Question about Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
What is normal running on/off time?
Refrig runs 11 mins, off 26 mins.Keeps everything cold. Maybe because it's older & louder I hear it running more! Settings are factory recommended. I vacuum back, keep drain open, and keep door seals clean. Thanks! JIM
  • 3,267 Answers
Fridge is perfectly OK. The on-off cycle depends on the physical load i.e. how much the fridge is stocked up with. A little heavy load would explain the cycle of on-off. Its normal and no need to do anything other than what u generally do, as mentioned, so carry on ......sodeep
Posted on Jun 17, 2009
The refrig has stinky smell after not opening it for two weeks without any spoiled food.
Is it a moldy odor or rotten food odor?
I suggest cleaning interior and then spraying with odor remover like: Nok Out Odor Eliminator and Sanitizer
Mar 20, 2016 | Refrigerators
How do I determine and fix what is wrong with 2008 model whirlpool frig that the freezer I noticed first all food unfrozen then a couple days later refrigerator not cooling can hear running but contin
I ned more information to answer your question. What model do you have? This is very important to give you the correct information you seek. Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Sep 16, 2014 | Whirlpool Refrigerators
Chevy Malibu Cold Idle Problem
Check the water coolant thermostat. If it is stuck in the "open" position you are heating up all the water in the coolant system and this will take time. The thermostat keeps the water in the engine until warmed up to almost normal running temperature, only then does it allow the coolant to enter the radiator.
Apr 05, 2017 | 2003 Chevrolet Malibu
Refrig is running louder than before
panie Wieczorek prosze sie ze mna zkontaktowac sprobuje panu pomoc moj email:
tedsan2@yahoo.ca
Jan 26, 2012 | Whirlpool GS6NHAXV Side by Side...
I got a single phase capacitor motor is is 22-11 amps it keeps triping my bracker one to two min of running now my bracker is fifteen amp do i need to get a higher amp bracker?
You need to determine the following: what else is on that circuit? You might have a 15 am circuit but you need to calculate what else is running. Please clarify... is it 22 amps at 120 volt and 11 amps at 220 volt? The motor will draw more amps when starting and reduce while it is running. Do not just toss in a larger breaker, that cold potentially lead to a fire or damage to your equipment.
Aug 25, 2011 | HP Color LaserJet 2600n Printer
Ice cubes & frozen food thawed out, food in refrig not cold. Compressor runs for 20-25 second and clicks off, after 1-2 min comes back on. The a/c amps reads 8.5 wht wire and 9.5 on red wire to the...
You are cycling on the compressor overload, meaning the compressor is drawing excessive amperage, the overload takes it out then it cools down and tries again. the normal amp draw for those compressors is 3-4 amps. Have you checked the condenser fan and made sure the coil is clean?
unfortunately those compressors cannot be serviced
Jun 27, 2011 | Kenmore Side by Side Refrigerator
My refrigerator is always running- could it be because of dirty coils?
Greetings,
Yes, its possible, but self defrosting refrigerators do run alot. This is because of the defrost system putting heat back into the refrig to defrost the evaporator...then it has to pulll the heat back out of refrig, and, this is why it runs longer than normal...One way to tell if its running to long..does anything freeze in the fresh food section? if so, maybe the cold control is bad or set to high....
Jan 17, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrig is running, but freezer defrosted and food side seems to be getting warm. Always blew warm air from bottom front, now just cold air.
Sounds like the compressor is not running. Try unplugging for 15 min. to allow compressor to reset. If you hear a clicking noise you may have a bad main board.
Feb 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My side by side refrig. keeps freezing everything. It is turned lowest setting. Model GLRS2677AW6
Hi, this problem is going to be with the running thermostat2.gif (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge2.gif to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 09, 2009 | Frigidaire Refrigerators
WHIRLPOOL NO-FROST REFRIG/FREEZR MODEL-EHT201ZKWR5
looks like operating normally...
the fridge as it reaches it's temperature shuts the compressor off and then after a few minutes..the fridge would increase temperature again and would turn back the compressor again.
its the thermostat which is cutting on and off the compressor.
and i think it is normal. based on the temperatures that you indicated..it is cooling very well..0 F in the freezer and 40 in the refrigerator... that's good.
drcool
Nov 06, 2008 | Whirlpool Refrigerators
Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker Logo
159 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
