Question about Hitachi Televison & Video
My tv bulb went out on my hitachi and i replaced it and now its still saying lamp on the tiv, the light keeps blinking
    Genius:
  • 1,030 Answers
In general after most lamps are replaced the customer needs to go in and reset the lamp timer depending on the set
Posted on Jun 17, 2009
Tv doesnt turn on and the lamp bulb is blinking
I recently replaced my lamp in my Hitachi 50VG825 TV and the red light was continually blinking for the lamp. The manual tells us to make sure that the lamp is screwed in tightly. I opened the covered and sure enough the screws needed to be tightened.
Try that and make sure you replace the tv cover. Hopefully this will work out for you like it did for me.
W.S.
Jan 23, 2011 | Hitachi 50VG825 TV
Tv turns on for a few seconds then the picture and sound turns off and the blue power light just blinks
It will do the same thing, until a repairman comes out, and services the TV set...
Symptom: No power / Dead Unit / Comes On and protects itself, Power LED may blink in 3 or 4 times cycles.
Cause: Check/Confirm SDR buffer ICs are not shorted, follow link to check. If so, replace affected SDR PWB.
That's what MY Hitachi service portal says...
Do you have one?
It's kinda like a crystal ball or magic carpet....not many people have one, but Hitachi techs do....
Eeenie Meenie Chili Beanie the spirits are about to speak
Nov 07, 2009 | Hitachi 51F59 51" HDTV Projection...
50v715 hitachi..the tv was on doing fine then it went off and the 2 red lights blink. What can i do to fix it?
If is the lamp and temp light on the front panel, then it could be that the bulb (lamp) needs to be replaced. Make sure you buy an original replacement lamp (phillips) they are supposed to last longer. There are also videos on you-tube that show you how to replace the lamp. Hopw this is helpful.
Nov 07, 2009 | Hitachi 50V715 50" Rear Projection...
Hitachi Its not powering on after bulb replacement lamp pilot light is just blinking
Please make sure that lamp box cover is placed back in its position after lamp replacement. If lamp cover is not fixed properly, TV wont turn on.
Thanks.
Sep 18, 2009 | Hitachi 62VS69 62" HDTV
Hitachi 50v500 tv lamp light blinking no picture
I have one of these units, if the light is blinking and no picture as you have stated then you will need to replace the bulb in the unit. it is contained in the front of the unit behind the front panel on the right, you would remove the front panel after unplugging the unit, remove the single screw and pull out the box. replace it and then reverse the proces. the bulbs can be obtained for about $130.00 to $200.00 depending on where you get it from. Shop around.
Feb 07, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
My tv wont come on.
you have to reset the lamp timer per the manufacturer's instructions. Reset procedure usually comes with the lamp.
Dec 01, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi #55VS69A
I had this same problem over the summer, I had my TV for two years before it went out. You need a new lamp. The lamp is not hard to replace on your own. However, you MUST make sure that you do not touch the lamp (the bulb part) in anyway. If you do your new lamp will not last as long. You can order the lamps online. They range anywhere from 150-300 dollars online. However, I found a TV repair company in my city that only charged me 100.00 for the lamp and they told me If I took out the box that holds the lamp they would replace the lamp for me. They also gave me a 1 yr warrantee on the lamp. All I had to do was un-screw the box from the back of the TV take the box to the TV repair company and I placed the box back into my TV. My TV works. While going through this process, I learned that these lamps go out all the time, the more you watch the TV the more often you'll replace the lamp. I was told from the repair company it could be as often as every year. The Lamp does have MURCURY in it so if you replace the lamp on your own be careful and have it recycled. If you live in SLC UT the repair company I went though was Village TV Sales and Service.
Jul 15, 2008 | Hitachi 55VS69 55" Projection HDTV
Hitachi VS810 Turns off by itself
the high voltage supply for the lamp may have blown.
cheap bulbs don't always have the correct rating.
made in china?
Feb 16, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Televison & Video Logo
80 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
