How to reprogram portable AC unit ?
I need to cool down very small room to 50F. The lowest temperature in the unit is 62F.
EVERSTAR Mod # MPN1-095CR BB6
    Sergeant:
  • 340 Answers
You cant its burned in the chip maybe parallel a mechanicalrefrigeration thermostat. that goes to 50F. Tom
Posted on Jun 17, 2009
Question why my machine is stuck on F shouldn't it be on C?
Posted on May 27, 2011
Can the freon in my everstar pottable air conditioner MPM2-10CR-BB6 be reaplaced and how
If there's a will there's a way. But, why are you replacing the refrigerant? Is there a leak? Did the compressor burn out? Honestly repairs to those units exceed their value.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 26, 2017 | Heating & Cooling
Cool air when running; warm air when compressor is off.
It sounds as if warm outside air is being drawn back into the room when the unit is not actively cooling. Portable units depend on room air to carry the heat outside, & therefore will not work properly if the room is too airtight. Provide a makeup air passage by leaving the door slightly open, & see if this helps. Use a room thermometer to see if your desired temperature is being reached. Note that if the wind is strong & coming from the wrong direction, it may not be possible to prevent warm air drawback.
Jul 10, 2007 | Sharp CV-P09FX Air Conditioner
Ok So We Bought This. But We Have A Problem Does It Take Water Or Not? Thats What I Need To Know! Please Help!
The DeLonghi PACA120E Portable Air Conditioner quickly cools rooms up to 400 square feet and comes equipped with several functions that make operation easy and low maintenance. Its 3 operating modes are supplemented with no-drip technology, an adjustable thermostat, 24-hour timer, and much more. This unit truly takes the work out of cooling medium- to large-sized spaces. Multiple Modes and Functions The DeLonghi A120E-also known as the Delonghi Pinguino PAC A120E-offers 3 operating modes and 3 additional operating functions that make this model versatile and energy efficient. Cool Mode: 12,000 BTUs of cooling power help cool large rooms, offices, or basements. Dry Mode: Reduce room humidity by removing excess moisture from the air. Fan Mode: Circulate air to keep your room comfortable without using a lot of energy. Low, medium, high, and an auto-speed are all included (auto speed selects a fan speed for you). Smart Function: Your AC uses Cool and Fan mode based on ambient room temperature. This function will also select your fan speed and keeps your room comfortable without wasting energy. Sleep Function: Using a low fan speed, the AC gradually reduces operation so your room remains comfortable but the AC runs more quietly and efficiently while you sleep. Boost Function: This function is ideal for the summer months and uses the maximum fan speed to rapidly reduce your room temperature. Useful Features Using DeLonghi's patented no-drip technology, this unit is "dripless" under normal conditions, meaning the AC will discharge all of the moisture collected from the air-so you typically won't have to worry about draining the water. When dehumidifying a lot of moisture in Dry mode, excess water may collect in the internal collection tank. Once the tank is full, the air conditioner will automatically turn off to avoid overflow damage. You can also use the included continuous drain hose as a no-fuss way to eliminate excess water as needed. An adjustable thermostat provides additional convenience by allowing you to set your room temperature. The DeLonghi portable AC will cycle on and off to eliminate over-cooling and maintain the set temperature. Additional Features Washable Air Filter: A washable air filter helps remove allergens and other particles from incoming air and saves you money on replacement filters. Quiet Operation: High efficiency compressor and components result in quiet performance. Electronic Controls: The LCD screen displays the timer and temperature settings, while intuitive indicator lights accompany each operating mode. 24-Hour Timer: This feature lets you program your AC to turn on or off up to 24 hours in advance, so it only runs when needed. Window Bracket: Double window bracket is included with purchase for flexible installation. Self-Diagnosis System: The unit includes a self-diagnostic maintenance system that identifies malfunctions should they occur. Remote Control: Use the full-featured remote control to change modes, set the timer, and select a fan speed up to 23 feet away from the receiver (on the front of the unit). Portability: Easy-roll casters and dual carrying handles make it simple to move this model from space to space.
Aug 06, 2012 | DeLonghi PAC A120E 12000 BTU Portable Air...
Why is my everstar air conditioner mpm1-10cr-bb6 only show numbers 2 4 and 6
Does it cycle past 2-4-6? and if so does it stop eventually on a number?
if so i think you may just have one of the LCD numbers on the read out burned out. the lowest setting is 62 deg. so if it stops at 2 by pushing the down button then thats your problem.
Does the unit work fine besides that?
Jul 29, 2012 | Heating & Cooling
My everstar portable ac is not running properly. In cool mode only the fan is running if I shut off the unit and restart the compressor comes on and then shuts right off the green light blinks briefly and...
Ed, there are several things that can cause this problem, but all are solvable.
1. The current temperature setting is not low enough.
2. The air intake filter needs to be removed and cleaned.
3. The water collection tank is full and needs to be drained.
4. Obstruction in the exhaust hose(s).
Be sure to turn the unit OFF & unplug it, before attempting any service work on the unit.
Hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 12, 2011 | Whynter Portable Air Conditioner
AC was cooling fine. Now, won't cool room even though cool air comes out. Exhaust hose is extremely hot.
Check filter, if you have a 5000BTU unit (small) and it is extremely hot, then it wont work great for a big room. BTU is the rate of what the AC will put out. 5000 BTU is good for a small single room. 10,000 will cool a bigger room and 18,000 btu is meant to cool a home.
Jul 07, 2010 | Whirlpool ACP102PS Portable Air...
I have an LG AC and the lowest temperature setting is 60 degrees
Lowering the temperature setting doesn't change the temperature of the air coming out of the unit it just lets it run until the room temperature gets colder. Check the temp of the air coming out of the unit. If it isn't as cold as it used to be the charge could be low. First though you should make sure the filters are clean and the coils.You should also check the actual room temp. It's also possible the unit doesn't have enough capacity to keep up with the cooling load of the room.
May 02, 2010 | LG Heat cool Window Air Conditioner
Have a portable everstar ac model MPM2-10CR-BB6 blow strong but no cold air.
check temperature setting and the mode on cool if ok check the compressor is working with condenser fan if are working the unit has a loss of refrigerant . if the compressor is not working and voltage is correct may be the capacitor need replacement
Sep 03, 2009 | Heating & Cooling
Heating & Cooling Logo
398 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
