Question about Sevylor Pressure Gauge Mano 4280A
What's the pressure for Sevylor st 5696 dive?
Sevylor st5656 what air presure should be in it
The ST5656 is a low pressure hull, so shouldn't be inflated to more than 1 psi, or about as firm as a ripe grapefruit. If you leave it out in the sun you need to let some air out or the air inside will expand and it will blow up
Apr 04, 2013 | Stearns SEVYLOR Sit on Top Kayak U250
Raft repair
Sevylor sells a patch kit, as well as a spray that is kind of like a silicone that works well on pinholes. Go the website: http://www.sevylor.com/Spare-Parts-Kit-P1898C45.aspx - more parts under accessories on the site.
You wouldn't have a copy of the manual for your boat, would you? I can't seem to find one - even called Sevylor and I couldn't get one!
May 15, 2012 | Sevylor Fish Hunter 6 Person Inflatable...
Need Manual fo Sevylor 12V Trolling motor
The Sevylor electric motor does directly mount to any Sevylor and Intex boat with out the need for an additional mount.
Sep 29, 2011 | Sevylor SBM 12Volt Fishing Motor
WHERE IS THE AIR NOZZLE TO FILL THE SEVYLOR FLYING MANTA RAY LOCATED
All the Sevylor tubes have a valve that comes apart in to two pieces, remove the top and you can fill remove the hole thing releases the air. You need a 12 volts high volume low pressure pump with connectors, 20 bucks in Overtons. Fill it till it is stiff, put it in the water let the air cool down inside then hand fill it with the connector and human breath to stiff it up again.
Sep 07, 2010 | Sevylor 48 in Inflatable River Tube
Sevylor motor mount instructions
I dont believe a motor will mount to it. Sorry!
Sep 30, 2009 | Sevylor 48 in Inflatable River Tube
Sevylor river xk2 does not track well on still water
This inflatable kayak is meant to turn to facilitate maneuverability in whitewater; it needs to turn.
Try attaching piece of plastic as a skeg, perhaps the skeg from the Sevylor Tahiti will suffice (or a piece of lucite or a plastic cutting board). A skeg makes a boat track straight.
My Sevylor Colorado came with an optional skeg which I only attach on flatwater (never whitewater).
Aug 14, 2009 | Sevylor Inflatable River Xk2 Kayak
Empty air pressure gauge
mineral oil any thing else will build up residue
Mar 18, 2009 | Dive Rite Brass Pressure Gauge - Gauges -...
How and why scuba gauges give a diver critical information while scuba diving?
Scuba gauges give a diver three very important pieces of information: 1. Time 2. Depth 3. Air Consumption This information enables a diver to stay within safe time and depth limits and avoid running out of air. There are many different devices on the market to help with this, from simple gauges to complex digital consoles. Time If a diver is not using a dive computer to monitor their nitrogen, they dive according to approved dive tables. To use dive tables properly, a diver needs to track their downtime. This can be done with a good dive watch. Two things make a good dive watch: water resistance and a rotating bezel. 1. Water Resistance. Good dive watches are rated to a depth in meters or feet (e.g. 200 feet) or a pressure rating in atmospheres (e.g. 4atm). Even though most divers probably won’t dive below 130 feet (the recreational dive limit), a good dive watch should be rated to 200 feet. Note: There is a difference between “water resistance” and “waterproof”. A “waterproof” watch is what you would wear in the shower, but would probably start leaking at 15-20 feet. 2. Rotating Bezel. A bezel is an adjustable ring on the face of the dive watch with a pointer indicator. At the beginning of a dive, the pointer on the bezel is aligned with the minute hand where it stays though out the dive. At the end of the dive, you compare the difference between the bezel and the minute hand to find out the length of the dive. The bezel should only move “counterclockwise”. It is possible to accidently move the bezel during a dive. Because of this, watchmakers make sure any accidental movement will turn the time in a conservative direction, making the dive longer rather than shorter. Depth Another important part of scuba gauges is a depth gauge. A depth gauge enables a diver to keep track of their depth even if they cannot see the water’s surface. Gauges can be either an analog (needle-and-dial) device or a digital device. Both work in the same way. They measure the surrounding water pressure and convert this into an accurate reading of your depth. Another feature of a good depth gauge is a maximum depth indicator. This tells a diver their maximum during a dive and must be reset after each dive. Air Consumption Another equally important part of scuba gauges is a submersible pressure gauge (SPG). This is connected to the first stage with a high-pressure hose and measures the pressure of the air in the tank. The SPG is much like the gas gauge on a car. At the beginning of a dive, a diver starts with a full tank. This should be about 3000 psi or 200 bars. As the diver breathes during the dive, the gauge will move slowly downwards. This allows the diver to have enough air left in the tank to: 1. Make a slow, safe ascent 2. Make any necessary decompression stops 3. Inflate their BCD once at the surface 4. Breath from the regulator if the surface conditions are rough A submersible pressure gauge also allows a diver to stop diving with air still in the tank. This keeps contaminants from entering the tank due to no air pressure. Wrist Depth Gauge Scuba gauges come in two basic styles. Stand alone gauges or gauge consoles. Stand alone gauges such as a wrist mounted depth gauge or a submersible pressure gauge attached to the first stage of a regulator are great backups when using digital gauges. Gauge consoles allow divers to have all their gauges in one place. Although less easy to read, analog gauges sometimes give slightly more accurate readings than digital gauges, particularly at shallow depth. Submersible Pressure Gauge Choosing Scuba Gauges When choosing scuba gauges, remember to look for: 1. Easy-to-read numbers 2. Luminescent dial or back lighting options 3. Rotating/swivel mounting 4. Easy disassembly for cleaning or replacing parts 5. Good warranty
Dec 01, 2008 | Aeris Max Depth Analog 2 Gauge Console
Sevylor Pressure Gauge Mano 4280A Logo
79 people viewed this question
Top Sevylor Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
Bill Boyd
ray gallant
Are you a Sevylor Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
