AC accumulating water, not draining properly????
Was purchased used and cools GREAT, BUT water accumulates in the bottom. The fan hits it and sprays water out with the cold air. I have removed the dead frog and cleaned the filter. I can't seem to find the drain. Repairmen have said it shouldn't hurt anything except it may grow mold (not good) and the cost of repair would exceed the value. Does anyone know how I can get to the drain, easily? or not easily? I'll take any help I can get.
  • 1 more comment
  • marthabasket Jun 17, 2009
    This is a Goldstar WG5005 window air conditioner
    Thank you for your suggestions. There is NOT a drain hole anywhere on the unit. I took the unit out of the window and tilted it in every direction possible, except upside down, and could not get all of the accumulated water out. I had to use rags to dry it out. There has to be some kind of drain that is plugged up. Right????
  • seth veloso May 11, 2010
    hey there, this should be a fairly easy fix. First I need to know exactly what kind of unit you have, it sounds like a window unit, is that correct. Or is it a whole house air handler
    Scholar:
  • 80 Answers
For some reason, newer AC window units no longer are made with a fluid drain. I think the intent is for the unit to be mounted at a sufficient angle (it MUST be angled back so the fluid drains toward the back of the unit) that the rear (outside) fan kicks the water over the condenser coil and gets rid of it that way, it also increases cooling ability slightly in this manner by misting the condenser coil. I would suggest increasing the angle of the back tilt by adding a 2x4 maybe under the unit to allow it to tilt? Alternately, you can drill a hole in the rear corner of the unit to drain fluid, but this is not recommended for several reasons...
1) It will usually cause rust to start at the drill hole.
2) you could accidentally puncture the coil system while drilling
3) the manufacturer did not make a hole, because one was not intended.
Posted on Jun 17, 2009
  • 334 Answers
Ok usually there is a hole in the bottom of the unit in the portion that hangs outside. There may be an obstruction in and around the hole. The easiest way is to stick something into the hole. The best way is to take the unit apart and clean the bottom pan. Usually the unit will,slide out of the cabinet in towards the house. This will give you access to the pan. Let me know if this helps or not.
  • seth veloso Jun 17, 2009
    Wow, no drain is weird. I am sorry, I can't really think of any other suggestions for ya. Here is the tech support number for goldstar, it has to be a simple fix. Let me know if there is any other way I can help after you talk to them. Good Luck
    Tel: (800) 243-0000
Can ac condensor leak water on ss cobalt at bottom of pass side or could it be radiator leaks in front of duel fans
The a/c condenser doesn't leak water, but it certainly condenses the moisture out of the air (hence the name). The HVAC box is supposed to have a drain installed at the bottom to allow the condensation to run out (usually via a hose through the firewall). If this drain is blocked, the condensation will accumulate and leak into the passenger compartment.
Apr 17, 2018 | AC Cars & Trucks
HOW TO UNCLOG DRAIN PAIN IN AC WINDOW UNIT
There technically isn't a drain pan in AC units. Some have a little hole in the back, some do not. If they do not, then the evaporator fan "slings" up the water accumulated from the condensation in the air, unto the coil to help cool the inside of the unit. If there is no hole, do not drill into the machine. You are likely to hit a sealed system component and damage the unit entirely.
Jul 29, 2012 | Frigidaire Heating & Cooling
Hi! Just purchased AC model AJCQ08ACD. I installed it into the wall, ran it for abut an hour and noticed that the water accumulates in the pan and just stays there, after a while the main fan started to...
No this is not normal. take the cover off the unit and look between the fan and the indoor coil. Look down the coil and you will see that it sits in a pan. locate the drain hole in the pan and see if you left a plug in it.. alos be certain that any hoses attached to that drain are not crimped or plugged. Also tilt the unit a little bit to theout side of the window to insure a positive drain.. Let me know if this fixes the problem and I hope this helps
Jul 20, 2011 | GE AJCQ08ACD Air Conditioner
Water accumulation and ice buildup
There is already a hole just remove the ac unit from the window,and it`s shell,take it outside and use a water hose to clean it out,and remove anything on the inside that may stop up the drain hole.This needs to be done every year before spring or summer.If this was at all helpful,please rate,thank you.
Jul 12, 2010 | Samsung AW0891M Air Conditioner
Freezer fan is making noise so I took all food out used a hair dryier to try and melt some of the frost/ice behind the back panel. Before this all the food had frost on them. This is the second time I did...
you need to have someone check the defrost circuit. if the unit does not defrost properly , ice will accumulate on the back panel where the evaporator is, blocking the evaporator fans completely, and the circulation fan will eventually stop working because the ice buildup contacts the blades all the fan motor, and eventually the refrigerator compartment will start to get warmer and warmer because there is no circulation of cool air.
Mar 16, 2010 | LG LFX25960ST Stainless Steel French Door...
The water that drains from the airconditioner to outsied is clogged up and not draining how can i unclogg it myself?
I can tell you a few stories of my own - I've had this problem myself and water will eventually build up and leak inside your house - you don't want it to leak on your electrical outlet ! I do not know how long you had this unit or how old is it, but these things can happen over time due to dirt, dust or other foreign objects or rust. Some AC units have fan spinning and picking up the water and spraying it on evaporators, most of it should be evaporated - only excess humidity will cause dripping - on older models water should drip outside through an opening or two at the back of the AC unit.
Make sure your AC is not level, and is tilted about 20 degrees outside, allowing the water to flow outside the AC unit.
You will need to find a way to access your AC unit from outside, locate the areas where the water drips normally, you should see openings, using an object (paper clip, pipe cleaner, etc.) try to insert it in the holes back and forth until you dislodge whatever is blocking the hole - be careful not to damage the very deliate fins at the back of your AC.
if still no water drips then take a ladder and climb up and you shuold be able to see from the inside there should be a slope or container where water accumulates before dripping out, is there ANY water there ? If you mostly see water farther away then your AC is probably not tilted enough to allow water to flow out.
If there is neither any water towards the outer edge where it drips, nor inside, farther away nor dripping inside your home, then it is probably being all evaporated or your humidity level is under control. The more your air has moisture the more water will be produced inside your AC, any excess moisture will accumulate inside your AC - if your AC manages to evaporate all of it, and no leaks inside, good for you, I wouldn't touch it.
Another tip - when you shut down your AC, do you hear swishing and unusual sounds of water ? that could mean accumulated water not being evacuated - Although it IS normal for some stagnant water to remain in your AC - do not worry about that, as long as it doesn't leak inside.
Sep 01, 2009 | Heating & Cooling
Water accumulating in bottom of kenmore
It's likely the condensate drain is plugged. You can access it from the back of the refrigerator. You can disconnect from the inside of the fridge and blow it out to ensure it is not blocked, then reconnect.
Aug 15, 2009 | Refrigerators
Water dripping out of freezer into bottom of refrigator
It is normal for water to run from the freezer to the bottom of the refrigerator during the automatic defrost cycle. But it is supposed to run into a catch pan and be evaporated by the hot air being pulled over it by the small evaporator fan on the bottom of the unit.
If water is not going into the catch pan, and instead is running out of the evaporator down the side of the liner, it will most likely end up on the floor instead of in the catch pan. If this is the case, drain your line could be stopped up with an accumulation of algae. To clean it out, find the drain plug in your freezer and pour a cup of diluted bleach into it. Pour it very slowly, because if the line is completely stopped up, it will not seep out and thus cannot get to the point of blockage.
If the drain is completely blocked, try using a can of compressed air (like is used to blow off computers and such), forming as tight a seal as you can between the air tube and the drain. If this fails, it might be time to call the repairman.
There is one more thing that might give the appearance of water 'leaking' and that is if the condenser fan is not properly pulling air over the drain pan to dry up the water from a self-defrost cycle (which normally occurs every 24 hrs). In this case, cooling will also be severely affected, since insufficient air flow over the condenser coils will make the condenser far less efficient.
Finally, and maybe you shoud try this first if you're sure the drain line is not stopped up: CLEAN THE BOTTOM COILS of dirt and lint accumulation. I can't tell you how many refrigerators I've worked on that needed nothing more than to have the condenser coils in the bottom of the unit cleaned. Restricted air flow over these coils is THE number one cause of refrigerator inefficiency or failure. By a HUGE margin.
Jun 28, 2009 | Refrigerators
Water accumulating in bottom of freezer
The water was not coming from the dispenser or the ice maker. It is a result of a plugged defrost drain tube.
When the refrigerator goes into defrost, if the water is unable to get out the defrost drain, it ends up on the floor of the freezer. You will have to clear out the defrost drain. It is a tube which is behind the back wall of the freezer compartment, at the very bottom of the cooling coils. Use a turkey baster with hot (not boiling) water to flush it out until the water runs out the drain (and into the defrost drain pan under the refrigerator where it will evaporate as the fan blows air over it).
Dec 10, 2008 | Frigidaire Refrigerators
Need to find fan for AC# DVAC10038EE. Hi, need to find this fan for my new AC, was busted while trying to make hole in bottom as too much water accumulated. Any idea where this item could be...
Hey, sound like it as doing its job, to remove moisture ans send it to the back bottom coils ,which it suppose to cool the hot gases on the bottom run of coils then if too much water , it runs out the drain hole. You didn't say the fan blades or the fan motor?
Aug 26, 2008 | Danby Heating & Cooling
Heating & Cooling Logo
1,835 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
