Question about Xerox Phaser 6120N Printer
Error 12 laser unit - Xerox Phaser 6120N Printer
  • 43 Answers
Turn off the printer.
Remove the toner and fuzer units.. Replace
Power on the printer.
Posted on Jun 17, 2009
My printer shows scanner error 12
Don't confuse scanner error with scanner section. sometimes HP calls LASER unit as scanner. Check laser unit
Sep 23, 2013 | HP LaserJet M1005 Printer
Hello, if this is the corect error then:
FM4 controller cooling fan
cools the laser unit,
developing block drive
block, and controller yes
(24/12 V)
E121-0001
In the back of the scanner unit there is a fan, check if that fan is working, if not replace it.
Jan 14, 2013 | Canon Toner Cartridge For Cnm Ir 6570,...
Scanner 12 error
HP LaserJet M1005 mfp is not work properly. printer show scanner error 12 ple. solution
Nov 08, 2012 | HP LaserJet M1005 All-In-One Printer
In my laser jet M1005 printer showing the scanner error 12
It could be dusty in the cis unit or scanner unit as its called.you will need to remove the glass and clean the scanner
Oct 29, 2012 | HP LaserJet M1005 Printer
Error code E01-22
The error E01-22 means polygon motor synchronization error.
The possible causes for the error is problem with ;
- engine pcb
- laser unit
- lvps
- sc pcb
You can try to reseat the connectors, else you may need to replace the board.
Nov 04, 2010 | Panasonic Office Equipment & Supplies
SCANNER ERROR 12
in my laser jet M1005 printer showing the scanner error 12. kindly help me how i can solve the problem.
E-mail : jkmeher@yahoo.com
Jul 13, 2009 | HP LaserJet M1005 Printer
CD not working. Error 12 message
error 12 is a read problem.
Most of the time it is an alignemt problem with the laser.
Sometimes it can be the mechanism, or vary rarely a dirty laser lense, or disc.
This error message merely means that it cannot play the disc. It is usually due to the laser diode inside the optical pickup head is weak, misaligned, or defective. But, it could also mean the tracking and focus adjustments have been jarred too far out. Or, it could be mean the servo controller for the head and motor drive has gone bad. Anything that prevents the system from reading the digital information on the surface of the disc will bring up the error code.
So, you must either have it serviced to find out the cause - or just replace it. This model is no longer current but there are many from Pioneer and others that could be an equivalent unit.
Apr 08, 2009 | Car Audio & Video
Xerox DC12 gives error 14-372 please HELP!!
ERROR 14-372 ROS MOTOR FAIL , ITS THE MOTOR THAT ROTATES THE POLYGON OF THE LASER BEAM , ITS LOCATED , BELOW THE SCANNER UNIT AND OVER THE COPY/PRINT CTG. 13R557/13R558 . IT CAN BE ONE OF 3 THINGS THE ROS ASSY. (LASER SCANNER UNIT OR ROS) , IOT DRIVE PWB(THE PC BOARD BELOW THE NVM AND IOT-SYS) OR A PROBLEM ON THE WIRING HARNESS / POWER SUPPLY. WE CAN REPAIR THOSE UNITS OR I CAN PROVIDE YOU THE PART NUMBERS IF YOU WANT TO ORDER THEM NEW FROM XEROX . diesco_cxl@hotmail.com
Mar 23, 2009 | Xerox DocuColor 12 Printer
Laser Error Error message 061-370 for Xerox Phaser 6125
From the service manual:
Troubleshooting Procedure Table
Step Actions and Questions Yes No
1 Check the Laser Unit for correct
installation.
Is the Laser Unit correctly installed?
Go to step 3. Reinstall the
Laser Unit. Go
to step 2.
2 Cycle the power.
Does the error still occur?
Go to step 3. Complete.
3 Check the wiring harness connectors
P/J40, P/J41, P/J411, and P/J412
between the MCU Board and the Laser
Unit.
Are the connectors securely
connected?
Go to step 5 Reconnect the
connectors. Go
to step 4.
4 Cycle the power.
Go to step 5. Complete.
5 Replace the Laser Unit (page 8-31).
Replace the
MCU Board
(page 8-59).
Complete.
Jan 31, 2009 | Xerox Phaser 6125 Laser Printer
Xerox Phaser 6120N Printer Logo
112 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
