Question about Reliance & 40 Gal Mobile Home Water Heater
No stop tap. cold water coming through cold taps in caravan but no hot water the carver cascade water heater is getting the water hot but it just wont come through the taps in the shower room or kitchen in the caravan we have changed the return valve and it ia still the same
  • 332 Answers
Your pipes are clogged, what if you were to not turn on the cold and turn on the hot does any water come out at all, with just the hot side turned on,, if not there could be a valve that has been turned off, or the pipes are clogged
Posted on Jun 24, 2009
Why no water will come out of the water heater
Is there a shutoff on the hot water line coming out of the tank? Is this problem only at one tap or all of the taps in the house? Is the cold water supply to the tank turned off? If it is no water will flow since the cold water pressure pushes the hot out of the tank.
Aug 29, 2014 | Water Heaters
Low pressure coming from Hot Water Tap
Were is the water boiler located.
Feb 20, 2014 | Water Heaters
Noisy water pipes when neighbours use water
Install air chamber to cushion sudden-stop of flowing water.
Water flow coming to sudden stop is called water hammer, and will bang pipes, but also loosen plumbing joints, causing leaks.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#bang
http://waterheatertimer.org/images/Flow-rates-water-hammer-600.jpg
Air chamber has to be vertical, and about 18" long, with cap on top.
By code each Hot and Cold line at each tap will have air chamber located behind the wall. So there are two air chambers at each tap.
In your case, you can probably add air chamber to your Hot and Cold lines and solve problem for both dwellings.
Water hammer is caused because water does not compress like air.
So when long column of water suddenly stops... the whole pipe-full of water comes to sudden halt... and that water could weigh 1-1/2 pounds ... and just like a hammer head moving, the weight of water bangs the pipes to dissipate energy, causing noise.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 21, 2013 | Water Heaters
I have to turn the hot water tap on full open to get hot water
Type of water heater is unknown
If you have single-handled faucet the faucet cartridge might be bad.
If you have recirculation system, then check valve might be bad.
Copy following links for troubleshoot.
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Jul 16, 2012 | Water Heaters
Our atwood heater is firing up ok and running for a good while then turning itself off but we dont get any hot water out of the hot taps. Our water pump is working ok but we have this funny tap within the...
Cold goes in bottom fitting of water heater, so that valve has to be open, and hot comes out the top, so that has to be open, if there is one there, but any valve in between needs to be closed. There are a few variations so if you can explain where your valves are located in the system more precisely, I can help better. Perhaps you can send a digital picture with reply?
Nov 11, 2010 | RTO Atwood Water Heater - 6 Gal LP
No water pressure
Check all valves are open, cold in bottom, pushes hot out top, and if cold at tap is doing same, take aerator off tap and see what happens. Is same thing happening at all taps?
Apr 25, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Carver cascade 2 No water at all comes out of the hot water outlet. The inlet non return valve has been changed & is working correctly.
Check the tank drain valve for water there.If you get a good water flow there you know the tank is getting water pressure.Check the first outlet downline from WH and if there is no water there you have a blockage or other problem.If you have to turn off water to tank, remove the outlet pipe ,and check for water flow from tank with in valve on.If no flow, tank is plugged up.
Hope this gets you going.
Oct 06, 2009 | Reliance & 40 Gal Mobile Home Water Heater...
No water coming out of carver cascade water heater
is the cold side hooked to the cold side if not you will be feeding the unit backwars making it to where the cold is just comming across the top of the tank, check the dip tube also, this makes the cold water go to the bottom and push the hot out of its outlet,, how many faucets are involved, if just one might want to check the cartridge to make sure it is working properly
Jun 16, 2009 | Reliance & 40 Gal Mobile Home Water Heater...
Water pump does not work when i turn on hot water tap
Since the cold water works, the problem is not the pump. Look for a blockage or possibly a major leak in the hot water system. if you have a kitchen sink and bathroom sink, are both hot water outlets not working? Does the water heater have shut off valve , or is its drain still open from when you winterized it (and the water running out to the ground instead of to the faucet?
Apr 22, 2009 | Water Heaters
Under sink water heater no flow of hot water from it
basically the principle of the heater is water flows into a internal tank and is heated by an element. You open a hot tap and the mains cold water forces the hot out and replaces it inside the heater.As you have a flow problem i can only suggest you may have some kind of restriction or blockage in the cold water supply at the water heater or from the hot supply from the heater.If you live in an area where lime content is high then this can calcify when heated.If you can, isolate the water supply and electrical supply and check the pipework for blockage.Also investigate your hot tap as this may be the fault. Good Luck
Mar 26, 2009 | Water Heaters
Reliance & 40 Gal Mobile Home Water Heater  Logo
544 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
Paul Nielson
Paul Nielson
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
