Question about Avanti Washing Machines
I have a triton instaflow 10. There seems to be letting by water by through the overflow. What could be causing his?? thanks Barry Ballard 07949 251510
2 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: my washing machine overflows during what seems
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine.This fault indicated can be due to failure of the water level sensors causing overflow but in all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Posted on Apr 18, 2011
Miele 4066 Water overflowing
Yes - I agree with the above - the water tank has two magnets a low level and high level - both should move freely in the tank and float with the water level - they determine when the water solenoid is turned off and on - if stuck - it will cause the tank to overflow. If both magnets are there and they move freely - then the reed switch in the case in more than likely faulty.
Aug 19, 2014 | Miele Coffee System
My Kawasaki zero turn toro will run for 10 mins then overheating buzzer comes on. Motor does not seem to be getting hot although water in transferring between overflow tank and radiator. Finns are...
i have had radiators cores block restricting the water flow and yes it could also be an air lock check in a manual to c if it has a bleed screw or lift the front of the motorcycle in the air or make a ramp then fill ur coolent system might pay to check the thermostate??? hope helps
Feb 04, 2014 | kawasaki Motorcycles
Kenmore Model 78862891 freezer defrost drain keeps freezing up every month.
It can be issue with water valve its clogged and not letting the water to stop running and that is causing the overflow of water and that is getting freezed and then clogged.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Just bought a used westinghouse RJ275M fridge. It seems to work fine except for the noise - it has a low hum and rattling noise.
It can be compressor fan noise,may be motor getting overheated and causing noise.It has to be inspected.
These will help.
Thanks,.
I have a top mount Kenmore refrigerator, model no. 106.60272990, serial no. EK2929089. It is about 10 years old and works fine except for one problem that has kept recurring every 2-3 months over the last...
hey barry I had the same problem and i recently broke down and called a repair service, the repair person installed a small aluminum piece he refered to as a heat probe, on the heater coil which is behind the back plate in the freezer, he claims this will solve the problem, evidently the water created in the defrost cycle freezes before it can get down the drain, thus the drain becomes blocked with ice, subsequent cycling of the heater for defrost causes more water and ice buildup and the water overflows through air ducts into the refridgerator, I would check at an appilance parts store for this part it cost $20, unfortunatley the total cost of the service call was $ 227, My gripe is this is an obvious flaw in design and should have beeen addressed by Kenmore, if you make a part to remedy a problem then its an admission of the problem! Good Luck!
May 27, 2011 | Kenmore Top Freezer Refrigerator
The unit overflows on an inconsistent basis. It
Check the inlet water solenoid.
Apr 15, 2010 | Dishwashers
Triton Shower is not working at all after a years great service.
FIRST TURN OFF POWER SUPPLY THEN OPEN UP THE CASE AND INSPECT THE WATER PUMP FOR ANY BUILD UP OF SCALE IF SO CLEAN WITH A GOOD SCALE REMOVER, ALSO CHECK THE PUMP IS NOT FAULTY AS THIS COULD BE THE CAUSE OF YOUR PROBLEM , ALSO CHECK FOR ANY LOOSE WIRE CONECTIONS .
Nov 11, 2009 | Home
The washer overflowed today. Does not seem to be
Overflowing is caused by the pressure switch, it needs to be replaced. Regarding the cold water, it is a water valve issue.
Both needs to be replaced.
Nov 02, 2009 | Washing Machines
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
I was washing pillows and water just overflowed - I'm not sure from where. I think the bottom of the machine. Just a little bit of water. Did I ruin the motor?
If you let the tub fill, then put the pillows in, you may have caused the water level to overflow the outer tub somewhat. If you didn't smell smoke or hear any frying sounds, the motor is probably ok. Does the washer seem to operating normally?
Jul 30, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
221 people viewed this question
Top Avanti Washing Machines Experts
Jim Thurston
No_ky
Kolbrun...
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
