Question about Toshiba Satellite M45-S169 Notebook
10 key pad within the alpha keyboard
How do I use the 10 key pad within the alpha keyboard on my Toshiba Satellite M45?
    Scholar:
  • 181 Answers
Utilize the numLK button located in the upper right area of the keyboard. Depending on the layout, you may need to press it in conjunction with the Fn or Shift key.
Good luck.
Nice laptop
Posted on Nov 02, 2007
In my laptop keyboard some keys are not working
Hello Mohammed,
The keys you are mentioning is not working then they are internally damaged. You have to replace the keyboard with new keyboard. Meanwhile you can use the external usb key board or the onscreen keyboard from the Accessibility option or Ease of access from, the accessories.
Dec 15, 2011 | Toshiba Satellite M45-S331 Notebook
My toshiba satellite m45-s355 seems to be coughing up a weird problem.Whenever i press the shift key these characters - "NB~A" props up and the whole system goes awry.I can figure out that it's a...
like other prblem on keyboard it seems your fn key was stuck, it can caused the keyboard was dirty, just open the keyboard then remove all the key on your keyboard then clean it using alcohol wait until dry then set the key again
Jan 14, 2011 | Toshiba Satellite M45-S355 (PSM40U073001)...
My dog walked over my keyboard and now my touch pad cursor will not work. How do i fix it?
Sounds terminal, dog may have damaged touch pad, have to replace top pad assembly = costly, double check with your local repairer as it is hard to judge without seeing the pad.
Nov 02, 2010 | Toshiba Satellite M45-S265 Notebook
How to remove Keyboard from Toshiba Satellite M45 latop.
Before you open the laptop case, remove the battery. The keyboard securing strip doesn’t have any securing screws and shouldn’t cause any problem when you remove it. The keyboard cable connector on the system board is cover by a metal plate and the plate has to be removed before you can get an access to the connector. Before you pull the keyboard cable from the connector you have to unlock it. To open the connector, move the connector lock toward the LCD screen. It is enough to move it 2-3mm to open the connector. Be careful with the keyboard connector on the system board. If you damage it, the entire system board has to be replaced.
Hope this helps
Jun 10, 2009 | Toshiba Satellite M45-S331 Notebook
Toshiba Satellite: Keyboard quits working after a while
How about replacing the keyboard? Perhaps, something was spilled on the keyboard in the past.
May 07, 2009 | Toshiba Satellite M45-S265 Notebook
Programming buttons for player and explorer on the satelite keybo
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=Satellite+M45-S2653&x=0&y=0
There you go
Apr 15, 2009 | Toshiba Satellite M45-S2653...
How to turn on the 10-key number pad
does the keys 7-0, u-p, j-;, and m-/ is working under MS-Dos command or not? If not the problem could be the carbon of you keyboard is worn-out, you have to cut the carbon of your keyboard that has connected on the motherboard, but before you cut take off the plastic of the caron atleast 1/2 inc. and cut the old carbon. Make sure that you turn off your power before you do anything. If still the same problem it means that some carbon inside of the keyboard is already worn-out, you have to replace the whole keyboard. Remember if some keys are not working this is hardware related not software nor setting.
Jan 31, 2009 | Toshiba Satellite M45-S265 Notebook
Toshiba Satellite M45-S351 BIOS password needs help!
BIOS passwords on Toshiba notebooks have to be reset by an authorized service technician who has the CD available to run the utility.  Their notebooks don't contain a battery reset to erase the password.  It was done as a safety feature to prevent theft from happening and it is a very good one.
If you take it into Best Buy or a computer dealer to get it done, you might have to prove that you are the new owner of the computer before it can happen.
Sep 23, 2008 | Toshiba Satellite M45-S351 Notebook
Keyboard
Hi this Tony my lap top toshiba M45-s265 is making crazy things,when I prees shift key ,everthing changes .the letter go to caps lock size and the numbers changes to works only the symbols, and when this happens also ,if you go to select any folder in my documents on windows you chooice one folder ,with mouse and set all the folders ,what could be happens
Mar 28, 2008 | Toshiba Satellite M45-S265 Notebook
Toshiba Satellite M45-S169 Notebook Logo
105 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
