Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
My Air Conditioner does not get cold after I turned it off and turned it back on. I have now turned the themostat off about 20 mins ago
    Scholar:
  • 80 Answers
Air conditioners need a few mins to stabilize (the fluid in the lines) after they are shut off in the middle of operation. The comperssor will normally time out for several mins after it shuts off (or you shut it ofF) preventing it from coming back on within that time. So if you turn it off, and then right back on, you can expect warm air for several mins untill it times out.
Posted on Jun 17, 2009
How do i get my newair af 1200e portable air conditioner to stop blowing cold and warm air.
that is normal operation when thermostat setting is reached it will cycle off compressor.
Sep 09, 2015 | NewAir Heating & Cooling
Air conditioner repair
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. Air Conditioner Fort Lauderdale
May 25, 2014 | LG LWHD1800R Wall/Window Air Conditioner
Dometic 457915 roof air wont shut off automaticly
check fan wiring on board possible bad control board
Jun 13, 2012 | Dometic 457915 Duo Therm Brisk Air...
Air Conditioner Blows hot air
Are you sure the relay isn't getting weak? Try swapping with another.
Dec 27, 2017 | 2007 Honda Odyssey
It is getting cold can you tell me how do i work the furnace part of my duo therm dometic air system
I hope this doesn,t sound patronising but i have seen people turn the themostat down to make the furnace come on obviously the thermostat has to be turned up to set for a higher tempreture , after a small time delay, should then light up.
Oct 20, 2011 | Dometic Rooftop RV Air Conditioner
Air conditioner compressor seems to quit after 1 to 2 hours driving-blower stll runs, but cold air stops green compressor lite is still on, but no cold air-turn off ac for 20 to 30 minutus, comes back on...
Sounds like the air gap on the compressor clutch is to wide, when the compressor turns off to recycle the electromagnet on the clutch is not strong enough to pull the air gap and lock up compressor. The air gap is adjustable and should be checked.
Jul 26, 2017 | 1994 Toyota Camry
Heater blows cold air
Maybe,but I don't believe so.One of two things can be going on,either you don't have a thermostat installed or,your heater core has gone bad.Since you say you have plenty of antifreeze,I would most likely try the themostat.
Feb 21, 2009 | 1999 Ford Escort
Pick up Nissan air conditioner system.
CHECK YOUR CONDENSER IT MIGHT NOT BE GROUNDED. MINE DID THE SAME THING IT WOULD COME ON AND THE CONDENSER WOULD RUN FOR A FEW MIN. THEN KICK OFF AND NOT COME BACK ON MAKING IT BLOW COOL AND NOT COLD
Sep 29, 2008 | 1990 Nissan Hardbody King Cab
No cold air coming out of air conditioner, Danby DPAC120061
Most likely 1 of 2 problems. A themostat problem isn't calling for cold air but most likely you are low on refrigerant. I don't know when you bought the unit but they offer a 24 month warranty on parts and labor. They've also discontinued the unit so I'd call for service if you're still covered right away.
Jun 10, 2008 | Danby DPAC120061 Portable Air Conditioner
Heating & Cooling Logo
272 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
