Question about Whirlpool Duet GHW9150P Front Load Washer
Leaking detergent and fabric softner
  1. I have a whirlpool duet HP and sometimes the detergent and fabric softner leak at the same time.  Is there any soloution on what to do and to handle this issue.  I've only had the washer for 2 months.  Thanks
  • 1,294 Answers
Re: leaking detergent and fabric softner
Possible your inlet into the tub from the detergent drawer is clogged; try pulling the drawer out gently to clean out. Or use a tooth brush. If you are good at 'do it yourself ' jobs you could open up the top of the machine to see what the problem is. If the machine is under warranty, call the dealer.
Posted on Nov 07, 2007
0 characters
3 Points
The fabric softner compartment of my whirlpool duet washer is completely full of water
Mine is doing the same. For over 2 months now I've been adding fabric softner to the detergent compartment but I broke down and called a repairman to come tomorrow... at a ridiculous repair rate. My washer is less than 3 years old and this will be the 3rd major problem that needed to be fixed. I've seen a lot of people post the same problem - some say all 3 compartments won't drain.
Feb 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water overflows from the detergent drawer
Check this tip out...
I know it is about the fabric softner, but I think that the problem with the detergent is inthere also...something is dirty and plugged up...
Fridgidaire Washing Machine Fabric Softner not going into washer
Aug 23, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet washer, dispenser problem with fabric softner
maybe it's clogged take the drawer out and see if the water flows out of that side ok. put into rinsea nd spin and it should put water into that side.
might take a minute
What happens let me know
make sure you have a towel ready
Feb 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Detergent reservoir won't drain after cycle finished. Water stays in it.
hopefully your using the HE type detergent an fabric softner, an not using but a teaspoon full each. the machine will detect if there is any product left in depenser. an too there will be some water left to keep lines an seals mosit. to keep from drying out so thats normal.
May 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet dispenser problem
this is joyce
You need to call who ever you bought it from and tell them the problem that you are having, I have the same set and I am not having that problem at all. I love my set, just be sure to use the he detergent, or you will have problems that the manufactr will not help with.
Dont overload machine the clothes wont smell clean.
Feb 06, 2009 | Whirlpool Washing Machines
Fabric softener dispensing before wash begins
I was having the same problem. Repair man replaced VALVE AW
He told me it is from the sedement in your water. If you have a water softner, it may not be the problem, unless it is not working properly. Sounds strange, but problem is fixed.
Nov 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Fabric Sofner won't dispense
hi there remove the soap drawer then remove the cover over the softener compartment you will more than likely find a blockage in the cover siphon or the down tube on the drawer
Feb 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leaking detergent
Sounds like the back of the soap drawer or inlet hose is partially blocked. Check whether junior has posted a toy car in the drawer
Oct 26, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet fabric softner problem
It obviously is backed up or splashed in from the wash. And if it is just water why worry about it.
Aug 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Fabric softner leakage
By opening upper machine's cover you will have an access to the detergent/softner drawer. Look for the place the water leaks from. Good luck !!
Sep 03, 2006 | Maytag PAV2300 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
281 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
