Question about Ruud UBHC Air Conditioner
Looking for Watts and EER rating.
I need the watts and EER rating for Model UAKA-024JAZ, Serial #5882 M3301 04817.
Thank you,
Deanna Larsen
    Sergeant:
  • 340 Answers
Try ruud.com tech support or google . Tom
Posted on Jun 17, 2009
  • bryanw80231
    bryanw80231 Aug 03, 2012
    You should go to "Rudd.com" before posting for someone to go there. They aren't trying to buy a house.
Tip
Air Conditioner SEER Seasonal Energy Efficiency Ratio
Energy consumption for home air conditioning accounts for almost 5% of all the electricity produced in the USA. Energy Policy Act mandates minimum energy efficiency standards for commercial buildings, using research and standards developed by the American Society of Heating, Refrigerating, and Air Conditioning Engineers. Energy Star qualified central air conditioners have a higher seasonal efficiency rating (SEER) than standard models, which makes them about 14% more efficient than standard models. Energy efficiency specialists with certified training on retrofits and energy savings on both residential and light commercial units may enable you to save up to 50 percent on your air conditioning bills with the use of a high efficiency energy system. Substantial energy savings can be obtained from more efficient systems.
SEER (Seasonal Energy Efficiency Ratio) is related to the Energy Efficiency Ratio (EER), which is the ratio of output cooling in Btu/Hr and the input power in watts W at a given operating point and also to the coefficient of performance (COP) commonly used in thermodynamics. SEER rating more accurately reflects overall system efficiency on a seasonal basis and EER reflects the system’s energy efficiency at peak day operations.
The SEER rating is the Btu of cooling output during a typical cooling-season divided by the total electric energy input in watt-hours during the same period. SEER is related to the Energy Efficiency Ratio (EER), which is the ratio of output cooling in Btu/Hr and the input power in watts W at a given operating point and also to the coefficient of performance (COP) commonly used in thermodynamics. SEER rating more accurately reflects overall system efficiency on a seasonal basis and EER reflects the system’s energy efficiency at peak day operations. The higher the SEER number, the greater the efficiency of your unit. Therefore you will realize greater energy savings. The higher efficiency your product, the lower your long-term energy costs will be. Both central AC and air source heat pumps are rated according to seasonal energy efficiency ratio (SEER).
Before you consider upgrading your cooling equipment, the cheapest way to save money and energy from cooling is to reduce the need for mechanical air conditioning in the first place. Ask your contractor about a variable speed air handler, which will improve comfort and efficiency and allow continuous air filtering at minimum energy cost. Also, because ducts are often responsible for a lot of wasted energy, make sure you hire a contractor who knows about high-efficiency installations. If your central air conditioning unit is more than 12 years old, replacing it with an Energy Star qualified model could cut your cooling costs by 30 percent.
on Dec 14, 2009 | Heating & Cooling
Need manual for emerson quiet kool air conditoner model 12HT13?
I found this I hope it helps.
Performance BTU/H Cooling: EER: Voltage: Amps: Watts: Cooling Area (Sq. Ft.): Pints/Hour: Room Air Delivery (CFM): Plug Cap Amps: Plug Type: Dimensions Width: Depth: Height: Net Weight: Shipping Weight: http://www.appliancefactoryparts.com/airconditioners/emerson/12ht13.html#Manuals
Jun 02, 2014 | Emerson Quiet Kool 12HT13 Air Conditioner
How much horsepower does my intex Crystal Clear Model 635T filter pump have? I'm looking at a hth vacuum that requires at least 1/2 horse power. thanks
If the unit does not have the horsepower rating, but has the AMP rating, try this formula found in Answers.com
"Amps are a factor in calculating power, and so can be used to determine horsepower, but only when other factors are present.
Given other factors, you can find the horsepower. The easiest way is to determine watts by multiplying amps X volts. Next multiply watts by .00134 and you have horsepower.
If: amps (A)= 20 and volts (V)=120 then
A X V =2400 watts (W)
2400 watts X .00134 = 3.216 horsepower"
Hope this helps you???
Aug 14, 2011 | Intex Krystal Clear Model 635 Pool Filter...
I don't have a problem with my product...im trying to find out how many watts do my product use. Model #uamb-036jaz serial #6263f040410617
Brand: RUUD Manufacturer: RHEEM Model Number: UAMB-036J* Condenser Type: air-cooled Condenser Coil Model Number: RCGA-36A2 System Configuration: split-system air conditioner Cooling Capacity: 34,200 BTUHs per hour Efficiency: 12 SEER
10.5 EER Electrical Service: Single-phase Electrical Input: 3,272 watts per hour Voltage: 230 and 208
Jul 01, 2011 | Ruud UAMB Air Conditioner
I am trying to find out the watts for a Frigidaire Side By Side Model #GLRS234ZA. It is going to be used in Chile, South America and I would like to know how to make it work there. Thank you.
on the model # plate it will have the serial # also what type freon is used in it, and it will have the amperage or amps. when normally working for example let's say is 3.5 amps, this will need to be converted to watts and you can google for that formula to convert amps to watts.
Nov 08, 2010 | Frigidaire GLRS234ZA Side by Side...
Can you tell me what seer this unit is?
Divide the cooling capacity by the total watts. example 10,000 btu's divided by total watts ( voltage times current)
10000/(120 volts X 7.0 amps)
10000/840=11.9 eer
May 15, 2009 | Heating & Cooling
How can we caculate the energy needed by an air conditioner?
It depends on the (EER) Energy Efficiency Ratio,which is capacity divided by watts.
Example 35000 btus / 2500 watts = 14 EER
If you know the capacity,btus and EER you can calculate the watts, capacity / EER
Example 35000 btus / 14 EER = 2500 watts.
EER is determine by testing the air conditioner at Department of Energy Guidelines, which are
80° drybulb 67° wetbulb indoor and 95° and 82° drybulb outdoor.
May 14, 2009 | LG LS-K2430HL Heat Cool Mini Split Air...
Ruud UBHC Air Conditioner Logo
343 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
