Question about Video Cameras
I have a sanyo vpc -hd1010 (7 months old) the "zoom out" function has stopped working in both record and playback mode "zoom in" still works in both modes. camera has never been dropped or misused still under warranty in hong kong, but i'm in canada. hk warranty is no good to sanyo canada.
  • jrexthedecks Jun 17, 2009
    this is NOT a lens problem
    the sliding zoom button does not work in the "zoom out" position
  • jrexthedecks Jun 19, 2009
    do you have any idea what this kind of repair might cost?
    i've sent the unit in for a repair estimate with sanyo canada but to be covered under warranty in hong kong. so long as repair isn't too expensive the retailer with cover the cost of repair.
    thanks for your help
    President:
  • 987 Answers
You have sent it for repair ... contact +19052654100 ..it will be free of cost as it must be under warranty now..
Posted on Jun 19, 2009
  • 10,594 Answers
Seems Tele/Wide switch is damaged due to some reason so its T part is working and W stopped.
Since its new model camera so Sanyo service center can repair it because Control Switch block (that has few other switches too) is not available in parts shop.
Camera requires following control switch block.
Thanks.
Posted on Jun 17, 2009
  • 3,230 Answers
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life.
Fix #3: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens.
Good Luck!!
Thanks
Have an issue with my cameras zoom function. When I take pictures my zoom works perfectly but when I switch to record mode the zoom will no longer work.
Nikon Coolpix S220 Troubleshooting - iFixit
https://www.ifixit.com/Wiki/Nikon_Coolpix_S220_Troubleshooting
iFixitThe Nikon Coolpix S220 is a compact 10.0 Megapixel Digital Camera. Designed with a 2.5 inch LCD ... If camera is in Video Mode the optical zoom will not work.
Nikon Coolpix L810 Troubleshooting - iFixit
https://www.ifixit.com/Wiki/Nikon_Coolpix_L810_Troubleshooting
iFixitThe zoom function is not working while camera is on; Zoom is not available in ... If your camera does not turn on, make sure that the battery is fully charged. If after a charge the camera still doesn't turn on, your batteries may no longer be able ... modebutton, the playback button, or the movie record button doesn't work, turn ...
Nikon L830 review ' Cameralabs
www.cameralabs.com/reviews/Nikon_COOLPIX_L830/
Feb 05, 2016 | Nikon CoolPix 900 Digital Camera
Sony Handycam CCD-TRV37 8mm Analog... 2 Problems, maybe more unknown at this time:
This does require disassembly to remedy the problem. There are various possible fixes. The most prevelant I have seen is cold solder connections of the board connector for the fpc cable from the top operation switch block ass'y. All you need is someone who can handle this task, like a professional. The controls that you are experiencing problems with are all linked with one cable and connector. One bad solder joint can cause serveral operation faults. Good Luck, magic seadog
Aug 18, 2007 | Sony Handycam CCD-TRV37 Camcorder
I have a Sanyo Xacti FPC-FH1 with a 32g SDHC card. I can only get 4g of recording time. The recordings after 4g have a big" ? " in the display when I list the recordings in playback mode, and while...
You could plug the card into your computer using a card reader and then right-click on it. Click on properties and it will give you the used and unused space.
Jun 27, 2010 | Sanyo Xacti VPC-S60 Digital Camera
My Sanyo Xacti VPC CG-10 HD Dual Camera is broken
its could be but if your tech you can fixed,
if not
you better see a technician whit experience
its the best i can tell...
Feb 07, 2010 | Sanyo VPC-CG10 High Definition Camcorder
My camera's digital zoom in/zoom out is suddenly not working!
There is some minor problem in your lense motor. Go to any sony service centre. That people will help you.
Nov 29, 2008 | Sanyo VPC-E760 Digital Camera
LCD Screen Stays Black
Had the same problem. It nearly drove me mad, however, the fix seems quite simple. The screen in playback mode seemed to be fine but if I swithed to record or photo mode I just got a black screen. I could see some pixel movement so I figured the screen was okay and that the iris was the problem.
Anyway, to fix it I simply gave a few sharp taps on the camera body near the lens. This unstuck the iris and I was greeted with a clear image in the LCD viewfinder. The camera now works fine.
By the way, this seems to be a fairly common problem with a lot of the different models and not just limited to this one.
Hope this helps.
Nov 25, 2008 | Sanyo Xacti C6 Camcorder
My sanyo vpc-e760 digital camera is showing lens error:22 what do i do
well i have a SANYO camera and every time i cut it on it cuts on a little bit and i see it and it sais lens error: 308 what does that mean?
Oct 08, 2008 | Sanyo VPC-E760 Digital Camera
Sanyo VPC-T850, only a month old turns on but automatically shuts back off. We have charged the battery, but it doesn't seem to work.
return the product for a full refund... you get what you pay for... cheap camera and you will get cheap functions
Aug 14, 2008 | Cameras
Regarding RECORD button is not functioning
Unfortunately only way is to replace control unit.
Jun 07, 2008 | Sanyo VPC-HD1 HDV Digital Camcorder
Sanyo Xacti VPC-HD1- doesn't do anything in record mode
As I have been writing on other HD1/2 problems, sometimes it can be the card which is an issue. If the card is too slow or perhaps corrupted then the device can find it difficult to record.
This and other soft faults (that are reperable by turning the power on and off, changing or reinserting the card, removing the battery) are often indicated by a flashing red recording light.
Apr 25, 2008 | Sanyo Xacti VPC-HD1000 Flash Media...
Video Cameras Logo
70 people viewed this question
Top Video Cameras Experts
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
