Question about Garden
What are the torque requirements for the valve covers bolts for a Briggs & Stratton 18 horse power Vangaurd Engine
  • 376 Answers
25 in. pounds
Posted on Jun 18, 2009
What are the torques on a 22hp ohv briggs and stratton head and also push rods
VERIFY your engine model numbers
Briggs & Stratton Intek V-Twin
Engine Model Numbers 407777 and 44P777
Cylinders 2 (Dual cylinder)
ITEM N m (Newton metres) lb-in Spark Plug Torque 20 180 Back Plate (to cylinder) 11 100 Blower Housing Screws 9 80 Breather Screws 6 55 Carburetor to Manifold 7 65 Cylinder Head Bolts 25 220 Cylinder Shield 7 65 Crankcase Cover 23 200 Engine Mounting Bolts 48 35 lb-ft Electric Clutch Mounting Bolt 75 55 lb-ft Exhaust Manifold 16 140 Fan Retainer Bolts 16 140 Flywheel Nut 203 150 lb-ft Armature Mounting Screws 3 25 Intake Manifold Bolts 9 80 Rocker Arm Adjustment Lock Nut 7 62 Rocker Support Screws 11.3 100 Valve Cover Cap Screws 11 100 Carburetor to Intake 7 65 Valve Clearance (Cold) 0.10-0.13 mm (0.004-0.005 in)
WARNING: Uneven tightening will warp the head. Tighten Cylinder Head Bolts down evenly by hand. Then using torque wrench tighten in sequence, in 9 N m (80 lb-in) increments to 25 N m (220 lb-in).
Intake valve push rods are aluminum.
Exhaust valve push rods are steel.
DO NOT interchange push rods.
Removal and Re-installation sequence for bolt removal and tightening.
Mar 21, 2015 | Garden
What are the torque specs on intake manifold on Briggs & stratton
if there is thread locking compound on bolt or threads it must be removed, use a tap to clean the threads and a wire brush to clean the bolts. Use a thread locking compound (blue) when reassembling, torque the bolts to 30 ft. lbs. alternating bolt to bolt in 7-10 lb. increments. Recheck the torque after the engine has been ran up to op temp.
Jul 17, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Need to know the torque sequence for my briggs & stratton 6.25hp craftsman push lawnmower engine?
One method that works is to use a star shaped pattern and torque the bolts in 2LB increments. Be careful not to overtorque the bolts.
Jul 15, 2014 | Briggs & Stratton Garden
Briggs and stratton 15.5 horse power over head valve
could be to much oil in engine are bad rings in engine or bad valve seals one of those three i would go with bad valve seals
May 14, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
18 hp Briggs blowing oil into the air filter
Sounds like your valves are sticking, possibly bent w/piston damage.
Dec 14, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Torque specs. for a briggs @ stratton 24hp. head bolts
WHAT IS THE VALVE CLEARANCE ON A 23 HP. BRIGS MOTOR AND THE TORQUE ON THE HEAD BOLTS?
Jul 17, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Head bolt torque for 16hp horizonal shaft engine
Anywhere from 35 lbs to 220 lbs, depending on the series of your engine. For your engine, the head bolt torque should be 190 lbs.
But I've attached a chart for you to utilize to make sure of your exact engine model series, just in case there was a transposed number, etc.
http://www.small-engines.com/torque.html
Here's the official Briggs & Stratton chart for all versions of their engines, which confirms the 190 lbs torque spec.
http://www4.briggsandstratton.com/miscpdfs/RNT/Engine%20Specifications%20Chart_ms3992.pdf
Hope you found this Very Helpful and best regards!
Aug 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Garden Logo
107 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
