Question about Kenmore 16.7 cu. ft. / 473 liter Upright Freezer 23725
Freezer quit (Kenmore Upright)
We accidentally left the door open a couple of inches for roughly 24 hours. The freezer no longer cools. I can hear a faint click and a very low hum (like a thermostat has clicked or something) for about 10 seconds every few minutes, but the compressor (or whatever) never kicks on and starts cooling. I cleaned it out and unplugged it overnight and tried again the next morning with the same result. Ideas?
Thanks in advance.
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 15, 2010
The freezer does not freeze anymore
Hello Rina;
My name is Peter. I am a retired field service technician.
You need to provide more information.
Upright freezers are very simple.
There is a label on the side wall witch has your model number on it.
1.) Locked in the defrost mode - If nothing is running except for the light being on then you are locked into defrost. Your defrost timer is in the back behind a metal plate. With a large flat head screw driver slowly turn the shaft clockwise one click at a time to turn the freezer on. If it turns on this component will have to be replaced.
25676024-2tl4mzw4ix4qkonroxm2e5ag-2-0.jpg Cost: $20.00
2.) Is your freezer cool? You may have a frozen drain and cooling coil. Un plug your freezer and leave the door open for 24 hours. After several hours check to see if you have water build up in the bottom of the freezer. If so, you are going to need to keep soaking up water unit there is no more.
3.) Can you hear the cooling fan running? These fans are $35-65.00.
4.) You may have a bad thermostat, bad defrost heater, or a refrigerant obstruction.
I need more information from you to determine the problem and the model number.
May 02, 2015 | Freezers
Magic Chef MCCF5WBX clicks but compressor won't come on
if it just hums or buzzez you will need to check the start capacitor on the compressor if it is stuffed you need to buy around 15uf---25uf cap @400volts depending on the size of the motor
Nov 19, 2012 | Magic Chef Chest Freezer MCCF5WBX
Door was left opened for sometime and freezing is not good now, what I should do
If the only fault was the door left open, switch off and defrost completely for 24 hours. Clean condensor coil. Restart and run for 12 hours before checking.
Aug 07, 2012 | Woods 201 cu. ft. Upright Freezer V2003RW3
We accidentally left our upright 20 cf frigidaire freezer door open for 24 hrs, all the food spoiled and now the freezer is not freezing and only cooling. Any ideas of what is wrong? thanks
THE UINT IS FROZE UP, YOU WILL NEED TO DEFROST IT. USE A FAN TO BLOW INTO THE FREEZER PORTION , AND HAVE LOTS OF BIG THIRSTY TOWELS HANDY .. THIS WILL TAKE ABOUT 2 HOURS TO DEFROST, WIPE EVERY THING INSIDE THE UNIT DRY !... JAY THE POOL PUMP MOTOR REPAIR GUY FLORIDA
Jul 28, 2011 | Frigidaire 20 cu. ft. / 566 liter Upright...
Left door open, closed next day, but only blowing cool air now
You will need to turn the unit off and let it completely unthaw. There is frost that builds up in the ducts and behind the panels when the door is left open that will cause the unit to not cool or circulate where needed.
May 10, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Won't freeze after door was left open
Having the door open has introduced an excess of humidity and therefore condensate/ice into the freezer coils. The coils are therefore iced over. You have choices depending upon your skill level. You might: allow the unit to sit unplugged with the door open until the excess ice thaws out and wets the floor underneath, which may take from 6 to 24 hours. You might: do this, adding some heat source in the freezer to accelerate the process. You might: locate the defrot timer, advancing the timer until a click is heard indicating the unit is in defrost, and repeat after about 15 minutes to defrost the unit with it's own heater. You might: let it recover just as it is but it will take a couple of days to clear itself.
May 19, 2009 | Hussmann Freezer 12 Facing Straight Glass...
Freezer defrosted and the motor won't start back up.
From what I can gather, you have a self defrosting freezer and the "motor" you speak of is the fan inside the freezer. If this is correct, do this:
Unplug freezer. Unload all food into coolers or other freezer space. Leave freezer door open for a day to allow it to manually defrost. Plug freezer back in after minimum 24 hours and confirm fan running and cooling before loading back up with food.
Mar 28, 2009 | GE 16.7 cu. ft. Upright Freezer FUF17DTR
Left the door open on my Freezer last night and now it doesnt wor
After looking at some advice from others I turned the internal dial to the OFF position, then turned it back to 6 or 7, and left it for 20 minutes, and it is now freezing again.
Jan 04, 2009 | Freezers
Freezer only freezing to 20 degrez
If the door was left ajar for any extended period frost has built up on the cooling coils. A complete defrost of the freezer should take care of the problem. Normally a frost free system will clear the ice from the cooling coil when the defrost time cycle happens. However frost may have built up in areas where the heaters can not readily remove it in a normal defrost cycle and shutting the unit down with the door open for about 24 hours should clear it out.
Nov 27, 2008 | Freezers
Freezer door left open
if the alarm is sounding its probably trelling you the freezer is at too high a temperature. plug it in and leave it plugged in, it can take several hours to re freeze
Sep 16, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore 16.7 cu. ft. / 473 liter Upright Freezer 23725 Logo
97 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
