Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Where do i find the inlet valve - Frigidaire FRS3R5EMB Side by Side Refrigerator
  • 111 Answers
In the back of the unit lower right corner
Posted on Jun 17, 2009
Kawasaki zzr1100c what is the valve clearence
hi there,
this table will help you. I used to own one.. beautiful bikes easy to work on too!
Valves:
Valve clearance: Inlet 0.13 0.19 mm
Exhaust 0.18 0.24 mm
Valve head thickness: Inlet 0.5mm 0.25 mm
Exhaust 0.8mm 0.5mm
Valve stem bend 0.05 mm TIR
Valve stem diameter: Inlet 4.975 4.990 mm 4.96 mm
Exhaust 4.955 4.970 mm 4.94 mm
Valve guide inside diameter 5.000 5.01 2 mm 5.08 mm
Valve/valve guide clearance
(wobble method): Inlet 0.02 0.07 mm 0.18 mm
Exhaust 0.06 0.11 mm 0.21 mm
Valve seating surface:
Outside diameter: Inlet 30.8 31.0 mm
Exhaust 26.3 26.5 mm
Width 0.5 1.0 mm
Valve spring free length: Inner 35.5 mm 33.6 mm
Outer 40.5 mm 38.6 mm
Valve seat cutting angle 32 degrees, 45 degrees, 60 degrees
Hope it helps.. Ken
Aug 18, 2014 | kawasaki ZZR 1100 Motorcycles
In an inline 4 cylinder 8 valve scorpio 2006 crde engine having 1-3-4-2 firing order which valve is first - the outlet or the inlet
from the belt side first valve is inlet second valve is exhaust..bigger valve is inlet small valve is exhaust also you will have a black colour in exhaust valve stems...
Feb 28, 2013 | 2011 Mahindra Scorpio
Inlet valve non operational on whirlpool awm 258 nordic
Please check on the voltage on the inlet valve , check on the controller if there is no voltage if not the inlet valve is faulty.
click this link: inlet valve
Jul 27, 2012 | Whirlpool Washing Machines
I have a tricity bendix dh101 stopped working cold water not going in to manchaine many thanks if u can help
Possible that the INLET valve is faulty /clogged or there is no voltage to switch ON the inlet valve.
So measure the voltage at the inlet valve, also check if the inlet filter is clogged.
Check the water pressure at the inlet to confirm, remove the line from the inlet valve and confirm the flow when activated.
Aug 08, 2011 | Tricity Bendix Dishwashers
Dishes not coming clean
Check water inlet valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
How to test a dishwasher water inlet valve.
How to replace a dishwasher water inlet valve.
May 26, 2011 | Maytag Dishwashers
Water pooling in washer in between loads
The problem is caused by a leaking water inlet valve and the only way to solve it is by replacing the water inlet valve assembly. It is an easy "do-it-yourself" fix that only requires a minimum effort.
Water Inlet Valve Replacement Procedure
  1. Remove the three screws at the back of the machine holding the top cover.
  2. Slide the top cover to the back and lift it from the washer.
  3. Put a bucket or pan under the inlet valves.
  4. Remove the fill hoses from the machine and drain the water into the bucket or pan to avoid flooding your floor.
  5. Remove the screws holding the water inlet valve assembly to the back of the machine.
  6. Use a pair of pliers to press the spring clamp holding the inlet hose to the inlet valve assembly and move the spring clamp away.
  7. Install the new water inlet valve assembly and all other parts disassembled in reverse order of the procedure above.
  8. Make sure to clean the fill hose filters, if there's any, before attaching it to the water inlet valve assembly.
Jan 20, 2010 | Kenmore Elite 45986 Front Load Washer
Dishwasher makes grinding noise during wash cycle (after pre-wash). noise persists for 15-20 minutes. It seems as though the inlet valve doesn't open during this phase of the cycle. adding water to the...
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it. Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Nov 19, 2009 | KitchenAid Dishwashers
Leaky ice and water dispenser connections
HI, this will occur if there is debris present inside the inlet valve structure that is preventing the inlet valve form completely closing itself when not in use. the will cause a small amount of water to leak through the lines. This could also be a damaged valve as well(mechanism failure).
I recommend to inspect this valve. The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush
or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Sep 27, 2009 | Kenmore Refrigerators
Ie error code
The Water Supply Tap is closed. The Water Supply is shut off. The Inlet Hose is kinked. The Water Pressure is very low. (below 10 psi) Inlet Valve is OK? The filter of Inlet Valve is clogged by impure water. The Hall sensor is OK? The Impeller of Air Guide is bound
Measure the electric resistance of Inlet Valve. (950-1300 ) Clean the filter of Inlet Valve. Check the frequency of Inlet Water by the Test Mode. Replace the Air Braker.
Sep 20, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
No water or ice
HI. could be4 as simple as a frozen inlet line or, the water inlet assembly valve may be damaged as well. I recommend inspecting the lines for ice or frozen water. if the line are Ok and not frozen, this will confrim a defective inlet valve.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Aug 17, 2009 | Refrigerators
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
49 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
