Question about SAMTRON 55V 15" CRT Monitor
Cannot adjust vertical alignment on Samsung SyncMaster 192N
My toolbar is half way off the screen of my Samsung SyncMaster 192N. I cannot get into the correct mode to adjust the vertical alignment on my display.
I choose menu...scroll over to the 4th icon which is Position....hit menu again and the horizontal (H) position is highlighted. I can use the + and - buttons to adjust that setting but I cannot figure out how to get the vertical (v) position highlighted so that I can adjust it.
I have tried everything I can think to try...please help! I am worried that it's something simple that I am missing.
    Habit-Forming:
    New Friend:
  • 35 Answers
Browser set to 200+ % enlargement
Posted on Apr 25, 2017
SOURCE: problem with samtron 56v 15" monitor
IT IS REULATION COMPLIANT PLEASE CHANGE THE 7805REGULATOR IC NEAR THE MEMORY IC
Posted on May 12, 2007
SOURCE: Display Resolution
samsung syncmaster 510N nonoptimize mode recomended mode :-1024x768 60hz how can i fix this?
Posted on May 21, 2008
SOURCE: No display Samsung SyncMaster 710N 17" LCD Monitor
same problem here...
here is a translated version of a webpage discussing the repair for this error...
http://72.14.235.104/translate_c?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220&usg=ALkJrhiRO8V09Lo7lnjqW47LE8IE653r7w
solder a 50 ohm resistor on pins 5 & 6 of Novatek NT68F63LG chip...
good if you can DIY, best if a qualified technician do it for you..
Posted on Oct 22, 2008
SOURCE: Error message on Samsung SyncMaster Monitor 19"
Hi There!
I had the same problem some time ago and I have managed to find a very useful website where explains how to fix it!
The solution comes from a Spanish Forum site, originally written in Spanish! Using Google translator you can have the step by step solution in English, although sometimes the translation is not too accurate!
I have managed to get my screen back to life with a total expense of 25p and 15 minutes of my Life!
Just cut and paste this link!
http://translate.google.com/translate?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220
I hope this helps!
Good Luck!
Frankie
Posted on Jan 29, 2009
  • 34 Answers
SOURCE: Syncmaster paower button blinking and no display
First of all plug another monitor to the VC on your PC and do the same for the SamSung"I over heat"SyncMaster2 053BW.
Oct 23, 2009 - This is how it went for me..I have a Samsung SYNCMASTER2.gif 2053BW. I leave my monitor on and let it hybernate when I shut down PC. I'm 3 months outside of my warranty. Two weeks ago something started happening. I boot PC and video doesn't come up for 10 minutes, and when it came up it worked perfect. VC/Monitor/MB?? It became 20 minutes and ...now..I have the analog/digital box in top left screen, power light on monitor flashing, no menu available on monitor and none of the other buttons work for anything. I test the monitor on Laptop..nothing(same as above)..I break out the old(working) monitor from deep within the closet. Plug it in and I'm up and running. So...
HOW TO OPEN A SYNCMASTER 2053BW
NO SCREWS!!! Assuming that the stand mount has been pulled out..The seam around the screen frame is where you start. The frame has the prongs, the back cover has what the prongs slip over.The frame is coming off first! I got the side to open by finger, then used a small standard screwdriver to pry ever so gently(lifting frame from rearcover). Leave the power button assembly on the frame, pull wire only a little to relax any tension..you get about 3/4" in extra taped to panel. The hard part is done.;) Still holding the frame...Now lift the panel (where the power button assembly wiring goes under panel) with the power housing that is under it as a whole and you will see where the powerbuttonassemble detaches.Remove frame. Now..holding edges of panel into back cover, lift and flip the whole thing over and place panel face down on a perfectly flat surface..a towel on my desk works. Lift and remove back cover.Your now looking at the back of the board housing. The ribon is simple, on the panel end of the ribon, squeez the outer clips together and slide it away against the panel..The secondary tin plate is removable, two clips super close to where the sets of wires come around the housing and into the panel.Unhook the 4 plugs(pink inside/blue outside)...Now lift the power housing off of the panel. The big board has the power. One screw to remove a ground plate first. Two screws to remove power board. Pics from phone.56ec44b.jpg
Reassemble but DO NOT re-snap the frame into place....yet... Test it! There is a reason the caps got hot in the first place, therfore it has a good chance of happening again. This is not fullproof...but.....mine has been on now for close to 6 hours with no glitches whatsoever. So I have resnapped mine back together. I hope you can too. - I must also add that this is one of the best producing monitors I have ever seen...in 60hz. The clarity is top notch. If you purchase one get the extended warranty. FYI...I paid $4.00 for those caps.
Posted on Oct 24, 2009
After several hours of inactivity, the screen on my SyncMaster 192n goes black, and the only way to turn it back on is by hard re-booting my computer. Sometimes even ctrl-alt-del doesn't work, and I have...
My guess is your video card driver has been altered and is causing the problem. Try rolling back the driver before reinstalling the monitor. Here is a link to the manual for your monitor: http://www.flatmonitors.com/Samsung170N.pdf
From the above manual: "The PowerSaver system operates with a VESA DPMS compliant video card installed in your computer. Use a software utility installed on your computer to set up this feature".
FFFF
Mar 18, 2017 | Samsung Syncmaster 192N 19" LCD Monitor
Can't find the place to put in speakers for syncmaster 192n monitor
lemoncaketre, 192N is basic VGA only type monitor!!!! No AUDIO capabilities!! Use a set of external speakers for audio!!!
12fixlouie
Sep 14, 2010 | Samsung Syncmaster 192N 19" LCD Monitor
My Monitor samsung syncmaster flashes and like the light of the controls as someone to turn off and on
You need to open it up and inspect he caps in the power supply, look for bad caps with bulging tops or seals. See example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you find so we can guide you further.
Mar 11, 2010 | Samsung Syncmaster 192N 19" LCD Monitor
I have an old Samsung 192N LCD computer monitor, and I have been having problems with it. There is a large black, vertical bar about the size of my thumb on the side of the monitor. I don't have a cable to...
you need to repir the power supply and replace the screen. the power supply may have had bad capacitors on it . crowned or leaking. it will be cheaper to replace the monitor with a preowned on rather than repair it
Dec 25, 2009 | Samsung Syncmaster 192N 19" LCD Monitor
Screen went black while i was on it and i have not gotten a picture since
try this first if you disconnect the cable and you get warning on the screen that the cable is disconnected,chances are the monitor is still good,next you might want to check if its set to digital or analog,
Good luck
Aug 26, 2009 | Samsung Syncmaster 192N 19" LCD Monitor
My three year old Samsung SyncMaster 192n keeps turning off. If I unplug the power supply and plug it back in it will turn on for a while. Any suggestions?
You need to replace either the caps or the inverter board. You may require an assistance from a repair person in replacing it. Check this link so that you could see how the inverter board looks like:
http://www.shopjimmy.com/catalogsearch/result/index/?q=inverter+boards&stock=all
Have a good one!
Jun 23, 2009 | Samsung SyncMaster 192 T (Silver) 19" LCD...
Picture not filling monitor screen
what is your sceen resolution set at on your laptop. try adjusting them and see if that works.
mj
Nov 01, 2008 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Menu not in centre of screen and unable to see volume bar
1. Solder the vertical IC. & IC supply capacitor.
2. change the vertical IC
Oct 20, 2008 | Samsung SyncMaster 1200 NF (Ivory) 22" CRT...
Samsung SyncMaster 192N loses picture; requires re-boot
Unfortunately, you two have two unrelated problems. CB, the monitor isn't asking you for the password, that's the computer itself going into hibernation, which shuts down the video output, hard drive, etc. You need to go into the power-save settings and either disable hibernate, or change the settings to your liking.
The other question about the screen staying on for 5 seconds... thats an inverter board problem.
Apr 25, 2007 | Samsung Syncmaster 192N 19" LCD Monitor
SAMTRON 55V 15" CRT Monitor Logo
471 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
