Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
I have a 5 year old Whirlpool Refridgerator (top freezer). The compressor has stopped working, can I get a compressor for it or should I buy a new fridge?
  • 159 Answers
Change the thermostat first and see if still not working then jou can get a another motor
Posted on Jun 17, 2009
Freezer and refridgerator stopped getting cold but is still running.
Honestly, if the unit is over 10 years old, buy new to pay for itself in energy savings. Usually the thermostat is the first problem. Thw second is the compressor. The compressor usually takes months to show signs of weakness, but the thermostat is more sensitive, and will go belly up first.
Jun 01, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Does not cool
it depends on the overall condition but it may be the relay on the compressor. may want to call a tech in youre area haundi24
Oct 27, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaks on to the floor from our whirlpool fridge
normally the pipe that drains the water on top of the compressor is a bucket that catch the water the pipe blocks sometime then needs to be opened again with a piece of wire
normally sits in the refridgerator compartement under neath the cooling plate
Oct 23, 2009 | Whirlpool Refrigerators
11 years old. Just stop cooling both freezer and
hello mam
the compressor of your refrigerator is out of service and should be recharged by the refrigrant so to do this work please call the engineer and check the work to be perfect and if he dont do it you should buy a new one.
Sep 27, 2009 | Refrigerators
Refridgerator is not blowing out cold air.
Inside the fresh food compartment behind the control panel there is a defrost timer. There also should be a small opening to turn the timer clockwise slowly until you hear refrigerator compressor stop running. The timer if working properly should return the refrigerator to operating after about 20 minutes. If not I believe the timer may be defective and need be replaced. Try this first and let me know, Thanks, Sea breeze
Mar 26, 2009 | Roper RT14DKX Top Freezer Refrigerator
Whirlpool Top-Mount Refrigerator Freezer warm, cracking noise
8yr old? Buy a new one. The cracking sound is from expansion and contraction of the cabinet and ice cooling or defrosting. It can be as simple as a bit of a top up of refrigerant, but can also be that your compressor has worn down the valve plates and therefore is not producing sufficient pressure throught the system.
Mar 06, 2009 | Whirlpool ET1FTTXK Top Freezer...
Water drains from freezer compartment into refridgerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 09, 2009 | Refrigerators
Whirlpoor Refridgerator 10-12 yrs old
I had a whirlpool fridge that did the exact same thing. Sometimes it was loud enough to wake me up at night! It is the compressor shutting down. I had it for several years untill I purchased a larger one, and then gave it to a girlfriend at least a year ago. Its still working good today. So if you can tollerate it, just live with it. Otherwise change the compressor.
Jan 04, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
99 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
