P910i switched off while charging. Cannot switch on again. Changed batteries. On charging red light burns for a while and then turns to green. Cellphone still does not want to switch on.
My P910i is not turning on, by mistake by an adaptor( with variable voltage) that I forget to switch it to 5v, instead it was supplying 7.2v. Is there anything that can be done to solve this matter.My P910i is not turning on, by mistake by an adaptor( with variable voltage) that I forget to switch it to 5v, instead it was supplying 7.2v. Is there anything that can be done to solve this matter.
You can't post conmments that contain an email address.
Red blinking light according to the manual means low battery. Charge it up and try again. If you have tried to charge it, you may need to replace the battery.
Try to switch it on connected to an AC charger, if it switches on , then it is a battery problem. If not, it may be the AC charger, or oxide in the charger contact.
I sugggest also going to a local phone repair shop, and eventually testing a different battery and a charger. If the battery works, replace it, if it is not the battery or the AC charger, then ask the fee for repair. Usually it is the charger or the battery.
At first one day I using my phone at battery low and after that I couldnt able to hear the rington. So I just switch my phone and keep charging. After 1-2 hours I switch it on but from there I coulnt able to switch it on. It use to blink till now.
battery.
When it is red light of death, it either means the bootloader of the phone is faulty (after uploading dodgy firmware updates), or the battery is too empty to start-up, let alone display charging progress. In your case you need to leave the phone charging even with the red light flashing and it will be fine. Give it a few hours connected to the charger.
