Question about Mag Innovision InnoVision LT765 17" Flat Panel LCD Monitor
Mag Innovision Model 780
Hi I am trying to adjust the screen size - can't find my manual for my monitor.
I know the buttons on the side, 3rd one down is the service menu - press it and you have a box with option - I know the top button advances the menu and cursor and highlights the next option---once you are on the (example horizontal adjustment icon - you press the 3rd button again to choose that adjustment option ---- BUT HOW DO YOU ADJUST ? UP OR DOWN - ADJUST LEFT OR RIGHT....the arrow keys don't work, the top 2 button on the side don't adjust the chosen option either....can't find the manual to download...help! Thanks!
Noggin
  • 944 Answers
SOURCE: MAG Innovision LT456s monitor power issue.
If you ask them nicely they just might tell you, else it's only $5 for a user manual(sorry no luck online); http://www.maginnovision.com/service.htm this link has a picture that maybe shows a power cable going to the bottom right (as you look at it) but it's hard to be sure; http://www.amazon.com/gp/product/customer-images/B0002CF06K/ref=cm_ciu_pdp_images_all/104-1966292-9407907?ie=UTF8&s=electronics#gallery this link shows what the power lead should be like - look for a hole that matches; http://cgi.ebay.ca/AC-power-adapter-for-MAG-innovision-lt456s-14-LCD_W0QQitemZ8824271526QQcategoryZ3698QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Hope this helps, if not ask again :)
Posted on Mar 17, 2007
SOURCE: Mag Innovision product # LT765s model #780
monitor is looking for the video signals--move mouse and try power on
Posted on Jan 19, 2008
  • 198 Answers
SOURCE: Mag Innovision LT776s Model 780
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
  • 198 Answers
SOURCE: MAG INNOVISION
Good Luck!
  • 2567 Answers
SOURCE: I have a 2002 MAG INNOVISION FLAT SCREEN MODEL
This could be a problem with the monitor's data cable. Try to check it & find if there is any bent pins on the connector.
If this is not the case, there could be a loose connection on the monitor's PCB, or a failing component. This needs to be checked by a qualified technician.
Posted on Apr 12, 2009
How to I get the speakers inside monitor to work?
I recently was given a MAG Model 780 too. I found the input for speakers just today. When looking at the monitor, on the left side behind the monitor you should be able to feel a flat horizontal surface. If you lay monitor down, you will see 2 mini-plug openings. These are your input spots for speakers/microphone. I believe pink is speakers & green is microphone.
Apr 13, 2011 | Mag Innovision InnoVision LT765 17" Flat...
I Can't locate power recepticle
It's on the back facing downwards.
Jan 27, 2008 | Mag Innovision LT776s 17" LCD Monitor
Tip
Setup Menu for MAG LT776 Model 780
I had a blank screen and went through the Setup tips here (in the blind) only to discover it was 3 bad caps on the PCB. I replaced them (tight fit) with more low-profile ones. They were swollen only, not burst or leaking. I put new 220uf 16V ones in, got my screen back.
I realized that it would be helpful if there were an image available for anyone troubleshooting, especially if not familiar with this model, or it's setup. I made the following image, maybe it will help someone in the future.
I see the image is resized for the forum, here is a link to a full size (700 x 850) viewing.
Full size Setup Screen
on Jul 17, 2011 | Mag Innovision LT776s 17" LCD Monitor
MAG LT765s monitor, model 780; where do i plug in adapter
Sometimes the power adapters on flat screens face the floor. So, if you look under the screen under the stand, you will likely see the plug.
May 22, 2010 | Mag Innovision InnoVision LT765 17" Flat...
Power supply to Mag 780 Model
No, it has a normal, seperate power cord. But the socket in the monitor is very small, it's a small round one. When facing the monitor from the back, it's located directly to the right of the monitor-stand, at the bottom-side of the screen. Just put the monitor on it's side to see it clearly.
It's all explained with pictures in your monitor's manual which you can download from the official website here: http://www.maginnovision.com/Support/Downloads.aspx?sn=464
Aug 23, 2009 | Mag Innovision LT776s 17" LCD Monitor
I have a 2002 MAG INNOVISION FLAT SCREEN MODEL 780. I use this monitor as a dual monitor with my lap top. However today I still can view everything but with a pink hue. I have gone to the color controls on...
Apr 12, 2009 | Mag Innovision Computers & Internet
Jan 07, 2008 | Mag Innovision LT776s 17" LCD Monitor
MAG monitor is all white
please change your ram immeditately or monitor itself because the life of monitor has been came to an end...
Dec 31, 2007 | Mag Innovision InnoVision LT765 17" Flat...
I need this information please
Try this site. I suspect however spares are not available. http://www.fixya.com/support/mag_innovision
Jun 02, 2007 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision InnoVision LT765 17" Flat Panel LCD Monitor Logo
157 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Jaime Hernandez
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
