Question about Pioneer DJm500 Professional DJ Mixer W/Effects System
Bass rotary switch
Every now and then when i use the bass rotary switch on me mixer it either cuts out or brings the bass full in
  • 42 Answers
The roatary switch is junk. One of the tangs on the switch is bent or broken, and its not holding the correct freq or signal. You can get a hold of Cherry Switches(on line). Or take the switch out, make a drawing of how it is wired, or how it mounts on the circuit board, bring the switch to an electronic shop, and ask for a replacement. You may need a solder gun, some tinning flux, and a pair of pliers, (cutting pliers as well) to desolder the switch. the switch could be a single or double to 12 pole switch with single to mutiple poles. So if you don't know that, I suggest you bring it an electronical shop. You can do this yourself, but make sure to make a drawing, number the steps, and make a hand wiring diagram. Good Luck I hpope this works for you.
Posted on Jun 17, 2009
How to hook up bose b1 module into yamaha emx 5000
The Bose B1 bass module is designed to handle up to 125 watts into 8 ohms 40-200 Hz.
The Yamaha EMX 5000 is full 500 watts, and full range. This is not a particularly good match.
EMX5000 Powered Mixers Mixers Live Sound Products Yamaha United States B1 Bass Module Bose L1 Encyclopedia FAQ Wiki
Apr 29, 2014 | Bose Audio Players & Recorders
Behringer djx700 has no bass
Check that all the eqs are set not to cut bass, check there are no effects on and that the XPQ is off. If you still have the problem how sure are you there is no bass coming from the mixer? Have you tried it with another amp? We had one hire customer who had the same problem you describe and his amp had a crossover and it was set to act as a mid/top amp and wasn't giving him any bass, unsurprisingly, switching it back to full range sorted it.
Dec 27, 2013 | Behringer DJx700 5-Channel Pro DJ Mixer...
I have found the fault with my mixer ( UB2442fx pro) but I need to be able to identify 2 components that need replacing. The first is the rotary pot vr96 (aux 3 / fx) and the second is the rotary...
The VR96 is a 50K "G" taper or "graphic taper" pot. Lots of luck trying to find that in a catalog... I finally got a scrapped piece of mixer board and salvaged one. The G taper is not stocked by any of the vendors like Digikey or Mouser here. Full Compass is the Behringer part distributor and I waited 6 months and got no delivery of one of these pots. The effects selector is a rotary encoder quadrature type. Use the Mouser.com catalog. Search for Encoder, then select ALPS manufacturer and then try to match up mounting and type using the spec drawings... with push switch also... Again, if you want to try Full Compass, you can call Behringer rep in Woodinville WA USA to get the Behringer part number and incident number to see if Full Compass might have one in stock.
Here is the maintenance schematics for your unit...VR96 is on page 7 of 32. :
http://elektrotanya.com/behringer_ub2442fx-pro_sm.pdf/download.html
Scroll down to "get manual" and click on it to download. IGNORE other download links as they are for viewers, etc.
Note, You may have to cut off a shaft on replacement to the right length to match existing shaft.
Jul 08, 2011 | Behringer EURORACK UB2442FX PRO Mixer
What is the best way to run a Bass thrue the mixer , Mike the Amp or directley thrue the mixer, we had problems with a clear sound?
The easiest way is to take the line out from the bass amp and connect it to the line in socket of the mixer ( not the XLR Mic in ). This will give a clean and flat sound which you will have to customize using the Mixer tone control and not the bass amp controls.
May 01, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
Drilling slowly
If the battery is OK then the problem will be in the variable speed trigger switch.
Sep 24, 2009 | Dewalt DW999K 7/8" Cordless SDS Rotary...
Delay on low frequency EQ
The bass pot's / controls are notorious for becoming dry jointed, all that is usually needed is the controls resoldering.
http://www.technicsdjuk.com/
Apr 22, 2009 | Pioneer DJM-600 Silver Professional DJ...
Pioneer DJM500 Mixer - Bass EQ Control on Channel 2
You might want to clean the exisiting potentiometer with dielectric solvent. This might work without having to replace the Pot. But if you have to replace it, make sure you have the correct tools. This is a fine soldering job, but it appears you have the correct part.
Apr 07, 2009 | Pioneer DJm500 Professional DJ Mixer...
Pioneer DJM 500 Ch 2 Bass Controller
Apr 01, 2009 | Pioneer DJm500 Professional DJ Mixer...
The main bus on my behringer 2222 mixer has gone. nothing patched to the main bus comes up on the main vu meter, and only a feint distorted noise comes out of the headhones when the main bus is turned up...
please make all your fader down-all your rotary control at middle(12 oclock position)------all your pressed pushbuttons in up position--disconnect all inputs cables----use good new cables for outputs---bring a good mic and connect it to any channel and raise its fader up and main mix faders up and check if the problem solved check your cables and your pressed button if not better to contact a good service center.
Aug 17, 2008 | Audio Players & Recorders
BASS KNOBS
please bring a good brand lubricant contact cleaner and apply it in knob and move it forward and back.(you can get it from radio shack near you).
May 30, 2008 | Pioneer DJM-600 Silver Professional DJ...
Pioneer DJm500 Professional DJ Mixer W/Effects System Logo
337 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
