Question about Sony Xplod CD Player w/MP3 Playback CDX-GT50W
Sony explod,every thing works but the radio
Just hooked this up and every thing works but no reception..thought the antena and or cable might have been bad so i replaced both with new antena and cable..radio still wont work..
  • 58 Answers
MAKE SURE THE HOOK UP IS TIGHT IN THE BACK OF THE UNIT.
Posted on Jun 18, 2009
POOR RADIO RECEPTION 2006 TOYATA TACOMA
U need to make sure that the antena cable is conected at the back of the radio and not broken. If the problem persists take it to a specialist to work on the reception, its minor u wil b enjoying your reception now. Vote if it works. Good luck.
Jun 08, 2011 | Toyota Tacoma Cars & Trucks
Cannot get TV to work on antenna...In menu I set cable to off, then initiate autoprogram but tv says "no signal". My antenna has a bulit in digital to analog converter. Suggestions?
Must buy a Digital converter box and to install it seperatly to devert back to tv anlogue tv signal to make the tv to work.Tv antena inverter alone can't convert analogue signal to digital signal only can give basic tv antena for better antena reception.Tries websites like Ebay.com,Amazon.com to buy a stand alone digital converter box to install and that didigal antena install and auto scan again u should able to get all the free DTV air stations.
Feb 01, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I don't understand the manual! How do you get any channels tuned in on the Technika LCD19-910
on all tvs there is a menu pannel find the menu button on the remote or tv could also be called setup button look for channel option or antena cable option (no on most of the new tvs it is an auto scan) and select that option it will scan throught the channels and auto add the ones that get reception say if ur using an antena
if u are trying to hook up a cable box or sat box through the antena coail wire at the same time u can not have them on so to scan for antena channels turn off the sat recver and cable box scan for channels because the sat box and cable box destors the singnal when on the same time with the antena u will proble have to go back into the main menu where yu selected the channels and manualy add channel 3 or 4 which is what runs the sat/cable box if ur using the antena hookup on the tv
if u are hooking the sat/cable box or dvd player to red gren blue or yellow white red hook up's they will be under a diffrent source chanel which u can usaly get to by hitting the input or source button on the remote
Jan 15, 2011 | Televison & Video
The radio only plays the local station with a lot of static. this happened with the radio that was in the truck when i bought it. i checked the antena, changed the screw in part of the antena. i put in my...
There is interferance in th esytem that is causing this effect. If the noise is coming while in motion then the noise is induced from the electrics of the vehicle.
Check or add a 0.47mfd/100Volt capacitor which is a clip type to the power into the set. If not use a DC/DC isolator or even a inductance coil with a capacitor , one you can salvage from an old set.
Make sure the antennae is good and the local reception is strong.If not the static might dominate.
Sep 17, 2010 | Car Audio & Video
Power antena after markit how to make it work with radio
on the radio there is a cable that is for Power Antena you might have to set a cable out to the area you are instslling the antena if this car already had a power antena you only need to hook up the leds from the old if not then like i said you need to get positive cable out to the antena and ground it to chassis
Apr 01, 2010 | 2000 Mercury Sable
No audio from my radio, and the fm tuner scan will not stop on any station. i bought the car used and it had no radio. the seller of the radio says its good and tested.
if theres no audio then stereos broke or hooked up wrong . Scan not stopping at station would be bad reception (antena not hooked up right) Go to a car audio shop spend a hundred bucks or 2 and get a good stereo and let them hook it up for you for $20.
Oct 18, 2009 | 2000 Nissan Altima
Why does my radio get poor reception
The radio has a built in small power sourse to increse reception. A reception booster..
That power sourse may be failing..
Very common on the stock stereos..
In my opinion - it it worth wile to have a brand name stero installed.. It is not real expensive to do..
Note;
Thank you for posting your question on FixYa.com
We are helping people on a points system.
If the information provided here was at all helpful,
please be kind - rate well and close the post.
Thank you – and enjoy your day ;o)
Aug 01, 2009 | 1995 Lincoln Continental
1997 chevy silverado has crappy radio reception. How do I find out if it is the antena or the cable?
If you pull the radio carriage out you should see a cable plugged into the antena port of the radio. If this is plugged in check the cable up to the antena
May 05, 2009 | 1995-1997 Chevy 1500 Truck Ignition...
No reception on radio, all static exept for a few times and I can
Chk. for corrode antena cable that plugs into back of radio.
Feb 10, 2009 | 2002 Oldsmobile Aurora
Better fm reception
Is it just a single wire?
If so, purchase a cheap FM antena. It looks like a "T" when spread out (4' to 5'). That should help.
You can purchase an "amplified" antenna, but if your area reception is really bad (such as in a valley) the antenna would just amplify the noise as well. Look for web based radio in this case or if you have cable there are stations on it.
Jeff
Jan 11, 2008 | GPX HM3817DT Shelf System
Sony Xplod CD Player w/MP3 Playback CDX-GT50W Logo
283 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
