Question about Compaq Presario 5000 PC Desktop
Presario 6000 Desktop start-up
Small wire pops out of niche inside computer when "on" switch is pushed in, so nothing happens - no light, nothing. We've taped it in and, so far, it's working. Will getting a new internal "on" switch, if that is possible, just cause the same problem again down the road?
  • salina5 Jun 21, 2009
    I don't solder - I'm a widow in her 70's. Shall I just cart it off to a repair place? Or, since I will then get withdrawal symptoms if it's gone too long, shall I order the part from HP and take it in when I take in the computer?
    Thank you so much!
  • 42 Answers
If you can ... take the front panel off, be careful you don't pull out the wires and light there a bagger for that. When you get it out solder the line back to where it is stemming from. Dont tape it it makes a mess. Believe it or not use candle wax (melted of course) over the wire and reinstall it. Use a sufficient amt of was
Posted on Jun 17, 2009
How do I change the bulb in my spa
Remove front wood skirt panel. Follow the 2 wires - black & a white, Reach into the light area. Grab hold of the light bulb holder/retainer, which is called a reflector, and twist it off the light niche/lens. It's a 'dry' niche. Some very old spas had a wet niche and you need to access that from the inside of spa. But if you have that style, post back with new thread.
once out, twist the pigtail 1/4 turn to remove from reflector, and the bulb just pulls out of the pigtail socket. and new pushes/snaps back into place.
Reflector 1015 Series Light
and the bulb...
Spa Bulb 12V Replacement 2 Pack
May 04, 2015 | Pool & Spa
Describe your Compaq Presario SR2010NX PC Desktop Problem Had power outage and power company replaced the transformer in the neighbors yard. Next morning went to start computer and nothing happens. ...
Hi--This link will show you where your CMOS switch is on your board. (I used to have a sr2010nx). It is a jumper and not a button, but the instructions are clear as a bell. Just scroll down the page till you see "clearing the bios". Expand that section and it will show you the exact steps to take.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00757531#N452
Removing the battery and popping it back in will not hurt anything. You might test it too when you have it out.
Best wishes.
Aug 29, 2011 | HP Compaq Presario SR2010NX PC Desktop
The power button completely broke off my emachine T3090 desktop. How can I get computer to start-up without this button?
You should be able To just reach in there and press it anyways. It depends what emachines uses, but normally it is a little white plastic thing that the button pushes, because it does nothing itself.
*If this answer helped you, please rate it 4 thumbs up!*
May 15, 2011 | E-Machines eMachines Desktop PC
When i push the ignition switch, nothing happens,
Check to see if there is power going to the starter solenoid when you push the start button.You are going to need a small meter or a light probe.If there is power to the solenoid check to see if there is power going out to your starter.Check the smaller wires as well for feed from your start button.The fact that nothing happens gives me the "feeling" its the solenoid. Good luck
Nov 26, 2010 | 2007 Suzuki Boulevard
Compaq Presario sr1550nx wont power up. Green light on power supply is blinking. What is that telling me?
Basically, I think that your power supply has gone bad if nothing at all happens when you turn it on.
To test this, disconnect the hard drive, the CD, and any other peripheral and try to start it.
All this assumes that when you push the on/off button, all you hear is yourself breathing--nothing at all from the computer.
Oct 11, 2010 | HP Compaq Presario SR1550NX (PY059AA) PC...
S5100NX PC Desktop Problem When I push the power button it feel's soft. No response from the computer at all. Is it possible to replace this switch?
It's possible that the spring that makes the button "firm" may have popped out. Take off the front cover and look for it. It's easy to put back in. While you have the front cover off, push the little (usually black) start button to see if the computer starts.
If the switch is not repairable, your best bet is probably to find a Used Computer store/repair shop. They should only charge a nominal fee, if anything. Computer booths at flea markets are good places to look for stuff like that too.
Jan 02, 2010 | HP Compaq Presario S5100NX (DM172A#ABA) PC...
The machine will not start. I removed the covered and air sprayed inside. With the computer plugged in, there is a small green light on but when pushing the on/off buttome, it does not start. Is there a...
Looks as if the connector wire to the power switch in front has become loose or removed from the pin provided on the motherboard due to the air. Check any loose connections or loose wires inside the cabinet & secure them. That should solve the problem
May 04, 2009 | E-Machines eMachines Desktop PC
Dead compaq presario 6000
try a different power lead and if doesnt work it sounds like the power supply has blown, had it on a few pc's
Jan 13, 2009 | Compaq Presario 5000 PC Desktop
COMPAQ PRESARIO V-6000 LAPTOP WILL NOT TURN ON
try to start the computer and right after that press the delete key several times as it try's see if u can get into the system bios if so change everything to a default level make sure you pres the f10 to save all info and try to reboot if this doesnot work please let me know good luck
Jul 13, 2008 | Compaq Presario 5000 PC Desktop
Red light flashing on power button
Sounds like the hard drive has had a failure, you need to get a replacement one, and reinstall it, along with the opperating system, and any other programs that were on the old one.
Feb 14, 2008 | Compaq Presario 5000 PC Desktop
Compaq Presario 5000 PC Desktop Logo
87 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
