Endless Summer 2009 Open Flame Patio Heater
Problem for Endless Summer 2009 Open Flame Patio Heater
Pilot lights but main burner won't
By jlefebvre on Nov 01, 2007
I can push in the control knob and push the pilot and i get it to light. but even when i hold in the control knob in for over a minute, once it's released the pilot goes out and i can't get the main burner to ignite.
thoughts?
thanks, jeff
jlefebvre@prisim.com
Same Problem
Feb 29, 2008
-   We just bought model PHS patio heater. We can push in the control knob and the pilot light will ignite, but as soon as we release the knob it goes out and the main heater will not light. we have checked the connections and they all seem tight... very frustrated.-   mama pink
Best Solution
posted on Nov 01, 2007
Helpful)
eagle338
Rank: Wiz
Rating: 84%, 1602 votes
There seems to be a problem with the inflow of gas into the burner..Check the connection for any blocks, loose contacts etc.,
Comments:
Nov 01, 2007
- Analyze this ok..It is putting off becoz when you stop pressing the knob the gas supply is being cut..It is clearly a problem with the knob..try replacing it..Its gotta work..
Was this helpful?
Yes
No
Solution #2
posted on Aug 21, 2008
Very Helpful)
michael272
Rank: Apprentice
Rating: 100%, 1 votes
sometime if the heater has been sitting for days spiders get into the burner area or the area between the tank and the burner and make a web blocking the flow. I have taken a compressed air in a can like the ones you use for computers laptops and blow air up the shaft and around the burner wait 2 minutes then try again. Sometimes it takes 2 or 3 blowouts to work.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Sep 12, 2009
Somewhat Helpful)
bn973
Rank: Apprentice
Rating: 75%, 1 votes
brand new unit doing same thing out of the box. I believe its the thermcouple safety sensor is bad. Left message for the company. bought at costco may just have to haul it back to them let them deal with it. Good luck all - seems to be a common problem - the h/w store guys knew what it was right away.
Was this helpful?
Yes
No
Popular Solutions for Endless Summer 2009 Open Flame
Questions and Unsolved Problems for Endless Summer 2009 Open Flame
Do you recommend Endless Summer 2009 Open Flame Patio Heater?
Answer
Answer
Have Endless Summer patio heater. I got the burner to run but after 3-5 minutes the heater shuts... (More)
Answer
We turn on the propane, gas doesn't seem to be moving. We can't hear any gas moving, the pilot... (More)
Answer
the longer the time between uses the harder it is to light last time took me 3hrs this time ive been... (More)
Answer
We have not been able to use our outdoor heater for a couple of years. I took the cover off and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Endless Summer 2009 Open Flame...:
Top Heater Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Heater Experts
Top Heater Repair
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
