I had a problem with my mac, in that it would turn on and get past the wheel, and go to blue screen, but the desktop would never appear. so the startup did not seem to complete..... Taking a solution from fixya, I then turned on, holding down the SHIFT Key and saw ghostly movements on the screen, which now seems black with slight white at bottom corners.... Does anyone know how to fix this...?
    Sergeant:
    Champion:
  • 387 Answers
It's a software issue, you could use the recovery discs first and then to the Apple Store or call Apple tech support.
Posted on Jun 23, 2009
My Apple Mac keeps giving me a message telling me to restart but when I do, the apple screen appears with small wavy red lines through the apple. It then goes to the blue screen and finally flips to
This could be anything and will take a workshop to diagnose correctly.The power-supply unit in these Macs was particularly problematic and it could easily be that but without a worksop visit it's im[possible to tell.
Jan 07, 2013 | Apple PowerMac G5 Dual Mac Desktop
When i start up my imac screen goes white with apple logo ang loading wheel then after that a blue screen,then just stays on blue screen
Thanks for asking your question with Fixya Support. I will be glad to assist you.
What I would recommend is that you try to acquire a USB keyboard, for this issue, because it will open the way for many troubleshooting options for such an issue like this.
If you can get temporary use of a USB keyboard, you can try any of these options:
Option 1:
Here are some steps you can try to resolve the issue:
• First, hold in your power button for approximately 10 seconds to do a hard shutdown, if it is not already shutdown (turned off)
•You will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the start-up sound for the second time.
• Release the keys and allow your iMac to start up.
If that does not work and you still reach a blue screen when you reboot, try this option:
Option II
Here is a simple procedure that I recommend you try:
-SMC RESET-
The System Management Controller is an integrated circuit (computer chip) that is usually on the logic board of your Mac computer.
It is responsible for power management of the computer. It controls backlighting, hard disk spin down, sleep and wake, some charging aspects, and some input/output as it relates to the computer sleeping.
• Shut down the computer.
• Unplug the computer's power cord.
• Press and hold the power button for 20 seconds.
• Release the power button.
• Attach the computers power cable.
• Press the power button to turn on the computer
If you still reach a blue screen, now you will need to go to this alternative process:
Option III
Try taking your Mac into Safe Mode in order to remove a possible folder(s) which may be affecting your Mac's start up function.
Try these steps:
-SAFE BOOT MODE-
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop enviroment the only difference is certain startup items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
• Remove all of those folders to the Trash.
*Reboot your iMac normally and see if you can access your normal User desktop environment.
One of these three options should help return you back to your main desktop.
If it does not, please let me know.
Thanks!
-The MacTechTrainer
Sep 10, 2012 | Apple 24" iMac Desktop
My laptop is on but the screen is blue and won't go to the desktop
A Mac that shows you a blank blue screen instead of logging you in may be afflicted by a malfunctioning startup item. Most people have a number of programs that start up whenever you log into your computer, and it's likely that one of these programs is causing issues. The startup item is unable to load, and so it causes the rest of the computer to hang.
In order to get your Mac past this hanging blue screen, you need to boot into safe mode and figure out which startup item is causing problems. The Apple Support article "I see a blank blue screen when I try to start up my computer" tells you exactly how to go about this procedure. Basically, you must remove all your startup items and add them back in one-by-one, rebooting each time until you find the one that causes the hanging blue screen.
Dec 28, 2010 | Computers & Internet
Apple laptop will not start
Get your Mac OS disk out and restart your computer with the disk in the drive ANd while holding down the C key. This will start the computer on the OS disk system.
Once you get to the desktop, look for the top menu and launch Disk Utility. Run a repair and see if you get any indications that it found anything out of the ordinary.
Then restart as normal.
If it still doesn't work, I would recommend reinstalling the system software.
Jun 02, 2010 | Apple MacBook Pro Notebook
Mac not loading
Try resetting your pram:
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Aug 28, 2009 | Apple eMac G4 Desktop
When i stert my g4 imac,s screen was became blue
You need to reset your pram
Jul 01, 2009 | Apple iMac All-in-one - 3.06GHz Intel Core...
Turn mac on, get white screen, have to turn on/off for ages
try re-installing os, it looks more like RAM issue.
Jun 29, 2009 | Apple iMac 17" Desktop
Imac not booting
Hi, Sorry you're having trouble,
OK, so much is happening here...
Can you shut the Mac down ( by holding the power on button for 5 seconds or so ) and then, make sure your keyboard is connected and that nothing is resting o the keyboard possibly pressing down on a key without you knowing it....
Now, start up your Mac and VEY QUICKLY, press down on the ( alt ) key and hold it down until you see a blue screen with a large Right pointing arrow and a circular arrow.
This is the start up disk selection screen. You should eventually see your Hard Drive appear at which point, you click on your hard drive and then the right arrow to start up the mac on your Hard drive.
If your disk is still OK, it will boot properly.
If your disk does not appear in the blue selection screen, it means you either no longer have a valid bootable system on that disk or it is KAPUT.
So, if this is the case, you will need to get a new hard drive.
How old is your mac, what model is it what Mac OS is it ?
Mar 22, 2009 | Computers & Internet
My ibook g4 has a blue screen when it comes on
It appears that your system is corrupted or the hard drive is damaged. Try re-installing the system software from the CD by holding down the C key during start up. Then run Disc Utilities to check the hard drive.
Dec 18, 2008 | Apple iBook Mac Notebook
19 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
