Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Spin cycle not draining
My Hotpoint WD63 1100 Spin does not seem to drain .. Does this mean that the filter is chocked ? If so where is the location of the filter if any ? Or could it be some other problem ?RegardsBrian
  • Hotpoint Master
  • 3,463 Answers
Hi-ya Brian
Probably blocked filter.
To locate and clean, remove rear panel altogether, locate large black hose at bottom of drum, remove from drum, and you will find the filter located inside the hose.
Check drain hose is not blocked also.
Please rate my solution.
Thanks.
Posted on Jun 17, 2009
Hotpoint acquarius wf640 what does error f-03 mean?
F-03 means that there is a drain problem. Check the drain filter and the drain hose. The drain filter must be cleaned and the drain hose must be set according to the specifications on the appliance's manual.
The drain filter access is located in the front lower side of the washer. The drain hose at the back of the appliance. See also: http://www.fixya.com/support/r4949772-washing_machine_not_drain
Jun 23, 2012 | Hotpoint Washing Machines
Door will not open have wash cycle
Switch off, put in spin/drain cycle and switch back on; check water is fully drained and then check filter. If not all drained, lower hose to ground level and drain to a bowl.
Apr 28, 2012 | Hotpoint Washing Machines
Hi. is the front filter on hotpoint wma10 removeable. The machine is not draining properly after cycle but putting it on spin only cycle twice removes most of the water.
Most hotpoint filters are Located under the drum centre ..you need to remove the big sump hose/ clipe off then the filter is inside here . give it a good clean the water test machine for any leaks before using...Good Luck
Mar 19, 2011 | Washing Machines
My wife restarted the rinse cycle to add fabric softener. Now the cycle timer isn't working. Washer will not drain OR spin. Everytime the timer gets to the spin cycle, it agitates instead. It is a...
Lay the drain hose down to floor level, and drain of the water into something.
Then try it on spin, if it spins o/k, then the pump or filter is probably blocked.
Hope this helps.
Jan 19, 2010 | Indesit W 123 Front Load Washer
I have the hotpoint BWM129 super silent 1200 spin, recently the machine has stopped draining water even after spin cycle has finished , I also have constantly flashing lights which are super wash and delay...
The flashing lights means that an error had been detected.
The machine must be unplugged from main to check the drain hose and the drain pump.
The most common is that the drain pump is clogged with debris and must be unlocked.
Feb 18, 2009 | Hotpoint BWM12 Front Load Washer
Machine wont go into spin cycle
The pump fiter is probably blocked.
Remove lower rear panel of washer.
Locate, and remove large black hose on bottom of tub.
Remove plastic filter inside, and clean.
Refit filter and hose.
Should now be o/k.
Before you do anything, lay the drain hose down into a bucket or bowl, and drain all the water out, so you do not have a flood when you remove the hose.
please rate my fixya solution.
Thanks.
Feb 01, 2009 | Hotpoint Aquarius WD640 Front Load...
WM 22 will not spin
yes.dose it drain,see it must drain before it can spinso if water is standing in it it wont spin and that would mean your pump is ither blocked or reciving power but not working.
Jan 01, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
My hotpoint wma56 wont do its fast spin cycle
Have you checked and cleaned the filter on the machine, usually located and the front near the bottom. If so then there is 2 other possibilities, either your water pump at the back of the machine is blocked or faulty, or it's the timer on the machine. A washer won't go into spin mode until it has drained all the water from the machine first. hence the pump has to run. Just remember to drain all the water from the machine before checking your filter otherwise it will end up on your floor.
Sep 22, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Washing machine
Normally these spin problems are just a blocked filter, which is located at the bottom of the washer behind a white panel which you can undo with a coin, drain water first, undo plug from hose into a bowl etc then take out filter and clean, hope this helps.
Nov 12, 2007 | Hotpoint BWM20 Front Load Washer
Hotpoint WD51P First Edition 1100
two possible cause. 1)drain pump motor faulty. 2)some thing struk inside the pump. it easy to locate the pump ,normally at the bottom near the draining pipe .hope it help
Aug 02, 2007 | Hotpoint WMA46 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
420 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
