Question about Palm Treo 500 Centro
Hot sync problem
The hot sync on my phone popped up and i took the battery out for a few then i put it back in. the phone turns on but it keeps saying "connectin with the desktop using cradle/cable". nothing is plugged into my phone and it wont let me exit out of it or do anything on my phone!
My daughter got ahold of my phone and drooled on it. the hotsync was going crazy so my husband took some electronics cleaner and got what little corrosion was on there off and now it works fine!
Posted on Jun 18, 2009
Have 2 tough cameras new, no reciepts both daughters did not keep reciepts., both took camera in ocean, one does not turn on at all and other turns on for a few seconds,lens does not open, obvioously...
You can try wash again in pur ewater with out batteries and leave to dry in hot press or very warm area of house for a few days 5 days min. then put back battery and say a nice little prayer before you press the pwer button and who knows The Man above may answer your request.
Nov 30, 2009 | Olympus Mju Tough 8000 Compact Digital...
My cingular palm centro wont stop hot sync
I had the same problem with my phone a few months back. I took the battery and sim card out of my phone for a few days and then put them back in and it worked. I still have problems with my phone but not with the hotsync feature.
Oct 25, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Virgin mobile Shuttle keeps turning off and on!
i took the battery out of the cell phone and every five seconds it keeps turning off,then back on..how do i make it stop, and how can i make it stay on?
Sep 29, 2009 | Cell Phones
I changed sim card, now they both display ''Insert SIM''
try taking out both cards and popping the battery on the phone.
Wait a few minutes and then turn the phone on with no card in it.
Turn it back off when it says no card found and insert the newer card and power it back up.
It seemed to keep a memory of the blank card.
Jul 23, 2009 | Samsung Cell Phones
My Centro started hot syncing itself.
try this: take the battery out, then hold down the red power button...keep holding it until you put the battery back in and your screen comes on. Hope this helps, it worked for my daughter's!
Jul 21, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
My palm centro began hot syncing by itself and I could not cancel it. It coming back. I took the battery out and waited a few minutes. Now it does not turn on at all and the red light stays on.
The problem is from the connectors on the bottom getting wet, slightly moist, oily from your hands touching it or just plain dirty. This sends an incorrect signal to the phone that makes it think the cable is attached and requesting what ever action is initiated by pressing the button on the cable, which is set by default to initiate hot-sync.
Two things can make this problem bearable or even resolve it:
Clean the bottom connectors to resolve the incorrect request for action being sent and/or reprogram that cable button action to do something different, like go to the phone's home screen instead of initiating hot-sync.
I take a packaged alcohol pad like they use at the doctors office (not a cotton ball, the fibers get stuck in the grooves and deposit too much alcohol in the phone) and wipe the bottom connectors down really, really well. then let dry. two or three times of doing this _always_ fixes the problem for me. I let a lot of alcohol get in there but the pads don't contain all that much extra which is why you should use the pads to keep from damaging you phone! (they are cheap at wal-mart.)
In the meantime, reprogram what the phone does when it receives (or thinks its receiving) a signal from the cable button press. On the centro, go to Preferences --> Buttons --> HotSync, then set the app you want to activate. I use "phone" so when the problem reoccurs, my phone keeps sending itself to the keypad, not the long long process of activating and canceling hot synch.
You will have to manually launch the HotSych application from the home screen when you synch if you keep that button the same or you can just change it back to the default when resolved.
Hope that helps!
Toni
Jan 12, 2009 | Palm Treo 500 Centro
My palm 755 wont hot sync
Restart your Palm Treo 744p. Take out the battery from the phone for more than 3 min and put it back in. Switch on the phone and then try to Hot sync Again. Hopefully it will work. I am assuming that you installed the Palm Desktop software came with the phone on your computer
I have same problem once in a while when i try to hotsync with new comp and this trick always worked for me.
Nov 17, 2008 | Palm Treo 755p Smartphone
Samsung Juke not able to put music in!! Need help!!
I had the same problem. I just called Verizon & they had me take the battery out of my phone & then put it back in, the music is working again. I'd say try that & if it doesn't work, call them & they'll help you out! Good luck!
Oct 26, 2008 | Samsung SCH-U470 Juke Cellular Phone
Sidekick 3
you should probably remove the back cover take out the battery and sim and then blow everything and put it back in
Mar 14, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Phone won't start
Did you turn the phone off before removing the battery? I sure hope so. If not, you may have to junk it. My father has done that to several phones now. He pops the battery out to put the charged on in, but forgot to turn the phone off. I just recently bought him a phone that sets itself to power off when the battery cover is popped off.
Dec 23, 2007 | Motorola Mobility RAZR V3xx Cellular Phone
Palm Treo 500 Centro Logo
186 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
