Video display problem, on MOBO A780GM-A
I have amobo A780GM-A new. A 2.7 athlon cpu, 4 gigs of memory g-skill, build in ATi 3200 video card. The problem is that after install windows and drivers for mobo and video display, after a few minutes the screen on the monitor will go off. Try everything but did not work. Baught an external PCI_E X16 video card and still have the same problem. What can be this crazy problem?
  • Lee Paine May 11, 2010
    how old is the monitor? and what condition is it in?
  • Hank May 11, 2010
    Did you go into control panel-power management and check to see when monitor will shut off? Could be it's set for only a few minutes.
    Hank
    Problem Solver:
  • 6 Answers
Well You Should Check Your Power Settings On The Computer Also I Had The Same Problem Last Year And What Happened Was That The Monitor Was Starting To Burn Out So I Got A New And Now It Works Great. I Also Checked The Monitor Setting Before Getting The New One
Posted on Jun 18, 2009
In call of duty ghost do i need to buy 1 whole 8 gig of memory
You need to have 6 gigs of free dynamic ram.(Not including that used by the operating system and any other applications you have.
The way that memory is organised in a computer these days is usually in pairs or DRAM (dynamic random access memory) sticks which are matched. This allows the CPU to withdraw data from both memory sticks in the same clock cycle (DDR double data rate) which improves the over all speed of the processing.
So legal combinations over 4 gigs which will use the dual channel feature on your motherboard will probably be.
2 x 4 gigs sticks = 8 Gig DRAM
2 x 8 gig sticks = 16 Gig DRAM
Below is the minimum specification requirement.
Note: MINIMUM Faster CPU better graphics card and More ram is better.
CPU: Intel Core 2 Duo E8200 2.66 GHZ / AMD Phenom X3 8750 2.4 GHZ or better CPU Speed: Info RAM: 6 GB OS: Windows 7 64-Bit / Windows 8 64-Bit Video Card: NVIDIA GeForce GTS 450 / ATI Radeon HD 5870 or better Sound Card: Yes Free Disk Space: 40 GB
Feb 24, 2015 | Activision Call of Duty: Ghosts Full...
Hi i have a imedia desktop, the mobo is a msi 7168 ,( socket 939) the origional cpu is a amd athlon 3200 single core ! now i have replaced this with a dual core athlon 4400+ now the memory has 4 dimm...
First time I heard that But Maybe your board needs a bios update which I personally wouldn't do unless you really know what your doing. I would buy better ram and more of it and just use the two slots that work.
Jan 24, 2011 | AMD (90613) PC Desktop
Will My ATI RADEON 9550 Video Card Work With GTA IV/4? the boz says: "ATI RADEON 9550 FUELED BY SAPPHIRE" "256MB DDR MEMORY" "WITH TRIXX OVERCLOCKERS UTILITY" This Is The Same As My Video Card:...
these are the specs you need!!
Minimum System Requirements
  • OS: Windows Vista - Service Pack 1 / XP - Service Pack 3
  • Processor: Intel Core 2 Duo 1.8Ghz, AMD Athlon X2 64 2.4Ghz
  • Memory: 1.5GB, 16GB Free Hard Drive Space
  • Video Card: 256MB NVIDIA 7900 / 256MB ATI X1900
Recommended System Requirements
  • Processor: Intel Core 2 Quad 2.4Ghz, AMD Phenom X3 2.1Ghz
  • Memory: 2 GB (Windows XP) 2.5 GB (Windows Vista)
  • 18 GB Free Hard Drive Space
  • Video Card: 512MB NVIDIA 8600 / 512MB ATI 3870
Jun 15, 2010 | ATI RADEON 9550 Graphic Card
I would like advice on upgrading my Graphics card
Unfortunatly your still running low end CPU power and low end agp graphics. Your going to pay 150-200 just for a fair PCIe/AGP HD/3D VC. If $200 doesnt hurt (and this is the lowest price best option), then might I suggest Mobo/CPU/RAM for around $200 that would do the trick and allow for future upgrades. You might also need a power supply. I just built one less than 3 weeks ago for a friend and it fairs against my own gaming comp.
MY PC...
AMD ATHLON 64 X2 DCP 6000+ 3.01GHz
NFORCE6M-A V:2.0
8GB PATRIOT
XFX 8800GT AD 512MB
500W PS
NEW PC....
Gigabyte GA-MA785GMT-UD2 MB $90+/-
AMD Athlon™ II X2 250 BOX 3.0GHz (CAME W/FAN)$70+/-
AND 4GB OF DDR3 1066 RAM COMPATIBLE WITH MOBO $40+/-
THE ONBOARD VIDEO IS CAPABLE OF USING 700MB
OF RAM...RGB/DVI OUT.
HOPE THIS HELPS.
Sep 12, 2009 | Asrock K7VT2 Motherboard
Green lines in black/grey screen (only vista, xp runs normal)
It's the onboard video try removing the CMOS battery and placing it back in after serveral hours, if that doen;t work it's the onboard Video replace it with a PCI Express Video Card.
Jul 27, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
No display on monitor
this lead to cpu overheating problem
clean your cpu fan and put some thermal grease between the fan and cpu
Jul 17, 2009 | Foxconn NF4K8AC-RS-1.0 Motherboard
Ram
Okay, you don't need two video cards. Your 4 memory slots are grouped in two's. One set is black and blue, and the other set is black and blue also. These are your dual memory channels.
The reason you can't see more than 2 gig ram is because you are probably not running 64 bit Windows with a 64 bit processor.
32 bit windows will only display 2 gigs, but max memory is 4 gigs. It will draw on the extra 2 gigs if ever it is needed, but this does not happen very often, if ever.
Hank
Jul 14, 2009 | ASUS A8N-SLI Deluxe nVidia nForce4 SLI...
No beep,No Display on my monitor,only CPU heatsink fan is moving
You motherboard has onboard video. It's possible it needs to be disabled and the option changed to use the pci or pci-express slot for the Ati card you installed. Since you have no post error beeps this is the best place to start. Also I had built a system not to long ago and had a similar problem. Resetting the cmos on the motherboard (usually a pin combo) solved the issue.
Start by hooking up your vga cable to the onboard video.
Hope this helps.
Apr 07, 2009 | MSI P7N Diamond Core 2 Quad/ Nforce 780i...
Monitor doesnt come on--just installed ecs a780GM mobo
Recheck all the hardware connections.
If it fine check the your CPU with another monitor. If it not works then fault with the CPU or software.
Hope this helps.
Feb 07, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
Computers & Internet Logo
172 people viewed this question
Alun Cox
David Payne
David Payne
