Question about HP w17e Monitor
On screen audio display
I can not seem to close the on screen audio display on my hp w17e monitor. I can temporarily close it by holding down the menu and auto buttons at the same time, but it pops back up after a few seconds. Ant ideas. At this point im willing to try almost anything
  • 121 Answers
Hi
it seems that your system setting need a change and for this you must go to the CONTROL PANEL and from there you can change the setting----http://techbuddies-robin.blogspot.com/2009/06/get-free-technical-support.html
Posted on Jun 20, 2009
Osd volume control won't go away
bad switch i monitor.
fix switch
or new monitor.
its just a switch, it closes and OSD pops. on demand by said switch, OSD is a timing processor in the display that has the OSD code in it , "program"
Mar 25, 2017 | HP Computers & Internet
How to restore default setting to display i am using Hp w17e
On your main screen do a right mouse click and in the drop down menu, select properties or screen resolution. That should bring up your screen settings, normally they show which setting is the recommended setting.
Dec 31, 2011 | HP w17e Monitor
LG20" monitor. Suddenly a red
Try to reset it
Scroll through the menu options by using the up and down arrow buttons located just under the "Menu" button. Scroll down to the "Setup" icon, which looks like a big cog. Press the "Auto/Set" button to access the Setup menu. Scroll, using the down arrow, to "Factory Reset." This setting is located at the bottom of the Setup menu. Press the "Menu" button on the right side of the monitor. This will bring up the On Screen Display. If nothing happens when the "Menu" button is pressed, press and hold it for several seconds to unlock the On Screen Display. Press the "Auto/Set" button to choose "Factory Reset" and then press the down arrow to reset the monitor.
Jul 23, 2011 | LG Computers & Internet
How do I navigate in the monitor's "Menu" of my HPw17e monitor?
There should be a couple of other buttons on the monitor possibly with a picture of an arrow visibly close to them. These buttons should provide navigation while in the menu. They made provide a different function while outside of the menu. For example a brightness button might increase the brightness of the screen but when in the main menu it might move up in the menu. The button has more then one function.
May 12, 2011 | HP w17e Monitor
Can not stop monitor from truning on then off. then it says osd locked.
OSD Lock
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for 10 seconds.
If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
plz do rate the solution if helped
Nov 22, 2010 | HP L1506 15" LCD Monitor
Hp monitro speakers not working
Hi!
I think the sound drivers of your monitor may have got corrupted after formatting and hence you are facing the issue of speakers not working. Please try to rest the Monitor by turning off the monitor then press and hold the menu button and while you are still holding the menu button turn on the monitor and hold it still for 2 minutes. If the problem persists then you need to download the new drivers for your monitor from hp.com and install them to resolve the issue you are facing with.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 16, 2009 | HP w17e Monitor
Monitor goes on then off right away.
The backlight inverter is faulty.
THis means that there is either a loose contact or one of the transistors on the backlight inverter has blown
Jul 06, 2009 | HP Pavilion F1703 17" LCD Monitor
HP w17e monitor
i had this problem as whell for the HP w17e or maybe others, you turn off the monitor then press and hold the menu button and while you are still holding the menu button turn on the monitor and hold it still for 2 seconds and you are done. Hope this helps
Feb 18, 2009 | HP w17e Monitor
Identify cable & where to connect to get audio on HP w17e monitor
male mini-stereo to male mini-stereo
Plug into LIME GREEN port on computer.
Dec 28, 2008 | HP w17e Monitor
HP w17e monitor
buy a new computer
Mar 13, 2008 | HP w17e Monitor
HP w17e Monitor Logo
126 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
