Question about Sharp Office Equipment & Supplies
Hello i have copier machine sharp mx-450u,with mx-nbx3.some times when i print document.suddenley stop printing,so i turn it off then it start printing,allways same ****.so i dont know the proplem cause of copier machine or cause of the mx-nbx3.so please give me the solution
  • ekouejean
    ekouejean Sep 25, 2012
    I do not the toner of my machin mxm450
    Scholar:
  • Sharp Expert
  • 120 Answers
As a general rule, U machines are not designed to be turned into network printers, that's what the MX-M450N is for. You can put an MX-NBX3 on it, it might work properly and it might not.
The NBX3 can only function properly with a hard drive in the copier, otherwise you're outta luck!!
Your driver type may be wrong. If you are currently using PCL6, try PCL5e.
Other than that, try getting a new driver from the Business Copiers section of sharpusa.com. You may have to see which model will work for you. Look for the PCL driver for MX-NBX3, then look for MX-M450U, then MX-M450N.
Posted on Jul 09, 2009
How do i stop my sharp copier from printing with line
Here is a short video I made on how to remove lines from copies/prints on Sharp copiers.
Copier Collin Houston TX Copier and Imaging Expert
Mar 10, 2015 | Sharp Mx-4111n Multifunction Copier
Mx 2830 - fails to print - asks to add extra plain paper
Check the paper type and paper size in the Printer Properties. Set them according the actual paper used in the printer. Check the paper size in your document you want to print. Correct, if differs from the printer's paper size.
Jan 09, 2014 | Sharp Office Equipment & Supplies
Documents in printer que, but does not print
If a print job get hung up in the print que it may stop and not be able to be deleted, this will also block other print jobs from printing. Here is a link to an article that shows how to clear the print que and purge the stuck print jobs so printing can resume. I hope it helps.
http://www.ccl-la.com/blog/index.php/how-to-delete-print-jobs-that-are-stuck-in-your-print-queue/
Dec 10, 2012 | Sharp Mx-2310u Color Copy/print/scan
Sharp MX-2610N printer can't set-up the print job (for labels from by pass tray) from my desktop computer.
Some documents like word override the settings... you need to change/save within your document you are printing. page layout and then page set up
Sep 16, 2012 | Sharp MX-2300N Color Copier
How to delete password protected pront job in Sharp mx-2700N when password is lost? I can log in as admin (web-access to printer) but cannot delete the documents in Documenthandling. BR, Steven
Open web interface of the printer and supply admin password.
As an administrator you should be able to navigate to the System Settings screen.
Select Document Filing Settings and navigate to the section Administrator Authority Setting.
Select Delete so you can delete forgotten print jobs (remember to Save the setting).
Navigate on Document Operation where you can see a list of existing saved print jobs.
Select the jobs to delete and go on.
You don't have unwanted ghosts anymore on your machine!
Most important: always remeber to smile and to help people. Take care.
Jan 05, 2010 | Sharp MX-2700N Color Copier
SHARP MX-2300N
Someone has sent a print job from a computer to the copier with an odd paper size specified. Go to Job status, under "print" highlight the first job in the que and delete it. (if the job was sent more than once you will have to repeat. ) Check the document and print settings of the offending document.
Dec 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
"Load Paper" screen wont go away. Is loaded with paper!! Help!!
Goto the job status and select the print job that is waiting.. To the right, select details and select the paper size you want. Identify the job because you will want to make sure the settings in that document are set to the correct paper size and type.
Dec 03, 2008 | Sharp MX-2300N Color Copier
Sharp AR-5320 giving me L 4 error some time
Usually the error is caused by a main drive over load. The machine needs to be looked to determine if its the motor, power supply, or a board.
Sep 19, 2008 | Sharp AR-5320 Black and White Copier
385 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
