Question about SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready Plasma Television
DL-hd4208t Won't turn on I also need advice on where I can get a remote control and a circuit diagram to assist me in repairing this T.V.. Any idea where or how I can contact the manufactors.                           thank-you                                  Emidio                                                  emidio56@yahoo.com.au
  • 5 more comments
  • Sollace Jun 27, 2008
    I have the same problem. Please post a solution here!
  • thel56 Aug 19, 2008
    I have this kind of plasma TV too, & the remote control was broken so I need to know where I can find one so I can turn on my TV, please help.
    thelma.musso@bigpond.com
  • Anonymous Oct 12, 2008
    TV shuts down. I can up-plug power cable and plug it back in and the power to the tv comes on. It shuts down in abour 10 minutes. I repeat the un-plug plug back in process, and works fine for about 10 minutes and the same thing happens again.
  • buzbyblack Nov 04, 2008
    my red light on the lower left of tv turns on and thats all can someone help
  • Anonymous Nov 18, 2008
    same problem flicker when turn on and turn off
    i have the same problem flicker then turns off never turn on
  • craig679 Apr 01, 2009
    I need a remote for this television
Same issue here.
Bad power board.
First symptom is flickering. Followed by shutting down. Not it will not power up.
Posted on Oct 23, 2008
Just out of interest are you suffering from any other issues with this brand of television. I find both foxtel as well as my digital top set box aren't working. Any ideas at all?
Posted on Jun 29, 2008
Why can't rear hatch be opened?
Won't open with the key ? Do all the other doors lock an unlock ? You have to understand the electronics involved , you have a remote keyless entry module an all switches are an input to the (RKEM) , an from the voltage input it knows what door to open or unlock or lock . First you would need a wiring diagram to test the circuit an you need to pull the inside panel off the rear hatch to get at the motor to see if the power is getting to it. Can be a very time consuming job. Here check out this video ,it's not the same vehicle as yours but it will give you an idea of what's involved . 2008 2012 Ford Escape Liftgate Latch Won Open Access Diagnosis Repair
Oct 22, 2015 | 2002 Chrysler PT Cruiser
I need the universal remote control code for a SVA plasma PDP TV... HD4208T. Thanks, email... topspeedtraining@yahoo.com
If you have a universal remote you can use its "code search" feature to locate a suitable code. If the search is unsuccessful, there may be no suitable code available in the remote's library.
Jul 09, 2014 | Televison & Video
Uet 606
1258 is the code to check.
Jul 11, 2013 | Televison & Video
W-72 remote won't work
1) change by new batteries alkaline
2) clean the contacts batteries with isopropyl alcohol
3) tight the springs contacts for better contacts with pliers
4) open the remote control, and clean the keypads switch from dirty, oxide, corrosion.bad contacts, or open contacts. This will NOT trasmitt the infrared signal to the receiver.
5) Otherwise you must go to the repair shop TV for fix it
see the block diagram
Jul 26, 2012 | Casablanca Fan Versa Touch2 W-72 Remote...
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
I want to know the simple example circuit diagram of a remote control
There is no much on diagram but a networking to matrix the inputs of different source to a SUB- PROCESSOR which is the heart of the unit. This outputs IR to the IR LED's to be emitted.
Please check for tips to repair a remote:
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
Jun 14, 2011 | Televison & Video
Remote Control button frozen - unable to select any number
Hi, the best way is to clean the green circuit board inside your remote control by Brennspiritus (pure Alcohol) (or eraser) and same to the buttons from inside too.
then wait until to be dry ( 2 min ), then it have to work.
if didnt , that mean there is a problem in the green circuit board amd its better to buy a new remote control.
Good Luck How To Repair Remote Control Buttons That Don Work
Jan 14, 2018 | Vizio L32 32 in. LCD HDTV
Optoma sw51u- lost remote control
Best chance is linked below but you will need the remote's model/part number at hand since the site couldn't find that model number:
http://remotes.com/remotes/servlet/rs?a=Search&mode=brand&uuid=12207196615740&brand=OPTOMA
Sep 05, 2008 | Audio Players & Recorders
Sony trinitron KV G21S2(i think)
Id you have no TV repair experience, play it safe and take the set into an authorized Sony repair place to estimate the cost to repair. Yes I know it would be nice to repair, but how much do you know about component level printed circuit board repair? You will need to first get a service manual, know how to read a circuit diagram, thats a schematic, and know how every circuit works with each other to make the TV set operate. I do appriciate the fact you would like to repair this yourself, but there is no magic fix in most cases when it comes to electronics. There is circuit diagnosise involved. Best advice would be to call in a pro to assist you in these types of repairs. Good Luck
Jun 23, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready Plasma Television Logo
444 people viewed this question
Top SVA-USA Televison & Video Experts
Tony
Michael Galve
Michael Galve
Are you a SVA-USA Televison and Video Expert? Answer questions, earn points and help others
