Question about Konica Minolta Magicolor 2530 DL Laser Printer
How do I remove the toner cartridges from my Konica Minolta Magic Color printer 2530 DL?
  • 32 Answers
Menu select,>x2 quality menu ^replace toner
Posted on Jun 26, 2009
  • 210 Answers
The instructions for this are posted on inside, back-left of the front panel when open. As indicated, push the green button in the lower-left corner with an embossed "1" next to it. Then, turn the green knob next to it with an embossed "2" next to it until the next cartridge is fully visible and the button from step 1 pops back out. Repeat step 2 until the correct cartridge is in place. Then pull the green handle above and to the left of the cartridge.
Posted on Aug 31, 2009
Konica Minolta Magicolor 2530DL streaks. maintenance
Lift drum out, look down behind toner and you will see a glass lens.
Clean it with a soft cloth or tissue. Works every time.
Aug 24, 2012 | Konica Minolta Magicolor 2530 DL Laser...
Magenta color very faded, but cartridge indicates it's fine and drum not automaticly rotated to replace it yet. But definetely faded, not clear colors
The printer may be dirty, the toner is deposited in front of the glass laser and unable to write properly: Clean the printer
May 12, 2011 | Konica Minolta Magicolor 2530 DL Laser...
I have a Fatal Error Code: 17H Can you help? It is a Magicolor 2530 DL color printer.
Check your toner cartridges, one of them is seized up. Remove all cartridges and turn the gear on the right side backwards ( counterclockwise) about 10 times and see if it turns smoothly. I don't know why but 90% of the time its the cyan that gets stuck.
Jun 11, 2010 | Konica Minolta Magicolor 2530 DL Laser...
I have a line running through my pictures. it doesn't matter what picture i print, i get the line
Well, there's bad news and then there's worse. Hope for the laser lens. Hope it's not the drum. By the book:
Abnormal
areas (white,
black, or
color) appear
in a regular
pattern.
The laser lens is dirty. Clean the laser lens.
A toner cartridge may
be defective.
Remove the toner cartridges with the
color causing the abnormal image.
Replace it with a new toner cartridge.
The drum cartridge is
defective.
Remove the drum cartridge and check
for damage. If it is damaged, replace it.
Mar 30, 2010 | Konica Minolta Magicolor 2530 DL Laser...
THE KONICA MINOLTA MAGICOLOR 2530DL/ ALL FOUR COLORS OF INK ARE LEAKING ALL OVER THE INSIDE OF THE PRINTER, WHAT WOULD CAUSE THIS?
Most likely reason is the printer is either a display model, or previously been sold and returned. The toner cartridges are usually sealed and these seals need to be removed prior to use. I would recommend returning to the supplier and asking for a new one, with the toner cartridges sealed. Once toner has been spilt, it is very difficult to remove all traces. A standard vacuum cleaner may be suitable to remove the worst.
Mar 08, 2010 | Konica Minolta Magicolor 2530 DL Laser...
Konica minolta 2530 dl Replaced black cartridge now says others not installed and "cannot rotate cartridges"
Clean toner chip reader, remove OPC drum and all toners, under the toner rack there is a 3 pin chip reader, use pressure air to clean it.
Jul 21, 2009 | Konica Minolta magicolor 2430 DL Laser...
2530 DL problem printing, has a streak of white line all the way down the page. Has plenty of toner in it.
If all the toners are not empty, then you have toner or dust on the print head unit. Remove the drum cartridge and you will see beneath it a narrow glass, just be sure that glass is clean.
Jun 07, 2009 | Konica Minolta Magicolor 2530 DL Laser...
I just got new color toner and says is out.
In the engine menu, set it to continue on error. It will continue to print, but the error light will blink...
Mar 22, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Konica Minolta Magicolor 2530 DL Laser Printer Logo
244 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
