Question about Eiki LC-XG250 LCD Projector
Have Eiki LC-XG250 projector. Recently had a power outage and since then it has not come back on. Have tried the reset, have plugged into different plugs, with no success. No standby light, nothing - could be internal fuse? if so how can I fix it? power supply? help....contact eiki tech support and of course they say i cannot reset fuse, would have to send it in for repair - how can i fix this? thanks
  • gary831 Jun 17, 2009
    if lamp was problem, that would not prevent projector from not having any power whatsoever would it?
  • 10,515 Answers
There is "NO" reset fuse. As the projector didn't turn, there might be millions of reasons. Might be an issue with lamp due to power outage or might be some other fault. There might be millions of reasons and you would agree. We cannot jump to conclusion that, it is Lamp. There might be an issue with power supply unit as well......
So, to be on a safe side, i would advise you to send it in for repair. This might be a small problem, However by trying to go for DIY ( Do It Yourself ), you might end up paying more bucks.
Rest, Decision is all Your's.
Thanks for using "Fixya".
Posted on Jun 17, 2009
  • taran_2005
    taran_2005 Jun 17, 2009
    I gave you an example. It might be power supply unit or a combination of multiple failures.My main motive is to advise you to avoid DIY in this case as power outage can cause multiple failures in projectors.
    I hope you would agree.
    Any further help, let me know.
    Thanks for using "Fixya'.
Eiki LC X1100 - the unit is loosing all power [no standby leds] when switching on after being off for 5 minutes or more. I've found that if power is disconnected and Reset switch is engaged it will come...
in primary power-supply circuit there are 2 smd capicitors,1uF and 2.2uF, replace them both by standard radial 105 C electrolytic, also replace the 220uF capacitor that is located beside these 2.
Oct 16, 2013 | Eiki LC-X1100 Multimedia Projector
Have Eiki LC-X1000 projector. Recently had a power outage and since then it has not come back on. Have tried the reset, 230 AC ok and 300 DC volt ok, No standby light, nothing,then what can i do
dried out smd capacitors in primary part of power supply , common problem with this and similar models. 1uf, 2.2 uF and 1 radial 220 uF
replace bij 105 oC type
Apr 05, 2012 | Eiki LC-XG250 LCD Projector
Eiki lc-sd15 has no power. The lights do not come on when plugged in and nothing works.
near the lamp door is a small hole with a resetable thermal fuse under it, try to push pin carefully
Jan 18, 2011 | Eiki LC-SD15 SVGA LCD Projector Multimedia...
Consistent flickering; had the projector on for 2 hours. Have rebooted 2xs. Eiki LC-XG250
Check your filter and make sure the projector is well ventilated ( all vents free of objects), all electronics have to cool. Some lamps start flickering when their about to die.
Oct 24, 2009 | Office Equipment & Supplies
EIKI LC-XNB3 Projector - Does not recognize any Video Inputs
there might be a bad connection between the input board and the main board. There are different connectors ( white) between them, that might be damaged during portable use
May 24, 2009 | Eiki LC XNB3 Multimedia Projector
I do not know how to use Eiki LC-300
The operation manual is at this addres (http://www.eiki.com/docs/owners-manuals/lc-300_owner-manual_2000-06-05_en_na.pdf?sfvrsn=14). It is a PDF & very easy to download. If you need any other help, write back.
Oct 14, 2008 | Eiki Projector lamp Projector Lamp for...
Eiki LCSB Projector: no input
make sure the resolution matches the input.
Sep 14, 2008 | Eiki LC-SB20 Projector Multimedia...
Bulb Life
hi,
This is 2000 Hours, 160 Watts, UHP lamp. dont keep it on always.Check the usage and then replace the lamp. It's better to turn off the projector after each class.
The lamp is around $400.00 for Eiki LC-SD15.
Viren
Rave Services India
Feb 07, 2008 | Eiki LC-SD15 SVGA LCD Projector Multimedia...
Eiki LC-XG250 LCD Projector Logo
88 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
neOen
Level 1 Expert
Jaime Hernandez
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
