Question about Dryers
My dryer won't run. The light is on when I open the door but I get nothing. The main circuit breakers aren't tripped. Is there a switch or breaker on the motor that could have gotten tripped? We bought the dryer new in 95 & replaced the motor in 02. Hoping it is minor.
    President:
  • 512 Answers
Sounds like one of the thermal switches is bad. Open back of dryer and look for metal round thermal switches. They are about a quarter in size. Use a jumper wire from on side to the other, try them all like this until you find the bad one then replace it. Also when you do this unplug unit, jump wire, then turn on. Always unplug when hands are on wires.
Posted on Jun 17, 2009
Dryer won't start
First, let's look at the switch on the door that is supposed to not allow the dryer to start if the door is open.
If this switch fails, could cause the problem. (Somewhat common)
Second, the switch that is supposed to start the machine could have failed. (Not too likely)
Then check the circuit breaker in your "fuse box" in the hall or garage or basement or wherever.
Circuit breakers can trip and not look like it. You might switch them (there are 2 together) on and off a few times to see if that is the problem.
Be blessed.
Feb 18, 2013 | Maytag Dryers
Dryer won't start
the timer could have went out or maybe the door switch is stuck open
Jan 08, 2013 | Dryers
Neptune dryer has power but will not spin.I hear a faint click comming from the left side. model#MDE9700AYM
An electric Neptune clothes dryer, like most electric clothes dryers, has two circuit breakers: one for the drum and another for the heating element. Both breakers need to be in the "on" position for it to run properly. Go to your main circuit box. Reset both of the dryer's circuit breakers to the "on" position. If one of the breakers trips again, there's a problem with the dryer component that it operates. Contact a dryer repair technician to evaluate the machine's condition.
The lid switch is a small latch located on the interior of the door frame on your Neptune clothes dryer. It keeps the door securely shut when the dryer's on to prevent injury should you open the door and reach inside while it's turning. If the lid switch becomes damaged, the dryer won't turn on even though its lights might work. Run your finger over the lid switch and listen for a clicking sound. If you don't hear a sound when the latch is compressed, it's faulty and needs to be swapped out.
The thermal cut-off is a heat-sensitive safety feature on a Neptune clothes dryer that shuts off the heating element if the dryer overheats. After it activates, it can't be reset; you must replace it. Until it's replaced, your dryer might only partially function, so while its lights might turn on, the dryer might not spin or heat. Don't exchange an old thermal cut-off for a new one until you first determine what promoted it to trip, otherwise your dryer likely will overheat again.
Oct 19, 2012 | Dryers
Won't start
Check the door switch by listening for an audible click just as the door opens or closes. If you do not hear an audible click then the door switch is bad. IIf you hear this audible click then go to your circuit breaker box and check to see if they have tripped. If the circuit breakers have tripped reset them ONCE and try the dryer. If the breaker trips again DO NOT reset it. You have an internal short in your dryer and it will require further service.
Jan 06, 2010 | Whirlpool LER4634J Electric Dryer
The circuit breaker trips when I open the refrigirator even when the ref switch is off
There must be a short in the internal lighting circuit which have one functional component, the switch. It is usually a white push-button inside the refrigerator near the door. The door pushes the switch when it is closed turning the light off. When the door is opened, the button pops back out to turn on the light. In your case, when you open the door you are switching on the light but the circuit breaker trips off. It means the short circuit is in the light wiring and nothing else. Retrace the wiring and you'll surely find it there. Rewire and have a good day.
Sep 24, 2009 | Refrigerators
My Whirlpool dryer is plugged in but will not turn on
I would start by checking to make sure the circuit breakers are not tripped. An electric dryer runs on 220 and will have a double circuit breaker - a gas dryer runs off of 110 and will usually not have a dedicated breaker. Once you have determined the power is on, the next most likely problem is the door switch. This prevents the dryer from being activated with the door open. You can "jiggle" the switch while attempting to start the dryer, or check the continuity with an ohmmeter.
Jul 20, 2009 | Whirlpool Dryers
The dryer will not turn on. I know I have power because the light is on. But nothing happens when I hit start
Check for a tripped circuit breaker (a ganged double breaker), sometimes only one breaker trips without tripping the other. Switch breakers off and then back on. If you have access to a voltmeter, check for 220 volts AC at the the two slanted slots in the dryer socket. Occasionally, one breaker of the pair will fail internally--replace the pair. If 220 volts is present, then problem is internal to the dryer. Usually, it is a short circuit in the heating element which causes the circuit breaker trip.
Jul 16, 2009 | Dryers
I have a whirlpool dryer, model number GEC9858EQ0, that did not restart after opening door to check the laundry. I have ohms checked the start switch and door switch. where do I go next?
It blows fuses or trips the circuit breaker Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. To decide where the problem lies, unplug the dryer, then:
  • If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician.
  • If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
    Good luck
  • Regards:
  • VOTIT
Jul 01, 2009 | Dryers
Dryers Logo
Top Dryers Experts
Marvin
Marvin
