Question about GPX CDRW3500 CD Player
Can you help me find a schematic dtagram for GPX CDRW3500?
Especially the power supply section, there are burn out components that need replacements.
    President:
  • 1,734 Answers
Ask the schematic finding experts -
They will get it for you.
http://manualfox.com
Posted on Jun 30, 2009
Sound but no picture on my GPX 32" model # TDE3274BUP what can I do to fix this? Please and Thankyou!
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board....
Jan 04, 2017 | GPX Televison & Video
Gpx 32 inch led hdtv have sound no picture
Jun 09, 2016 | GPX Televison & Video
Sony TV has a power supply problem both ics irf1b7n50a in the power supply section are all shorting which number could I use as an equivalent. is there a way I could use a power modular with two power id's
Hi Saidi
Have you checked all the other components used in the main power supply regulator section circuit, before replacing a new STR? You should do it. There should be a reason for the failure to STR. You should find it, and rectify it, before replacing an other STR. Check all the small components, resistors, zener diodes, small value ceramic capacitors etc: Make sure all of it are OK. Especially give a keen attention to zener diodes used; if any. It will be best to replace these diodes, even if you do not find any fault with it with multimeter test.For more information go to http://electronicshelponline.blogspot.com/
Power supply schematics to some popular brand TVs are given. Pull up older posts. Good Luck.
Nov 26, 2013 | Televison & Video
In onida ky thunder strf6654 getting burn,fuse blown when also change of str.????
Check all the associated components at the power supply regulator section circuit; especially check the zener diode/s. Replace them. Replace the STR only after replacing these components. There is a chance to these components too can damage, when the original STR has burned out by any reason. If you wish to get more, about the schematic diagram; check the site linked here. Type in the number of STR in its search box, or Pull up previous posts, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option. http://electronicshelponline.blogspot.com/
Aug 06, 2013 | Televison & Video
Can we get parts for the gpx cdrw3500?
I think your only option is to send a Parts Inquiry to GPX directly (Link Below)
http://www.gpx.com/store/pg/78-gpx-Support.aspx
Please leave feedback
Cheers
Andy
Apr 27, 2011 | GPX CDRW3500 CD Player
Will not record but will play cd's
You don't say what the recorder does do when you try to record. Any messages?
One possibility - You have to use CD-Audio or CD-Music media for consumer CD recorders.There are probably a zillion logos plastered somewhere on the unit that say what media are compatible with it.
May 16, 2009 | GPX CDRW3500 CD Player
Busted component
Getting a schematic is rather doubtful. You might be able to get a general idea of the circuit from somewhere on the 'net.
Was the power supply dead?
ATX style power supplies have both a standby and main section. The standby supplies a low current +5 volts to a small portion of the motherboard.
If the component failure is in this section, this standby voltage will be missing or incorrect, and the computer will be dead- won't power on at all.
I've seen a number of catastrophic failures in this standby circuit, and repair isn't suggested or economically feasible, especially as some parts often poof beyond identification.
When the pwr button is pushed, the main section comes on, and supplies +5 (Red wires), +12 (Yellow wires), +3.3 (Orange wires), -5, -12. Look here for this info http://pinouts.ru/Power/atx_v2_pinout.shtml
Voltages are precisely regulated, and any substantial deviation (more than a few 10ths of a volt) indicate a problem, especially on the +5 & +3.3 lines.
Jul 07, 2008 | Okia / 450-Watt / ATX / 80mm Fan /...
Cd recording malfunction
I have a power supply that burnt out but the unit worked good before that. Can I buy your recorder for parts or do you want to buy mine for parts? You can e-mail me at schepulis@ndtel.com
Dec 02, 2007 | GPX CDRW3500 CD Player
Need manuel
It looks like a free membership at this site will give you the manual: http://www.theusermanualsite.com/manuals/mfg/gpx/gpx_cdrw_3500_cdrw3500.html
Mar 28, 2007 | GPX CDRW3500 CD Player
GPX CDRW3500 CD Player Logo
94 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
