Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Ice maker does not dispence Ice.
Motor does not even try. When you push the lever to disense ice....NOTHING. I have tried defrosting and making sure there is no ice built up on it. This is less than a year old. Please help.
Does the water dispense? A lot of side by sides require the door switch to be closed completly before any of the freezer door functions will work. Try making sure the door switch is closed.
Posted on Jun 27, 2009
Not dispencing ice
YOU WILL NEED TO CHECK FIRST FOR WATER IN THE MOLD OF ICE MAKER(WHERE CUBES ARE MADE). THEN MAKE SURE THE LEVER THAT TELLS WHE THE ICE MAKER IS IN THE DOWN POSITION
Jul 08, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
FRS6LF7JMO Ice maker making ice. But will not dispense ice . have cleaned out ice container. Nothing jamed in auger. All back in push in lever to dispence ice not even a noise nothing.
It sounds like the motor that turns the auger is either disconnected or fried, it might also be binded elsewhere, but you should at least hear some humming if the motor is getting current. If you can figure out where the motor is connected you can test the windings for a short with a multimeter (set to resistance and a reading of zero means good, infinity means its shot).
Let me know if you need any more help
Jun 07, 2011 | Frigidaire Refrigerators
Have my ice maker set to cubes, only dispenses crushed, and now "nothing"
remove the ice bin then hold it over the sink and lift the small arm located on the back of the dispenser if it opens and cubes fall out this is good.
the next thing to look at open the door and look at the auger motor case and you will see a small hole in the back with a square plastic actuator make sure this is down.then hold the door switch and have some one try and dispence ice the piece of square plastic should move up if it does not the it needs to be replaced.
if it moves up just make sure the metal arm on the back of the dispencer bin is properly inserted in the plastic actuator.
Jan 24, 2010 | Frigidaire GLRS264ZA Side by Side...
Ice Dispencer is not releasing ice (cubed or crushed)
I would remove the ice bucket in the freezer and make sure that nothing has gotten between the motor and the auger that pushes the ice forward.
Jul 09, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker and water dispencer
Check the water inlet located at the back of the fridge.
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 21, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Ice maker
replace micro switch above the ice maker lever in the dispensor housing
Jan 22, 2009 | Amana ARS2464B Side by Side Refrigerator
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Problem with ice maker
Christy
Depends on the model. BI models or co29 the setting is warmer to make more ice.co2075 you have 2 tstats. So the icemaker control is seperate.What model do you have
Aug 11, 2008 | U-Line Refrigerator Ice Maker
GE 23.5 CU FT side by side w/ice maker and water in the door.
replace the dispenser control under the front panel on the freezer door if need detaild instuction after receiving parts reply to me
Jan 15, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
176 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
