Question about LG Art Cool LA121CNP wall/window Air Conditioner
The unit behind the filter is frozen solid.
The unit behind the air conditioner filter is frozen solid, when the unit is on it's spirting out water, and there's a grinding noise coming from the unit. It's going to be 9+ degrees + humidity in Houston and I have cats in the house.
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Sergeant:
  • 340 Answers
Turn it off thaw out clean evaporator clean filter the grinding is the blower wheel hitting the froze solid. hope the blower wheel is not wrecked. use 409 to clean. Tom
Posted on Jun 17, 2009
Water Filter Frozen
Air blowing directly on things like a water bottle has frozen it solid ( in the REFRIGERATOR SIDE! -- Block airflow BUT... I think the problem is YOU NEED TO CLEAN ( blow out with air!...the ONLY WAY) YOUR CONDENSOR COILS ( in the back, outside...behind the cardboard cover nowadays) Your fan has to run too long ( because refrigeration is the "removal of heat"...this is what those coils do but they are insulated with dust!)...too long blowing to achieve the same temp result = Frozen Stuff
Sep 24, 2017 | Frigidaire Refrigerators
My air conditioner is no longer blowing cold air it only seems so be on fan mode though i have it set on cold. Also there is a wire hanging down behind the filter which i hadn't seen in the past.
Hello my name is Heath it will be my pleasure to assist you. The first thing to check is the filter in the furnace or air handler. Also check the inside coil to be sure its not frozen up. Does the air coming out feel cold? It sounds like the unit could be low on charge which means it has a leak and should be leak checked repaired and properly charged. You would need refrigeration gauges to put on the system in order to properly check the refrigerant charge in the system. One other thing could be a dirty condenser coil. Turn the power off to the unit and use a garden hose with a strong nozzle and spray water through the whole coil to try and blow any dirt or debris through the condenser coil in the outside unit.
Aug 27, 2011 | Haier HWF05XC7 Thru-Wall/Window Air...
I have a Goodman A/C unit model number cpke 36-1a. My problem is that the fan in the house works along with the unit fan outside, but no cold air in the house. What do I need to check? thermostat is set at...
First check the filter to see if it is not completely clogged and make sure the
coil fins behind it are not frozen solid. If it is then shut off system or switch it over to
Heat to defrost the coils if you have a heat pump, then replace the filter.
Then check the outdoor unit to see if the large copper line coming to it is cold
(this means the compressor is running and not just the fan)
Also Make sure the thermostat is in "AUTO" and "COOL"
The last thing to check is to make sure the duct work to the return has not separated or
has not been torn open by animals (cats love to do this under mobile homes).
Sounds like a ductwork problem or plugged filter from what you describe. Hope this helps.
Aug 10, 2011 | Heating & Cooling
Water dispenser just stopped working. Ice dispenser still works and the refrigerator has a new filter
two possibilities
1) the water valve is defective it has one inlet from the house plumbing,two outlets, one for i/m one for water dispenser
2) the reservior that chills the water is frozen, it is located behind the lower crisper drawers in the ref. to see if its frozen remove crispers and shelves and tap on it , if hollow sounding it's not froze if solid sounding its froze. to thaw it turn off unit for at least a hour
Jul 21, 2011 | Kenmore Side by Side Refrigerator
The interior of the air conditioner behind the adjustable directional flow fins is covered with mildew. How can it be cleaned?
Remove the front of he unit, as if you're going to clean the filter. That will give you access to what you need to clean. Use warm water and dish washing liquid to wipe off the mildew. Rinse with clear water and a sponge, dry thoroughly and replace the filter and the front of the unit.
NOTE: Before attempting any of the above. Turn the unit OFF & Unplug it.
Jul 20, 2011 | Frigidaire FAC124N1A Air Conditioner
How to change or clean the filter and where to download a manual
DeLonghi has the manuals for their portable air conditioners here: http://delonghiusa.com/support/product_manuals/5#table-jump . The direct link to the PAC C120 manual is http://delonghiusa.com/support/sites/default/files/product_manuals/m-PAC+C120.pdf .
Before cleaning, turn off the air conditioner. To clean the filter, pull it straight up from behind the top of the air intake (on the back of the PAC C120). Vacuum off the filter. If it is very dirty, immerse it in warm water and rinse several times. (The water should not above 40 degrees Celsius (104 degrees F)) several times. Then allow the filter to air dry. Slide the filter back into the air conditioner and turn the unit back on.
I hope this helps.
Jul 17, 2011 | DeLonghi PAC C120 Portable Air Conditioner
Not cooling looked at inside behind filter and it is frozen
A frozen evaporator coil means one of two things, a lack of air flow or low refrigerant (freon).
Make sure the filter is clean and the coils are free of dust and dirt. If the unit blows good air (strong flow on high) when it first starts up and then freezes you are low on refrigerant and need to have it recharged.
Jul 21, 2010 | Goldstar Heating & Cooling
Delonghi pac w160a...''no water symbol'' stops on in airconditioning mode even though water tank is full
In the back of these units where the cord pulls out, there is usually a red reset button, try pushing that to reset the unit, also make sure the filter is clean, pulls from the top out of the unit. Make sure the coils are clean as well behind the filter.
Good Luck!
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Nov 12, 2009 | DeLonghi Air-To-Air Portable Air...
LG Art Cool LA121CNP wall/window Air Conditioner Logo
472 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
