Question about Compaq Evo N610C Notebook
Compaq N610c is going crazy, need Help!
I have sold a compaq n610c that i installed myself, to a Friend but a few Days later he comes back with it telling me that the Battery doesn't charge.
I take it home with me and i found out that when i switch ON the Laptop it tells me "No booting Drive found" or something similar after doind once "CTRL - ALT - DEL" it then Boots corecctly into Windows. This was the first weird thing i discovered.
Once in Windows i went to look if the Battery was charging or if it was even being recognized by the System and the scond weird thing happened, the System was Blinking that small blue Ray of light over the Battery symbol that shows that it is loading the Battery plus every time the ray of light showed up while blinking a small text appeared saying "0%  [Loading]" and i could read there: "Source of Energy: Alternate"! Shouldnt the Battery receive "continuous" Electricity instead of "alternate"??
I then tried to change the original charger with a Universal charger to see if the problem persisted and yes it did, the Universal charger didn't change anything.
The third weird thing the Laptop is doing is, that everytime i boot up or reboot the computer, the Date and Time in Windows sets back to 1980 and Windows Warns me of that fact. Why in Hell is this Laptop doing this weird things? When i gave it to my Friend it was Working flawlessly and 2 Days later it does all this weird things.
Do you have any Idea what could have happened? And how do i resolve this issues? I had Flashed the Bios with the newest one from HP while installing the system and now i flashed back to the older Bios it had before but that didnt made a difference either, i was thinking the small Bios Battery could be Dead but that dont explain some of the weird things that are happening to this Notebook.
Any Help would be very welcome and appreciated, Thank you!
Peter S.
  • Picas Nov 18, 2007
    Thanks for trying to Help.
    This is what i have done; I changed the Battery with a new one, problem with Battery solved, old one was Dead. Still the Time and Date keeps going back to 00:00 and 1980 every time i start the system cold for the first time, does that mean i have to change the CMOS Battery??
  • marc_lucas Jun 26, 2008
    Hi, I also have the same problem, as I understand when the main battery dies the clock battery also then goes flat. But does anyone know where this clock battery or rtc as its sometimes called goes!???
  • 55 Answers
The ''alternate''should mean the source (than battery)not the current.Go to control panel check the settings on power options and change the small bios baterry(as you thought) If the problem continious change and the normal battery or check it with no battery on
Posted on Nov 17, 2007
  • john doe Nov 21, 2007
    propably your cmos battery must change also just give her few days your new battery mau revive her
    Problem Solver:
  • 5 Answers
Try replacing the battery....
Posted on Nov 06, 2007
Have compaq evo n610c laptop, it locked up on
sadly you need a new drive, these are about £40.
from any computer vendor fit new drive and then load installation disc.
hope this helps.
Apr 27, 2010 | Compaq Evo N610C Notebook
Problem compaq Evo notebook N610c
The bluetooth driver for your laptop (and all other drivers for it) can be downloaded [HERE].
The name of the driver is "Support Software for Windows XP for Bluetooth MultiPort Module by Compaq" and can be found under the #driver - network" tab.
When you say Adobe pdf I assume you mean the PDF Reader?
Sep 21, 2009 | HP Compaq Evo Notebook N610c
Screen turn off of Compaq Evo Notebook N610c
check your settings under power options in control panel, also check advanced power options in bios. very likley you will find problem here.
Jul 25, 2009 | Compaq Evo Notebook N610c
Compaq Evo N610C Faint Screen
Usually it's the inverter. Sometimes it's the backlight / lcd, and occasionally it's the lcd cable and or video card.
Easiest thing to do is order a replacement inverter from ebay. They're cheap and then swap it. You just need to remove the outside lcd bezel, it's just four or five screws and you're in business.
Feb 22, 2009 | Compaq Evo N610C Notebook
ATI vga driver and compaq N610c
plz i want compaq Evo N610c vga driver
Dec 04, 2008 | Compaq Evo N610C Notebook
Battery installer
My compaq evo n610c have the following problem: "103 circuit charge failure" and use power AC only.
best regards
Sep 19, 2008 | Compaq Evo N610C Notebook
Can I install 1gb of ram on a compaq evo n610c
Yes, Memory Upgrade for Compaq Evo N610C, the Compaq Evo N610C takes the PC2100 DDR SDRAM SODIMMs to a max of 1gig - and two 512 would be perfect.
The memory modules in a Compaq Evo N610C are not located where you expect them to be.
Here's how to do it.
Open the notebook, and place your fingers on the keyboard as if you were going to type. There is a panel directly beneath your left palm, just below the Ctrl and Alt keys. The panel is hooked into the front of the frame closest to you. Using a thin flathead screwdriver or knife blade, apply a bit of pressure on the panel so that you're pushing it towards the LCD while prying it up. The panel will come right off and you'll have direct access to the memory modules.
Jul 28, 2008 | Compaq Evo N610C Notebook
Compaq Evo N610C Notebook Logo
596 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
