Question about Emerson EWF2004 20" TV
I cannot get my Emerson DTV to play on all channels since they hit the switch. All the stations is breaking up, and some I cannot get. I have reset and I run setup over and over still cannot get all my channels. It just want play good anymore.
I have an emerson tv with remote. It doesn't get all channels. I don't know how to reset for all channels
Posted on Sep 13, 2009
  • 74 Answers
You prabably need a new digital antenna since the digital swich over.
Posted on Sep 18, 2009
Keep loseing local channels , change antenna 4times allways resetting channels gain and lose
Hi, I may have the answer for you. Your (TV) is very sensative to off air stations (anntena).
If you are near a cell tower or Power lines your TV tuner will have a harder time finding anything.
You may need to switch to Cable or dish to recieve anything worth watching. Most off air channels
will fade away because of DTV. If you have a chance Google (digital TV) for your search.
Good luck...
Jun 04, 2011 | Televison & Video
How do I reinstall the channels for complete digital TV in my area?
You can redo auto scan for channels anytime.
The US DTV technology is still changing. The software autoupdate for your DTV tuner and memory can be done anytime by broadcast station signal. So, from day to day your tuner may improve in sensitivity to reach farther DTV stations. And the picture quality can also change by new decoders downloaded into the DTV converter.
Aug 15, 2010 | Televison & Video
My radio won't play tv channel 4 sound or any other! please tell me if im doing something wrong!
Since June of last year all television broadcasting switched over to digital signals. Without a converter your radio will not receive any of the stations sound channels. Impossible to modify, only a converter will bring the stations in.
Feb 05, 2010 | Emerson RP6250 AM/FM/Weather/TV Radio
My dtv keep saying nosignal antina hooked up .protron tv was working fine ran scan station. stop playing
dtv needs a strong signal to keep track of the channel. The antenna is good inside the room but tends to be affected for interferences. to catch signal (as in the past with ear rabbit antena) is difficult inside the room. and roof antenna is better but needs a good installation. the cable channels can work digital without the dtv. Is hard to give you any idea besides this ones because i don't know how the set up[ is in your case problem, but i hope i could help you a little. Now if the antenna is rasonable good and still having problems with your channels the suspect the dtv failure.
Apr 24, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
My LCD won't tune into DTV
You need to go to your menu option with your remote. Select channel scan from the options listed in setup. This will allow the turner to find your DTV channels again. Hope this helps. J
Apr 09, 2009 | Televison & Video
Trying to help this older lady with a emerson tv/vcr combo. She has no manual with set. Setting up to record same station everyday at same time. VCR will record but when playing back she only gets sound no...
The TV should be on channel 2, 3, or 4 to work correctly. There might be a small switch on the back of the VCR that lets you select the channel that it wil play back on.
Also, look on the remote control for the VCR and see if there is a button labeled TV/Video, and press that while something is playing. This switches back and forth between the TV signal and the VCR signal and it could solve your problem.
Jan 08, 2009 | Emerson EWC1304 13 in. TV/VCR Combo
Digital tv not picking up digital signal??
According to the manufacturer, the EWL20D6 Television is not digital ready. If that is the case then you will have to use a converter box in order to receive the digital channels.
Dec 20, 2008 | Emerson EWL20D6 Television
DTV Converter hookup
Is it possible to record TV programming on a VCR when using a DTV converter? h1 = document.getElementById("title").getElementsByTagName("h1")[0];h1.innerHTML = widont(h1.innerHTML); Hi,
I had the same problem and found this answer that worked for me. Hope this does the trick for you.
Simple stated, your VCR must be set to channel 3 also. Check it out.
woody
  1. You must have the VCR tuned to record on channel 3.
  2. You must have the VCR connected to output signal of the DTV converter box. In other words, the converter box must be connected between the antenna and the VCR. So, the likely configuration you would use with a coaxial cable is antenna to DTV converter to VCR to TV.
  3. You must tune the DTV converter to the channel you want to record prior to recording. The VCR won't be able to change channels on the DTV converter.
  4. You will be able to use the timed record function on the VCR but you must adhere to steps 1-3.
If this sounds freakishly familiar to recording on a digital cable or satellite set-top box, you are right. It is exactly like recording a signal from a digital cable box or satellite receiver. While it may be inconvenient to perform the steps above, at least the option still exists to record on a VCR while using a DTV converter box.
Disadvantage of DTV Converter: You will lose the ability to watch one program and record another with the DTV converter. Sorry for the bad news.
The reason is the tuner. The VCR tuner is useless with digital except for recognizing channel 3. The digital converter is a single tuner item so it only receives one station at a time.
Oct 17, 2008 | Emerson EWV603 VHS VCR
Samsung LE40R73BD DTV freezing, wont chnage channel
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Oct 24, 2007 | Televison & Video
Emerson EWF2004 20" TV Logo
615 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
