In my home office I am using an airlink 101 802.11g wireless usb 2.0 adapter to connect with my airlink 101 super g wireless router on my main computer. Everything has worked well, but today my office computer is unable to bring up any internet sites even though it is showing strong connectivity. The main computer is having no internet proplems. How can I fix this?
  • 4,806 Answers
Hi.
This method will hard reset the wireless drivers back to default settings.
What i want you to do is right click "computer" select "manage" and then "device manager", a list will populate, then click on the + sign next to "network adapters" and right click on the wireless adapter and "un-install" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again.
Good luck
Posted on Jun 17, 2009
I have a F7D2101 Surf & Share Wireless USB Adapter and I have a wired internet connection. Can i use the surf and share USB adaprtor to share the internet (Creating a hotspot) between my desktop and...
You need wireless router for your usb adapter if you want to share your internet connection. Just an example if you have 2 laptop which dont have wireless adapters then you need 2 usb wireless adapters.
Sep 06, 2011 | Computers & Internet
Airlink adapter and att router access problems
Make sure you have the most up to date drivers for both your mini usb adapter and your router.
The 64 bit version of windows 7 may not have the right driver for your equipment.
Will get better with time.
Good luck.
Jul 04, 2010 | Airlink (AWLC3025) Wireless Adapter
Belkin wireless adapter trying to connect to Airlink 101 router
Did you type in the wep key and confirm it?It will not work is you type it in once only.
Nov 12, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Can't connect through my wireless G network adapter.
Give the default gateway address of your laptop computer in the desktop computer. this will solve your issue.
Sep 02, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
My Wireless connection status page is blank. Same with the wireless connection properties page and the "view available networks page"(or wireless network connection page) can't open, all it has is the top...
The AWL number was what I was looking for, thanx.
If the AirLink utility is running, there is where you would check the status. The way to set it so that the connection shows in the 'network connections '
Go into your Control Panel, then go into Network Connections
Right click on your AirLink wireless adapter and click “Properties”
Click on the “Wireless Networks” tab
Put a check in the box next to “Use Windows to configure my wireless network settings”
Click “OK”
If you wish to go back to using the AirLink101 802.11g Cardbus Utility, go back into the “Wireless Networks” tab in your AirLink adapter’s properties and remove the check mark next to “Use Windows to configure my wireless network settings”
Aug 03, 2009 | Computers & Internet
Have an airlink card bus
If you have access to change the wireless routers channel do that. Log onto your router from the wired connection probably 192.168.x.1 (x is your subnet, find this by going to run>type cmd>hit enter>type ipconfig>hit enter the gateway IP should be your router
type that ip in a browser i.e. http://192.168.x.1 and log in go to wireless settings and find the channel option. usually you'll want to keep it at 1,6, or 11
(if your wireless utility doesn't show channels) go to your wireless pc and install netstumbler > install it > click the scan button and you should see all of access points around you. choose a channel that is used the least between 1, 6 and 11 and save that as your new channel on the router, as you are probably getting a lot of interference.
second try using the built in windows utility instead of the airlink one
also
update network drivers
update router firmware
don't sit around large metal objects :)
Jun 10, 2009 | Airlink (AWLH4130) 802.11g/b Wireless...
I'd like to use my Airlink 101 802.11g wireless router as an access point in my home office. Is that possible?
if it is a wireless router (no modem functions), then you would need to have it connected to your modem so you could set it up as your access point.
Jun 05, 2009 | Airlink AR430W Wireless Router
I need driver for pcmcia airlink awlc4030 wireless cardbus adapter
http://www.modem-help.co.uk/AirLink101/AWLC4030-Super-G-Wireless-Cardbus-Adapter.html
go to his site and download it
May 06, 2009 | Airlink AWLC4030 Super G 802.11g/b...
Cannot Communicate from Computer to Computer
A connection from USB adapter directly to USB adapter may or may not be possible. Borrow a wireless router from someone and use it to test supporting connections to your two computers. I think you will find this a much easier way to proceed. Routers can be had for $40 or less. Shop around.
Good Luck
Gus
Nov 18, 2008 | Linksys Wireless-G WUSB54G 802.11g/b
HELP PLEASE ASAP
OK well I think it is better to set it up like this... Connect the Modem to the Phone Line, Connect the Modem to the Router with an Ethernet Cable, Use a CABLE connection from the Main PC to the Router. (Ya gonna ditch the USB WiFi) Set that Main PC connection up to connect to the internet from the Main PC, thru Router thru Modem.... Then from Slave, install the USB adapter in this PC, and use this to connect DIRECTLY to the WiFi Router... and thus to the internet. This way will give the best transfer rates, and reliability
Sep 15, 2007 | Actiontec GT704WG Wireless Router...
Computers & Internet Logo
109 people viewed this question
Alun Cox
David Payne
David Payne
