Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Water dripping through openings in top, back of refrigerator onto top shelf, about a cup a day, in spurts, morning and evening, freezes within an hour in catch basin I configured. Kenmore 106.67297790, no icemaker.
Drain plugged by ice. will thaw.
Posted on Jun 18, 2009
Water seems to be gathering and then dripping from under the control panel which is situated in the main fridge, on the back wall, behind the top shelf.
sounds like a bad plugged evaporator drain plug? which then freezes up and moister - water/ ice build up takes place in fridge
Mar 08, 2015 | Refrigerators
How do I reset fridge model #106.51132210 it drips water from top and freezes on top shelf of fridge side
I'm not sure if resetting will help, but the easiest way is to just flip the breaker off and then back on.
Dec 04, 2014 | Refrigerators
The top of the inside of my 2002 Whirlpool refrigerator Model ET1FTK (top mount)is frozen and is dripping onto the first shelf.
The cause of that drip is going to be a blocked defrost drain in the freezer and the water from the defrost is pooling up in the freezer then when it can't hold anymore it's dripping through the vent in the ceiling of the refrigerator onto the shelfs. By removing the back wall of the freezer you could find the drain on the bottom of the freezer coil. By GENTLY peircing that frozen drain at a 45 degree angle until a small hole is formed in the built up ice it could be totally flushed using warm water once a small opening is made in the ice in the drain.
GENE
Oct 13, 2011 | Refrigerators
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
May 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water dripping into refrigerator from freezer
DRAIN TROUGH IS PLUGGED OR FROZEN. EMPTY FREEZER AND REMOVE LOWER TRAY TO SEE A HOLE ALL THE WAY IN THE BACK USUALLY IN THE CENTER. CHECK TO SEE IF WATER CAN DRAIN THROUGH BY POURING A CUP OF IT INTO HOLE. IF IT IS FROZEN POUR HOT WATER UNTIL IT THAWS, IF PLUGGED REMOVE THE OBJECT.
Jan 28, 2009 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
Food freezing in refrigerator and water dripping
The problem with the water is that the drain tube is plugged. The easiest way to fix this and to save money is to unplugg the refrigerator and leave the doors open all day. This will thaw out the drain tube without a service technician coming out. That will fix that problem. With it freezing the food on the where its not supposed, This may be a bad cold control. But try unplugging the unit for a day with the doors open and this may fix both problems. (i know it will fix the water issue)
Nov 24, 2008 | Whirlpool Refrigerators
Water Leak
pull the funnel tube out of the back wall and clean the drain that goes out the back wall of the refrig section
Feb 18, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
141 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
