out of memory" message on a HP color laserjet 8550DN
Did you use GENUINE HP memory sticks?
It sounds like the memory is not compatible.
Scroll through the menus and select reset printer.
Feb 19, 2009 | HP Color LaserJet 8550dn Printer
Print to card
Use straight paper path ie tray 1 as input, face up tray (sticks out on leftof printer) as output.
Set card as media type when in printer options window.
Some card is not good to print on.
Sep 05, 2008 | HP Color LaserJet 8550dn Printer
How to clean a density sensor unit on a hp color laserjet 8550
1 Open the right upper door.
Sensor is located on the door lower center of door ther should be a small brush next to it
2 Use the brush located next to the sensor to remove all toner
particles from the sensor.
Jun 06, 2008 | HP Color LaserJet 8550dn Printer
HP Color LaserJet 8550dn Printer Logo
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
